Sharp lc-42sb45u no response... at all.
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Sharp lc-42sb45u no response... at all.
    @lastleg, -this is a dead thread- you would better off starting a new thread....that said you can be pretty certain that if it says capXcon on it, it needs replacing. The residue coming out the top is the electrolytic that makes the cap work, Ie if the stuff inside is outside that cap is not doing its job. Replace with panasonic fm or nichinon from a reliable source (digikey or mouser) hopefully just the one failure is causing your problem, but there could be more that look ok that are bad as well.
    Liberating magic smoke one part at a time
    • LastLeg
      • Aug 2013
      @Caleb, Thanks for the info. Ordered through digikey. Hopefully this will take care of it.
      • tibimakai
        • Jan 2012
        • 3680
        Repaired another one, with the blown 1.5A fuse on the inverter board.
        • RetroNinja
          • Jul 2016
          • US
          #84
          Can't make a new thread, but I have this TV and when it is first turned on there is a solarization effect on 1 quarter or so of the right side of the TV.
          It eventually goes away (and there is a perfect picture) if the TV is left on long enough. I haven't cracked open the TV yet (to check the boards), but in reading about this it seems like a TCON problem.
          Opinions?
          • advant
            by advant
            02-03-2020, 12:25 AM
          • sefoster
            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
            by sefoster
            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
            11-20-2022, 09:29 AM
          • SONY_E-WASTER
            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
            by SONY_E-WASTER
            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
            does...
            12-26-2021, 05:46 PM
          • gavenb
            Sharp LC-80LE661U 80 inch
            by gavenb
            Hi folks!
            I have a LC-80LE661U that had some interesting issues.
            Initially, it would come on and show the sharp logo and would show normal static before shutting off.
            I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
            11-12-2023, 02:05 PM
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
