Re: Dead Sanyo DP26648 logic board, need service manual.
By any chance do you still have the cable that goes from the logic board to the T-CON board? I tripped over the cord that plugs the TV into the outlet and did a bit of damage.
The connector on the T-CON board lifted a bit off the board. I tried soldering it back down. I didn't get it perfect but it's holding it down a little. Just at a slight angle.
I'm getting absolutely nothing on that VIN_12V on the T-CON board now and on the cable on the T-CON side, a wire isn't staying in the connector because I broke the little thing that prevents the wire from coming out off.
Just more bad luck I guess. I don't know if I jacked up some of the T-CON board pins when I tripped over it and that's why there's no voltage at all on the test point or if it's because of the wire on the cable. I doubt it's the wire though because it's the second to the last on the opposite side of the VIN_12V test point.
Originally posted by cashkennedy
View Post
