Olevia 265-t12 - no place to turn but the Internet
  • HAHOMETP
    • Nov 2012
    • 155
    Re: Olevia 265-t12 - no place to turn but the Internet
    chcbearsfan, where are you physically located? I have a 265TFHD-T11 with a different problem:
    https://www.badcaps.net/forum/showthread.php?t=28953
    If you are local to me we can join efforts by swapping in known good parts for testing purposes since most likely our problems do not overlap.
    • chcbearsfan
      • Oct 2011
      • 32
      #62
      As an update to this, I have it fixed. I contacted the ebay seller and they sent me another inverter board and that fixed it. So now I have transformers to work with should another go bad.
      Ran into another issue with a misaligned ribbon cable, I started a new thread for that one. All in all I got it back in working condition.
      Oh, and I am in Indiana so not local to you, sorry.
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
