Samsung LE32R88BD/ BN44-00155A
  • veaux
    • Sep 2014
    • 25
    • Mexico
    #181
    Re: Samsung LE32R88BD/ BN44-00155A
    GM folks, this thread is full of knowledge. I have the BN44-00192A which is apparently similar or even a drop in replacement of the one in this thread.
    Symptom: solid red stdby led. Tv is responsive to remote... The led blinks when I use it but that's all.
    I already replaced all the caps on the mainboard side, they were visually bad. But the problem is still here.... I'll look for that resistor next the the big cap on the primary.
    5vsb is present and I have a 4.3V ish PS_ON for a couple seconds when I use the power on button or the Power On button on the remote so I think the PSU never switches to high voltage.
    Will check that next week end.
      So the picture you showing is before the caps with bulging tops are replaced and all those bad brown conductive glues are removed? Do you get about 400VDC between the two legs of the main filter cap when it is turned on?
      • veaux
        • Sep 2014
        • 25
        • Mexico
        #183
        Hello budm, yes the photos are from before the caps replacement. I removed some of the glue, not all. I need to reopen the tv and finish the job. I'll check the 400V at that time.
        I will post my findings when done.
        • michael dranfield
          • Jan 2016
          • 232
          • England
          #184
          Actually the glue you refer to becomes hydroscopic and absorbs moisture from the atmosphere , it then acts like a resistor and passes current.
            It is also corrosive and will eat away the component leads and copper traces common problem since the 70's.
            • LPs1978
              • Jan 2016
              • 8
              • Italy
              #186
              I'm trying to fix my LE32RB86 LCD TV.
              I changed all caps on the power supply board but the TV still has problems.
              When the TV is cold it takes 20 minutes to start before correctly shown the image. In this 20 minutes what you can hear is just noise and the red led continusly blinking and the blu light under the samsung brand switching between on and off.
              What I understood is that if I heat the CPU board with an hairdryer the TV starts quite immediately.
              Do you have any idea about what I can check on the CPU board?
              Thanks,
              Luca
              • veaux
                • Sep 2014
                • 25
                • Mexico
                #187
                Alright, sorry for the delay. The main cap is at 175 V when the tv is on standby. When I try to power it on it doesn't change.
                I checked the RM801 resistor and it has no continuity (infinite ohm reading).
                As you'll see in the picture, there is a black trace bellow to blue capacitorCM818 apparently. I tried to remove the most glue I could. Kinda hard to do imho.
                So what else do you think is fried beside the resistor? What can I check?
                • michael dranfield
                  • Jan 2016
                  • 232
                  • England
                  #188
                  For slow start of the main board replace two surface mounted capacitors in the middle of the board , its the two that are larger than all the rest , from memory I think they are 1,000 uf but as I am at home now I dont have the cct ref numbers .
                    Check all these parts:
                    https://www.badcaps.net/forum/showpo...&postcount=169
                    • veaux
                      • Sep 2014
                      • 25
                      • Mexico
                      #190
                      unfortunately, I have no way to check capacitors (I should invest in one btw). How can I check the mosfets? Or, for the cost, I could replace them all maybe...
                        You can check the resistance between the Source pin and the Drain pin of the MOSFETs to see if it shows really low resistance first without removing them.
                        • LPs1978
                          • Jan 2016
                          • 8
                          • Italy
                          #192
                          Thanks,
                          Luca
                            Can we see the pictures of your main board? More likely you have bad SMD caps on the main board that the ESR will go down when heated up so the board function again.
                            Since it is not the same model as in this thread, you should start a new thread.
                            • veaux
                              • Sep 2014
                              • 25
                              • Mexico
                              #194
                              QM801 which is a FQPF5N50C from is Fairchild is apparently shorted. I have 1.5ohms between D-S, D-G and S-G.
                              The other one is apparently fine. I have no resistance reading (open circuit)
                                I would replace those parts as listed at this point.
                                • Loz2212
                                  • Jan 2016
                                  • 61
                                  • United Kingdom
                                  #196
                                  Hi guys,
                                  I have a LA-32R8BDD.. pinched it off my friend as he was about to wang it in the skip. The TV turns on very briefly and then shuts off all together.. Not even a standby light until I press the power button again.
                                  I'm pretty confident with a meter etc but could just do with someone pointing me in the right direction.
                                  No obvious swollen caps or burns on any of the boards. Metered out most of the small fuses and checked the VCC on the inverter which remains at 24v steady even when the screen goes off.
                                  Sorry if this sounds like a terrible explanation, I may require the odd prompt.
                                  Thank you
                                  • Loz2212
                                    • Jan 2016
                                    • 61
                                    • United Kingdom
                                    #197
                                    LE32R88BD*.. Apologies.
                                      Pictures of the boards used in your TV?
                                      BN44-00155A???/
                                      • Loz2212
                                        • Jan 2016
                                        • 61
                                        • United Kingdom
                                        #199
                                        Struggling to upload photos for some reason..
                                        Thanks for the response. The power supply is a BN44-00155A.
                                        Thank you.
                                        • Loz2212
                                          • Jan 2016
                                          • 61
                                          • United Kingdom
                                          #200
                                          Hope this is OK. Thanks
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
