Question on Philips 42" Plasma
  • keico
    • Oct 2011
    • 52
    HDMI 1 stopped working
    Strange problem
    Last night was watching tv and turned off.
    Woke up and turned tv and cable on and saw message that said I needed a valid HDMI tv in order for HDMI cable box to work. This happened sporadically. The channel would come in and then go back to that message.
    I tried different HDMI cables, rebooting cable box, still same thing.
    I hooked up the cable box via the component hook up and worked perfect.
    My computer is hooked up via HDMI2 and it works great. When I switch it to HDMI1 the computer detects then undetects the TV.
    Finally I just left the PC in the HDMI2 and the cable box in the component.
    I also updated the firmware and still the same.
    HDMI1 is just not working.
    Do you think it could be the tuner board ??
      Re: Question on Philips 42" Plasma
      There's a HDMI receiver IC usually for both channels. It's possible ESD (electrostatic discharge) or EOS (electrical overstress) has damaged one of the channels. You can't readily buy these chips on the market (due to pointless HDCP restrictions), so the only fix is to replace the tuner board as a whole, assuming that chip is at fault.
      • tibimakai
        • Jan 2012
        • 3680
        these are the uprights
        http://www.encompassparts.com/products/?310430814601
        • keico
          • Oct 2011
          • 52
          Ok this TV makes me wonder if I should spend any more money.
          First one of the HDMI goes out.
          Now this morning after turning it on, went got some coffee come back, and the set is dead.
          No lights nothing, no clicks, no blinks.
          Took the back off and saw that the fuse was blown on the power board, replaced and it blew again.
          Do you think its worth the money to invest any more money
          • keico
            • Oct 2011
            • 52
            Does anyone have some advice to offer
            • keico
              • Oct 2011
              • 52
              Ok took out the power board and the fuse has this info "t8ah250vp"
              I ordered some in hoping that it would work.
              I also did some reading and saw that this is a hard fuse to find, but may just be the only problem.
              In my previous post I said I replaced the fuse, that is not true, what I did was use aluminum foil and when I turned it on some green led came on on the power board but they went off after a few seconds.
              Do you think I should dump any more money into this TV ??????????????
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #27
                One trick some TV technicians use is to insert a 60W or 100W filament lamp in series with the TV.
                If there is a short the lamp will stay lit, but if there is no short the lamp will brightly glow for a short time (while the main cap charges) and then go out or go dim.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #28
                  if you used aliminium foil as a fuse i would not be suprised if you have blown more parts on your board or even some of the tracks may of become open circuit it may be good to post some pics of the top and bottom of the power supply circuit board. have you know replaced with the correct fuse if so are any of the lights on the front of the set?
                  • keico
                    • Oct 2011
                    • 52
                    Had to order the fuses. Also pulled the power board for a much closer examination. I know it is not a definite way to verify damage but I do not see not one component that looks blown.
                    I took a bunch of pics and put them in an album.
                    Please have a look and tell me what you think
                    https://www.badcaps.net/forum/album.php?albumid=62
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #30
                      next to the fuse holder with the fuse missing there are 2 white tall resistors have you checked these it should say on them what ohm they should be?(i think theres also 1 to check by the 42 stamped on the heatsink) have you also re tested all the other fuses on the board since you removed the bad fuse?
                      picture 18 is that a red barrel fuse by the white connetors if so check this as well
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #31
                        "I took a bunch of pics and put them in an album.
                        Please have a look and tell me what you think"
                        I hope you are not easily offended but it is some time since I have had to look at so many fairly useless pictures. VR69 did well to pick out what he did
                        - we should have been able to read what it says on the sides of the resistors. Pictures to be any use for troubleshooting should look like this.
                        https://www.badcaps.net/forum/attach...1&d=1290283049
                        https://www.badcaps.net/forum/attach...7&d=1280167246
                        Fewer pictures better quality preferably posted as an attachments.
                        But that is only my opinion.
                        • keico
                          • Oct 2011
                          • 52
                          Not easily offended and appreciate your time.
                          Any closer with my camera and its to blurry.
                          Will try to see if I could get some better ones. Are you looking for the entire board or just pieces of it ??
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            Full Boards Straight on Top and Bottom please. Tests on the cement resistors and fuse are priority - A 60inch set was fixed by replacing these recently - for a couple of dollars.
                            • keico
                              • Oct 2011
                              • 52
                              Just wanted to give everyone an update. Fuses came in and I installed. put back together and TV is working again.
                              • Jojodugay
                                • Sep 2012
                                Picked up this TV and need some advice
                                I have done some research but am looking for advice on how to fix
                                I have read that the buffer boards go bad on them.
                                I have attached some pics
                                could anyone please take a look and tell me what they think
                                Hello Keico, what did you do to your tv can you tell me please! Because we have the same problem to my tv.. in what parts did you change? Please thank you.
                                • capron
                                  • Nov 2012
                                  Originally posted by tibimakai
                                  That part is no longer available.
                                  I also want to convert my Philips 42PF5321D/37 from a wall mount to a table top TV and have lost the parts.
                                  Encompass thinks that I can use
                                  http://www.encompassparts.com/item/6...611/Stand_Upri
                                  and
                                  http://www.encompassparts.com/item/6..._Returnable%29
                                  The stand upright doesn't list compatibility with my TV, but the base stand does.
                                  To further confuse things, I see that these parts are also listed
                                  http://www.encompassparts.com/item/7...and_Base_*Nla*
                                  http://www.encompassparts.com/item/6...621/Stand_Base
                                  I'm not sure which parts will work with my TV and most of them are out of stock anyway. Does anyone know of a source that has the parts (or compatible ones) I need in stock? Anyone want to sell me the stand from their old TV?
                                  • celiabrown
                                    Issue with Plasma Philips 37inch chassis FTL2.1
                                    by celiabrown
                                    Hello guys,
                                    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                    Can someone has any symptom like this ?
                                    Thanks​
                                    05-09-2024, 10:56 PM
                                  • Cooperr
                                    Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                    by Cooperr
                                    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                    10-21-2025, 01:11 PM
                                  • Sharpa
                                    Repair attempt Philips 55OLED804/12
                                    by Sharpa
                                    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                    The symptoms when bought: Philips logo appears then tv turns off
                                    Things tried so far:
                                    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                    11-22-2025, 08:30 AM
                                  • alro7779
                                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                    by alro7779
                                    Hello, guys!
                                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                    09-14-2025, 12:25 AM
                                  • G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                    by G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                    It does power up when pressing the power button.
                                    I already try the power button while plugin the plug with no result.
                                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                    Could this be an PSU or eMMC issue ?
                                    07-19-2025, 03:43 AM
