Vizio VX37L HDTV 10ABlack vertical lines on right side
  • bikerbuddy
    • Jun 2011
    • 134
    Hi I have a 37"vizio model # VX37L hdtv 10A , No sound no pic , It has black screen with vertical lines ,I took the back cover off and looked over the power supply did not see any thing unusual , the back light is on when it is power up but has to to shut down by removing the wall plug.
    I measure the voltage on the P/S while the TV is on with my Dmm and I
    get the following voltage measurement.
    All 24V is measured 24.53
    A voltage is 1.40V
    B voltage is 3.56 V
    5 voltage is 5. V
    Ps on is 3.50
    12 volts is 12.2
    I have noticed that if I remove the harness from the Tcon board and plug it back in those lines will move over to the left of the screen.Here is a few picture of what the lines look like.
    I have a fair amount of electronics knowledge and I can do some component repair if pointed in the right direction.
    Any and all help is greatly appreciated.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VX37L HDTV 10ABlack vertical lines on right side
    Do those line show up with the on screen menu like setup?
    --- begin sig file ---
    --- end sig file ---
      I have seen this problem before and it was a T-con fault.
      Do Retiredcaps check first, though.
      • bikerbuddy
        • Jun 2011
        • 134
        For Retiredcaps I did not try it with the menue but I will try it this morning and post back.
        For Tom66 I have seen an article where it has pointed to the tcon board, however I saw a Tcon board on Ebay for $25.00 I was lucky that the board was located right here in St.Pete I called up the fella and he pulled it off Ebay I will pick it up this morning and install it then see what gives.
        Thank you Guys will post back later.
        • bikerbuddy
          • Jun 2011
          • 134
          Ok Guys since my last post last night I picked up the Tcon board from a local fella , installed it and power up with my remote ,I was hoping for a little miracle, sorry guys no miracle today .
          With the other Tcon board now I get vertical lines over the entire screen any one with any suggestion what I should try next.
          By the way the PS is maintaining all the right voltage as i mention in my first post. I had to take the pic of the screen left half and right half was difficult to get the whole screen in one shot and hold the TV up at the same time
          The TV does not respond to the remote control except for power on
          See pic.
            It looks like you did not seat the ribbon cables correctly between the T-CON and the LCD panel, try resting them again, also try using contact cleaner on the connectors.
            • bikerbuddy
              • Jun 2011
              • 134
              Budm I went to sleep last night with the ribbon cable on my mind , I am going to look into it this morning and will post later.
              Thanks for conforming my thoughts
              • bikerbuddy
                • Jun 2011
                • 134
                After spending about 2 hours messing around with the ribbon cable I just cannot fix the vertical lines on the screen, I kept on swapping tcon board
                no luck, I open for any suggestion.
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • brad2157
                  Vizio E70-E3 Two white vertical lines
                  by brad2157
                  I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                  Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                  Replacement main board - Boots up fine, but starting...
                  12-13-2021, 05:11 PM
                • pni
                  LG 49uf695v vertical coloured lines
                  by pni
                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                  11-14-2025, 03:15 AM
                • viking509
                  vizio e65 e3 LED tv color vertical lines center tv only
                  by viking509
                  I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                  03-21-2023, 12:48 AM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
