A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
Re: A guide to fixing/troubleshooting some common plasma TV problems
Series 1 only.
Remember, TV power MUST be off whenever you change any of these connectors.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Thank you busy student for your tech info... i would have them in mind. For now i just cleaned u pthe tv with a blower and no problem 2 days now. if this happens again i will reset all connectors its a time because the tv is out of guarantee so i wont mind destroy it.Comment
hi,new member here. have a lg moel 50pk540 . screen is all red but if I press menu button menu comes up ,rest of screen stays red .replaced logic board ,new board gave us a different set of symptoms.sent it back for warranty second replacement gives us no picture at all just a white dark glow . am I in the right track ?Comment
I'd suggest both your boards are bad, can you try with original?hi,new member here. have a lg moel 50pk540 . screen is all red but if I press menu button menu comes up ,rest of screen stays red .replaced logic board ,new board gave us a different set of symptoms.sent it back for warranty second replacement gives us no picture at all just a white dark glow . am I in the right track ?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Well, I'm not certain about your problem, but the very fact that the control board is changing the symptom should be a clue that those boards are faulty.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hey Tom,
I have a conundrum. I think this could use it's own thread, but I can't do that yet :p
I came into the possession of a Philips 53 inch (50PFP5332D7/32) plasma screen. The guy said it needed a $125 part, but after all the posts on here about the capacitors, I opened up the back of mine and, sure enough, the caps were popped on the power supply.
At this point I have replaced all the capacitors that were bad on the power supply, and a few extras for good measure. As a newbie at soldering, it took me awhile, but I didn't smear it onto the other circuits or soldering lines.
With all of the new capacitors on it now, the relays still click about once per second, so I figured it just needed time to charge up, but after 10 minutes or more, the relays were still clicking.
At this point I looked elsewhere on the other boards to find anything else. I see a possibly blown cap on one of the other boards, but I am wondering if there is perhaps something else wrong on the power supply as it won't even stop the relays. Could it be a blown fuse?
Thanks in advance.
Sincerely,
DerekComment
I recommend you follow the steps in this topic about isolating the Y-main (Y-sustain) and X-main (Z-sustain)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Unplugged the Ysus, kept the Zsus. Unplugged the Zsus, kept the Ysus. Still got the relay clicks.Comment
You may have main board fault.
See https://www.badcaps.net/forum/showpo...61&postcount=2Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I checked the Control Board, but how do I check the main board?Comment
Did the test patterns appear?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
No, the light just stays blue and the relays continue to click away very consistently.Comment
OK, can you get hold of some 100 to 470 ohm (any value between 100 ohm and 470 ohm is possible) resistors easily? You will need two.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I could probably order some online. Do you think it's a power board fault still or the main board?Comment
I am thinking main board or power supply right now with equal probability, I just need you to use the resistors to try and isolate it to one board or another. You could probably buy the resistors from somewhere like radioshack or online on digikey/ebay/etc.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have Lg plasma 50pc3dh tv that has no pic but has sound the screen blinks and jumps but never comes on I replaced 9 caps on the main board same thing when I disconnect the ysus & the zsus it does nothing I am disconnecting them separately?Comment
Your Y-buffer and Y-sus are bad-- common fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by alltvrepairsHi,
I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
Any one met this problem in the past?...10-08-2025, 07:34 AM - Loading...
