Phillips 42PFL5432D/37 Chirping and No Picture
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Phillips 42PFL5432D/37 Chirping and No Picture
    Originally posted by tw1ztid
    Continuity is fine to test the diodes though?
    1) Nope. Use the diode check function to check diodes.
    2) Post a picture of your multimeter.
    --- begin sig file ---
    --- end sig file ---
    • tw1ztid
      • Jan 2012
      • 36
      Dont have it yet. Slow day at work and trying to be prepared. I know how much i question every little thing , and worry if i do it right I'm sure im overcomplicating it. Sorry for that in advance.. lol. Once i catch on to the basics it all gets very simple.
      • retiredcaps
        • Apr 2010
        • 9271
        No worries. With power off and the TV unplugged, there is very little you can do to damage the TV, multimeter or yourself.
        Both the resistance and diode checks are done with the power off and TV unplugged.
        It is when the power is ON, that you have to be careful because one slip of the probe can cause a short.
        edit: See posts #19 and 20
        https://www.badcaps.net/forum/showthread.php?t=10419
        In the guide, I have sections on multimeter, fuses, and diodes.
        • tw1ztid
          • Jan 2012
          • 36
          Thanks, that is 100x better than the video imo because it covers many different things. Was mainly worried that i wouldn't get the correct readings or short something. Be back later.
          • tw1ztid
            • Jan 2012
            • 36
            Got everything ready.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Plug your red probe into the red circled spot. Black probe into COM. The black probe will always stay in COM.
              1) For the diode test, set the meter to the diode test function (blue).
              2) For the resistance test (fuse), set the meter to the 200 (two hundred) scale (yellow).
              • tw1ztid
                • Jan 2012
                • 36
                #27
                Ok, first results..
                ZD904 .02 and .02
                ZD902 .05 and .05
                D925 .07 and .07
                D912 .000 and .000
                I should desolder one side from each to retest now? I've repeatedly been getting the same results. There are other D and ZD diodes that the results came back fine.
                Edit: checking fuses right now, so far so good
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Ok, first results..
                  ZD904 .02 and .02
                  ZD902 .05 and .05
                  D925 .07 and .07
                  D912 .000 and .000
                  If you switched the leads around, then yes all those readings suggest the diodes are all bad. You will have to desolder and retest out of circuit.
                  It is possible that something else on the board is shorted and causing all these potentially false positives.
                  • tw1ztid
                    • Jan 2012
                    • 36
                    #29
                    I'll remove them shortly then, I cannot find any other fuses on the inverter boards than the one on the power board..
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Fuses begin with the letter "F". For example, F100.
                      Your 4 fuses circled in red.
                      • tw1ztid
                        • Jan 2012
                        • 36
                        #31
                        Thanks, never seen a fuse other than the glass looking ones.
                        All 4 read at .3, so they seem fine.
                        So far we're down to either
                        1) Diodes are bad and need replaced, casualties from when the Caps went bad?
                        2) Another (larger?) part of the power board is causing a false positive.
                        I'm leaning towards number one, like Mr. Bills situation, but I know to expect the unexpected.. I'll start off by removing one leg of each diode and checking for false positives. If they are, what do you recommend for being my first plan of action?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Remove them and test them out of circuit. Report your multimeter results for each one.
                          • tw1ztid
                            • Jan 2012
                            • 36
                            #33
                            ZD904 .02 and .02
                            ZD902 .05 and .05
                            Havin a bitchin time trying to get these things out.
                            Starting on removing the next two..
                            • tw1ztid
                              • Jan 2012
                              • 36
                              #34
                              After removing it, D925 now gives me .463 and no reading the other way. So it looks good after all
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                ZD904 .02 and .02
                                ZD902 .05 and .05
                                ZD904 and ZD902 are bad for sure.
                                Add fresh 60/40 solder to the joint first to help with thermal transfer.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  D925 is good. What about D912?
                                  BTW, there is no such thing as "no reading". If it reads "1" on the left hand side, that means "out of range" or "infinity".
                                  Remember a diode lets current one way and blocks the other way.
                                  Hmm, we get this on a daily basis now. Time to write another guide. See
                                  https://www.badcaps.net/forum/showpo...2&postcount=31
                                  • tw1ztid
                                    • Jan 2012
                                    • 36
                                    #37
                                    Ok, that's what I meant. So it's good.
                                    Edit: Checking D912
                                    • tw1ztid
                                      • Jan 2012
                                      • 36
                                      #38
                                      D912 is out of range, and .43
                                      it's good.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Okay, time to order parts. Remember tom66's suggestion and you might want to get 4 just in case they blow for some other reason. I'm guessing these diodes should be under $1 each?
                                        • tw1ztid
                                          • Jan 2012
                                          • 36
                                          #40
                                          I'll start searching for FR4007 thanks!
                                          • Bloopeta
                                            Phillips 58PUS7805/12 No Picture
                                            by Bloopeta
                                            Phillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
                                            From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
                                            When one is unplugged, I get half sceen, clear picture.
                                            With other unplugged, get half screen but with thin horizontal lines
                                            Any ideas? Or is it likely a bad panel?...
                                            03-10-2023, 02:08 PM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
