Technosonic 1908
+ More Options
Posts
  • sienoki
    sienoki
    • Jan 2012
    • 314
    Technosonic 1908
    Another project im hoping to fix..
    This lcd tv i got from a friend to try and fix..no power lights no nothing dead.. has a ticking noise from transformer..after googling the psu (MSDV1901-ZC01(B) there was a common fault with the 2 schotty diodes on the heatsink..so i replaced them with MBR20100CT-20a-100v..still same issue and ticking noise remains
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Technosonic 1908
    check for shorts on the output(s) and replace the startup cap (usually 47uF 35-50V).
    That's usually the first thing I try for ticking powersupplies.
    If that's not it, look up the datasheet on the SMPS controller IC and start checking that one.
    • sienoki
      sienoki
      • Jan 2012
      • 314
      Is the start up cap usually in the psu area if so mine was 50v 22uf i replaced that 1 but no joy..where would i start testing now..thx
      • sienoki
        sienoki
        • Jan 2012
        • 314
        where will that IC controller be..thx
        • bbjunkie
          • Dec 2011
          • 301
          See attached photo.
          Controller is usually on the underside. Small surface mount IC
          Post a pic of the underside, and the number on any chips close to the startup cap on the opposite side of the board.
          I'm not the best person to be giving advice, I've got a PSU ticking at present and cant locate the source of the problem!
          • PlainBill
            • Feb 2009
            • 7034
            You're going to have to give us a little more to work with. I really prefer that the picture cover the entire board.. including the edges.
            The controller could be the device fastened to the heat sink, it could be on the bottom of the board, or it could be on the top of the board, but in the shadows. It will be in the neighborhood of the very large cap.
            PlainBill
            • sienoki
              sienoki
              • Jan 2012
              • 314
              The 3 blue disc caps are c103..103m-1kv..c102..101k-1kv..c114..472z-y1 250v
              how do i measure those..thx
              r101 & r102 both 105 resistors measure.948m
              r104..104 resistor..94.5k
              r121..104 resistor..94.5k
              r110..470 resistor..47.0
              c109 & c106 yellow box caps.22k275v..MCY/HT BOTH MEASURE 1.816m
              thx guys sorry for the poor pics im having to use my phone at moment..the circled cap was the 1 i replaced..theres no smds on underside of board..the ic attached to the heatsink has 6 legs & will need to desolder as i cant see any numbers on it clearly
              • sienoki
                sienoki
                • Jan 2012
                • 314
                I removed the big cap to get a good view of ic..it reads F1G45-CW0765R
                also when i first changed the schotty diodes i kind of overheated the pads abit..so i added a trace..
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  Whats this 4 legged item between yellow cupoid cap & large cap..
                  Ive to far only changed the start up cap would replacing all the caps give me any standby by light or power to backlights etc..or is my issue situated only within the psu area of the board..thx
                  The transformer or within that area has stopped ticking now but still dead..if i desoldered the transformer how can i test it to make sure its not dead..thx
                    That's a bridge rectifier.
                    What do the output voltages measure at?
                    • sienoki
                      sienoki
                      • Jan 2012
                      • 314
                      Am i testing the bridge rectifier with power on & on 20v setting on my multimeter..thx
                        Use diode test.
                        BUT...
                        If the bridge rectifier is dead the fuse will blow or the power supply will not work at all.
                        It is probably not the cause of your problem.
                        • selldoor
                          Slow Learner
                          • 7870
                          I am butting in here just on the side of safety.
                          I believe that the Bridge Rectifier is in the HOT part of the board
                          and it turns the 250v AC into around 370v DC so if you set your meter on 20v there will be smoke.
                          I am not sure which pins are AC and which are DC - it might say on the board? or you could get a data sheet for the part number.
                          I think you can test it power OFF as well but not as a voltage but as a diode Take a multi-Meter and switch it to Ohm x 1
                          Test between one of the "~" and "+" legs.
                          You should get either an almost-zero reading in one direction, and when you reverse the test probes, you should get an almost infinite reading.
                          Now try the same between this "~" leg and "-".
                          Same as above.
                          Now repeat the same tests with the other "~" leg, and "+", and then "-".
                          Same as above.
                          If you either get almost zero or almost infinite in BOTH directions, then the rectifier burnt out.
                          Reading previous bits it is unusual for the blue ceramic caps to fail and same goes for the box caps and even the BIG 400v or 450v cap
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            Same as above.
                            Same as above.
                            When testing the legs of the rectifier from bottom side with power on it keep on tripping my fuse box..so im gonna leave this 1 as i dont want to blow myself up..thx
                            With the fluke 77 series II multimeter
                            I know my limits so thx guys for your help in troubleshooting this set but im gonna give him it back
                            • selldoor
                              Slow Learner
                              • 7870
                              Good Idea!! (not blowing yourself up- not the edit) as Tom says probably not the problem
                              Almost missed this - I have attached what I think is the data sheet for it.
                              (or its equivalent)
                              I dont know enough to suggest how to test it but Plainbill or the others
                              will.
                              • sienoki
                                sienoki
                                • Jan 2012
                                • 314
                                Same as above.
                                Same as above.
                                When measuring this rectifier in dioide mode with above sequence i get .512 then .OL the reverse is .512 an almost zero?..thx
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  That's half the test -looks good to me- picture worth a thousand words:
                                  http://www.youtube.com/watch?v=dqkT6hF0O3E
                                  Just found this
                                  • ntoskrnl
                                    [FIXED] XFX Core Edition Pro 450W ticking noise
                                    by ntoskrnl
                                    My XFX Core Edition Pro 450W power supply started making a weird ticking noise some time ago. Eventually, I figured out what the issue was, and managed to fix it. I purchased this unit back in 2012, so it's an old model, but I'm still posting this in case someone finds it helpful or interesting.
                                    THE PROBLEM
                                    The power supply started making an irregular ticking noise when running, but would otherwise work perfectly fine. The issue would sometimes come and go. A Google search for "xfx core ticking" found multiple other people reporting the same issue, so I assume this...
                                    04-19-2022, 10:36 AM
                                  • TheDragon
                                    LG TV turn off/on also ticking noise
                                    by TheDragon
                                    Hi all, I searched through the forums before posting.
                                    My LG LW650T suddenly stopped working a few days ago, and although I've started the search to replace it as it was old, the picture quality was good and would love to repair if possible to use elsewhere and save some electrical waste.
                                    I gave it to a local repair place who said he would do some basic checks, and reflow it, but it never worked so didn't charge me.
                                    The fault is:
                                    Press the power on via remote.
                                    I hear the relay and power LED turns on.
                                    The other control LED's cycle on/off as per...
                                    02-02-2021, 03:02 PM
                                  • Biruslapio
                                    LG 50PB690 power supply terrible noise
                                    by Biruslapio
                                    I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
                                    As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
                                    I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
                                    07-13-2022, 12:46 PM
                                  • tracid1987
                                    Samsung LE40F86BDX (model 2007) noise in picture
                                    by tracid1987
                                    Hi
                                    I have this TV bought back in 2007 and used it for playing on PS3 for 4-5 years actively. After then it was barely used. It was mostly in stand-by mode or plugged out of mains completely for years. Today when i turned it on i have noticed noise in picture on two different locations of the screen. As you can see on the photos (see attachments) the noise is only in a small rectangle area, and if you look at it closely you see that one noise rectangle area is at the upper left corner of first half of screen, the other noise rectangle area is at the upper left corner of the second...
                                    08-21-2021, 01:48 PM
                                  • eccerr0r
                                    DSI 5600A frequency counter noise ...
                                    by eccerr0r
                                    Anyone have a old ancient DSI 5600A frequency counter (late 1970s)?
                                    Just wondering if you see significant noise on the readout now in 2023, and if you replaced the caps in it.
                                    I had huge amount of noise in the readout but after replacing the caps it went down a lot - but not zero... Still trying to figure out how t get the noise down when right now it looks to me to be a design flaw...
                                    04-22-2023, 12:50 AM
