Flat line on Panasonic TX-29AD2DP
+ More Options
Posts
  • bbjunkie
    • Dec 2011
    • 301
    Just happened to mention to a guy at work that I was messing around with some TVs in my spare time and he offered me free for collection a big and rather heavy Panasonic TX-29AD2DP (a really nice 29" CRT in 4:3 format)
    He told me that it had developed a fault (a horizontal very bright line across the screen with no other picture.. I think it's called field collapse?) and that instead of getting it fixed he went out and bought a big 1080p plasma.
    Got it home, still in the car though!
    Won't be looking at this for a while, as I already have 4 in the "junk pile"
    Anyone come across this before? After some searching it has been suggested checking for dry joints on the scan coils & field output chip. So, i'll start with that and go from there. I've downloaded the service manual so will have some interesting bedtime reading
    Jim
  • berniedd
    • Mar 2007
    • 119
    Re: Flat line on Panasonic TX-29AD2DP
    The vertical scanning has failed. Suspect the vertical output IC or transistor. Also change the big electrolytic capacitors in and around that circuit. While it is possible, the vertical scanning yoke may also be suspect, but a failed yoke is not commonly seen. Also be aware that running the set, even briefly, with only a single horizontal line on the crt can permanently burn the phosphors on the screen. Turn down the brightness control to minimum if you have to test your repair, and don't run the set longer than you have to while in such a state.
    • rayrod81
      • Oct 2010
      • 205
      It was a common problem in Panasonic tube sets. Most of the time it was cold solder joint in the vertical deflection circuit or a bad vertical IC. The cap in the vertical deflection circuit may need to be replaced also. Very cheap and easy fix. Don't poke around too much with the TV turned on because there are high voltages in the horizontal section that can be pretty dangerous.
      • bbjunkie
        • Dec 2011
        • 301
        Ok, got the set into the workshop and the main board out (eventually) located I561 a TDA8175 which I touched up with fresh solder. I removed C563, a 470uF 35v electrolytic and C561, a 2200uF 35v electrolytic. Measuring ESR the 470uF measured 0.06 and the 2200uf measured 0.00 ohms
        I see there's a chinese supplier selling the TDA8175 for $4.00 while the only source here in the UK I can find is cricklewood and they are asking £18.00
        Does anyone have any cheaper reliable sources for these now rare IC's ?
        Depending on what you guys think of the 0.06 ohm ESR I may put it back together and test, if I have to order caps then im grounded until after Christmas as my only source tomorrow is Maplin who afaik dont stock low esr caps.
        Suggestions welcomed
        Attached for reference is the schematic for the section in question
        Jim
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Test the 2200uF cap with the ohms range on your multimeter - it could be shorted. If it doesn't registered as shorted put the caps back in and try the set again - the ESR on the 470uF cap looks normal.
          A working TV? How boring!
          • popeye
            • May 2011
            • 155
            Jim
            Change both caps check the 27 volt line if the ic has gone replace it then you are good to go simples.
            • bbjunkie
              • Dec 2011
              • 301
              Started higher dropped to about 15.4M ohms and kept falling slowly
              I'm away for Christmas so won't be looking at it again until Boxing day.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Definitely not shorted then.
                • bbjunkie
                  • Dec 2011
                  • 301
                  Got the caps re-fitted this afternoon, retouched the field output IC solder connections and I now have a picture. Won't hold my breath though.. the picture was flickering occasionally. Once I get the following sorted, I will leave it on for a few hours to see what happens.
                  Turns out there is very little sound from it - can barely hear something in the centre speaker and nothing from the left and right.
                  Suggestions welcome
                  Jim
                  • TrueSword88
                    Kogan - KALED65XU9220STB - Blue Vertical Line
                    by TrueSword88
                    Hi all.
                    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                    The line just happens to coincide with the end of COF and start of the next COF (attached).
                    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                    Hoping to fix...
                    05-05-2023, 04:28 PM
                  • almarhum
                    To fix laptop screen vertical line by working on its EDP cable
                    by almarhum
                    Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                    As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                    05-07-2024, 02:12 PM
                  • mrsith
                    Samsung UE58TU7100K - no picture, vertical line
                    by mrsith
                    Hi.
                    Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                    This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                    Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                    02-07-2023, 11:18 AM
                  • bdalkiran
                    55EC930V white vertical line appeared (need help)
                    by bdalkiran
                    Dear All,
                    I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                    Please advice how to proceed and what is the...
                    01-13-2023, 04:16 PM
                  • tmhobadcap
                    VIZIO M60-C3 Can the vertical line be fixed?
                    by tmhobadcap
                    I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
                    02-05-2023, 03:37 AM
