Please Help.... I have a 47pfl7422d and the screen is now dim on the left side ... i was told a bad slave inverter so i replaced it, still dim, i removed the lcd screen and looked at the bulbs, right side is bright and the left sides are dim as if not working at all, could someone please help as i dont want to take this tv in for repairs Thanks
phillips 47pfl7422d is dim on left side of lcd
Re: phillips 47pfl7422d is dim on left side of lcd
That indicate insufficient voltage out of the inverter. Check the input voltage and of course pictures help us help you. Attach the pictures using 'Manage Attachments'.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
i was looking at the 2 capacitors on the master and slave inverters and the new slaves capacitors look clean as where the old slave and masters look like they have opened up on the end and have had a blackish material ooze from them. Does this mean they are bad??Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes, they are bad. This is why we always ask for photos. Replace the bad capacitors with something like Panasonic FR or FM series from digikey or mouser.
If that is a 680uF 35V cap, this will work (assuming height and diameter are okay)
http://search.digikey.com/us/en/prod...2417-ND/613778Last edited by retiredcaps; 11-17-2011, 12:44 AM.--- begin sig file ---
--- end sig file ---Comment
And new caps will cost under $10, including shipping.
If you DO decide to buy a new board, perhaps someone here might be interested in the old boards.
Thanks to all in this tread,i fixed a same tv whit the same problem just reading hereComment
I've got the same problem (both caps pop'ed on the Slave but only one pop'ed on the Master). Do you think I can just replace the caps or is there potentially something else bad on the board too? Someone in the thread mentioned a ceramic fuse but I don't see it anywhere. What else should I check before I reinstall the inverter CCA's?
The capacitors are likely the only fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by StephenRight SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.05-29-2025, 10:35 AM
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by ravi_1617Hello to all ,
I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
on external VGA port image is perfect /normal , Attached image... -
by GjacksonHi all,
I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look... -
by valvashonFriend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
Thanks, Val
...Yesterday, 03:01 PM - Loading...
