Old git need help Goodmans LCD TV dead ..
  • selldoor
    Slow Learner
    • 7870
    Re: Old git need help Goodmans LCD TV dead ..
    Hi - Guess you are in UK? As Goodmans common here.
    Is This What your looking for
    http://www2.cricklewoodelectronics.c...roductid=21108
    Looks like £5 plus vat Inc Postage or you can collect if you know
    anyone near cricklewood. I live near a CPC but they dont seem to stock them - cant see them at maplins either
    Or there is this one on ebay (if you can wait for it) http://www.ebay.co.uk/itm/NCP1200-NC...item415961bca3
    • ceedy
      • Nov 2008
      • 76
      Cheers for the links, I had completely forgotten about Cricklewood, I used to get stuff from them , must be 25 years back !! in my Hifi building days.
      Got a couple of IC's and some fuses on order.
      thanks
      Chris
      • retiredcaps
        • Apr 2010
        • 9271
        Don't forget the caps. Capxon is about the worse brand of capacitors there is in the lcd world.
        --- begin sig file ---
        --- end sig file ---
        • ceedy
          • Nov 2008
          • 76
          finally got all the Caps odds sizes for most shops round here..
          But all recapped . new IC in socket.. new fuse ..
          whilst waiting, been round the board with meter .. looks like ZD101 is shorted . so another bit to get !
          A bit hard to see what ident is on there .. looks abit like Z208 ( or B ?) .. possibly a small p on the end ?
          Any clues ?
          thanks
          Chris
          • PlainBill
            • Feb 2009
            • 7034
            Any clues ?
            thanks
            Chris
            According to the schematic, ZD101 is a 1/2 watt 20 volt zener. Something like the 1N5250B should be suitable.
            PlainBill
            • ceedy
              • Nov 2008
              • 76
              #26
              i' ve found one 4748 diode here at home , would seem its a 22v though??
              any good ? or i'm off to do a wee bit more shopping??
              ( never had this problem with parts when i was working )
              C.
              • PlainBill
                • Feb 2009
                • 7034
                C.
                I'd suggest doing a little research. That zener is associated with the power FET in the SMPS. Off the top of my head, 22V is awfully close to 20V and 20V is a real handy number to pull out of the air. But the consequences of being wrong are pretty severe - lots of smoke and a smell of charred plastic.
                PlainBill
                • ceedy
                  • Nov 2008
                  • 76
                  #28
                  Any easy way to test the Mosfet while I'm waiting for bits .
                  Only got an old fluke 77.
                  C.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    For testing mosfets, I like to test for shorts. Measure the resistance between Gate-Source, Gate-Drain, and Drain-Source. Any reading under 30 ohms suggests it is shorted. If you are testing "in circuit", then remove the component and retest "out of circuit".
                    Others test mosfets like this ...
                    http://www.4qdtec.com/mostest.html
                    PS. I have an old Fluke 75 (purchased used).
                    • ceedy
                      • Nov 2008
                      • 76
                      #30
                      Test off board the resistance between
                      Gate-Source = NC
                      Gate-Drain = 2.4 ohm
                      Drain-Source = NC
                      Just getting a IRF840 ( seems a reasonable equiv ?) to replace it
                      thanks
                      chris
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Gate-Source = NC
                        Drain-Source = NC
                        thanks
                        chris
                        Yes.
                        PlainBill
                        • ceedy
                          • Nov 2008
                          • 76
                          #32
                          New mosFet new 20v zeners , new NCP 1200 , new fuse powered up .. flash-pop !!
                          Fuse gone. ?
                          Actually found another board on German Fleabay, but he won't send to me . I i've asked)
                          Chris
                          • Scenic
                            o.O
                            • Sep 2007
                            • 2640
                            Chris
                            If you really need it that badly, i could buy it and send it over to you if you pay for it + shipping.
                            I hate when you find the exact spare part you need, but the seller refuses to send it anywhere other than the country he lives in
                            Happened to me quite a few times already..
                            • ceedy
                              • Nov 2008
                              • 76
                              #34
                              Wow, that would be great ... would save me having to grow some more hair, just to pull out in frustration ?
                              the flea bay link is : http://www.ebay.de/itm/ws/eBayISAPI.dll?ViewItem&item=290583257669&ssPageName=ADME:X:AAQE:1123
                              thanks
                              Chris
                              • Scenic
                                o.O
                                • Sep 2007
                                • 2640
                                19.90eur + 5eur shipping.
                                cheapest shipping option to the UK (?) is DHL w/o tracking (8.90eur).
                                so that would end up as roughly 34eur/46usd/30gbp total.
                                If you have paypal, that would be the easiest option. I would want the money beforehand though, as i don't want to spend ~25eur on a PSU board I don't need because you decide to fix your own one in the end (had something like this happen before.. that's what you get for trying to help sometimes..)
                                I'd say further details via PM?
                                edit: looking through that guys shop, it's kinda suprising this inverter/PSU board is as cheap as it is (especially considering it's supposedly new and unused). The other prices in his shop are pretty ridiculous, like 55eur for a 7" portable DVD player display, a 15" laptop LCD for 100 or a LCD inverter for 70eur
                                • ceedy
                                  • Nov 2008
                                  • 76
                                  #36
                                  Great thanks, i'll hold off for a couple of days til next week.
                                  Just had to spend a lump on my car service/MOT .
                                  Also will give me a short while to have one last go at finding out the problem on this PSU is ..
                                  Speak soon thanks
                                  Chris
                                  PS any clue anyone ?
                                  • ceedy
                                    • Nov 2008
                                    • 76
                                    #37
                                    off work today, so having another go..
                                    R104 0.42 ohms is OC... not sure if I missed this first time .. or it was the last POP/flash?. redface:
                                    Tricky size , might have parallel up to get close ? got lots but nothing this low..
                                    LF104 coils = 1 ohm off board
                                    C.
                                    • LEECH666
                                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                      by LEECH666
                                      Good day ladies and gentleman!
                                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                      01-19-2024, 05:46 PM
                                    • double_DD
                                      How can I be sure that my EC chip is dead?
                                      by double_DD
                                      As the title suggests, how can I be sure that my EC chip is really dead?
                                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                      03-12-2025, 07:47 AM
                                    • disorder
                                      ps5 edm-033 dead after hdmi/usb ports destroyed
                                      by disorder
                                      hello guys,
                                      i need help to repair a edm-033 ps2
                                      history : as always hdmi port and usb ports destroyed after unplugged
                                      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                      so i changed it
                                      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                      i don't see any projection of liquid metal on pcb.
                                      01-14-2025, 12:48 PM
                                    • Beton
                                      Finding a dead short component
                                      by Beton
                                      Hi guys!
                                      I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                      So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                      I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                      I have a bench PSU and if I try to inject voltage the voltage...
                                      12-10-2021, 01:05 PM
                                    • zunasthegreat
                                      Chieftec GPS-450-AA with dead 20N60C3
                                      by zunasthegreat
                                      Hello everyone hope all doing well!
                                      I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                      09-01-2024, 07:12 PM
