Vizio SV320vxt popping fuses like it made it up.
    Re: Vizio SV320vxt popping fuses like it made it up.
    The two main DC caps (two long brown cap 450VDC rating) are in parallel to get enough filter (they are selected for the amount of the AC ripple (riding on top of the DC) that the circuits are allowed to accept).
    This power supply board has PFC Voltage booster circuits, when the TV is OFF, the DC on that cap should be around 165~170Vdc, when the board gets the PS_ON signal from main board, the voltage on the caps should go up to around 390~400Vdc.
    Most TV in the last 2~3 years use PFC circuit to get power factor as close to 1 as possible.
    • shwsrvcs
      • Jan 2012
      • 69
      #42
      okay.. now that I've got them both connected properly they both read 167.6 with the power on standby and 163,4 when the vizio light is illuiminated.
      • shwsrvcs
        • Jan 2012
        • 69
        #43
        Ohhh ok. I see that! so let me bring that board back here to my desk...
        dang it...
        I am so dumb. I touched the probes together cuz I decided to see if the voltage had changed for either of the two, with the additional info on the pdf, it was clear as water how those two interacted with the next part on the board.. and those mosfets above them.. but anyways... they touched and there was that distinct pop of electricity. now the caps don't read any voltage at all, the main fuse, beep on the continuity setting, but now the meter reading fluctuates while it beeps... damn it.
          Check the PFC diode on the primary side.
            By the way, my post #41 with the attached PDF, I also circle some caps that look like they have domed tops, did you verify that, may be its the distorted pix.
            • shwsrvcs
              • Jan 2012
              • 69
              #46
              I took these pics earlier then walked away from it for a day to try another avenue hopefully be successful this time.
              Here are 4 views of those caps, they do look odd at certain angles, but when I look closer then they look okay...
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #47
                Hi I have just been reading through the thread and have had what I hope is a eureka moment.
                In post 19 there is a picture of the inverter board and there is a white sm fuse. I cant see that this is referred to in the text and wonder if you have tested it at any time?
                • shwsrvcs
                  • Jan 2012
                  • 69
                  #48
                  You know, I took a break yesterday to write out my letter of resignation from the porn biz to jump into the deep end here in this line of work. (seriously, i've been webmastering in porn since 99 but its a dead industry now) but now I'm getting ready to test another board for another vizio here. I'm going to pull that back on the bench as soon as I get this testing finished.
                  Thanks for the idea!
                  DG
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #49
                    There are also two ceramic fuses on the main board F1 & F2 - have you tested those?
                    • shwsrvcs
                      • Jan 2012
                      • 69
                      #50
                      I took the time time walk away for a bit and come back fresh. I really appreciate all the help I've received here and this forum is the absolute best I've seen in a long while.. at least 10 years of bbs/forum usage.
                      I tried the last couple suggestions and all the ceramic fuses come back as good. I went thru again today and tested the voltages coming from the main board back (PSON) and it shows an increase when the power is turned on, the amber light in the front turns white when the power is turned on, the power will stay on (amber light is white) until it is turned off.
                      Checked to find if the video is being sent to the screen but I am unable to see any thing while using my led flash on my phone or incandescent flashlight.
                      so I've got power all the way up to when it comes back to the switch mode power, but at that point from what I can tell, there is no signal to the screen and no power to the backlight. I really wish I could have figured this out but I think I'm out of time, well... yes, I'm out of time,
                      The person I'm working on this for has been and is still being very patient but realistically, Im thinking maybe.. I've taken time in this repair that would better used by maybe ordering the 60 dollar board on eBay and just replacing it?
                      Really I wish there was more of standards type thing going on at the component level, if not for all brands, at least across each brand. I had 4 vizio's thru here last week and each one of them has it's own way of connecting between boards, the ccfl's. I understand the tech is ever expanding but maybe with the advent of led back lights the need for just downright funky boards in each model in a product line can give way to something more modular and interchangeable.
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • mrtek
                        Vizio M65-C1
                        by mrtek
                        Hi.
                        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                        07-14-2025, 07:28 PM
                      • Sik_6ty_Sixx
                        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                        by Sik_6ty_Sixx
                        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                        02-18-2025, 05:06 AM
                        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                        12-14-2023, 07:45 PM
