Vizio VU42LF Broken Screen
  • KTMLew
    • Sep 2011
    • 37
    Been doing some searching for a parts manual. Hoping to find what other TV brand panel might work? The VX prefix seems to be the prevalent listing.
    TV does come on and can see the input screen. There is a used panel on ebay that I want to know if it would work.
    http://cgi.ebay.com/ws/eBayISAPI.dll...=p5197.c0.m619
  • cadillacman
    • Feb 2011
    • 524
    Re: Vizio VU42LF Broken Screen
    good price, but i would be scared to install that being sold as "i guess it should work hope we diagnosed it right"
    busted screen tvs get junked man. Not worth the time and effort, sell the boards or keep them for use later when you find a dead set with bad boards but a good screen. Ive been saving the ccfls out of them too.
    • KTMLew
      • Sep 2011
      • 37
      I agree. Bought it planning on parting it out. But it's so pretty...would look great hanging on my wall!
      • truep
        • Aug 2010
        • 373
        Pull it apart and check the sticker on the back of the panel and see if it's the same panel number.
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • paqman
          Vizio M60-C3 black screen
          by paqman
          So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
          So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
          03-02-2024, 04:37 PM
