I have this Phlips 50PF9731D/37 the relay,(both of them)clicks and clicks without stopping,and the 5 volts is moving from zero to 5.3 volts.Found two 3300 microfarad caps bulged in the power board,havent changed yet because i just ordered,but i used a general purpose one to make a fast test,and the same symptom is on,,relays never stop clicking..all voltages are moving,,discconet the y sus,same,,any help please..
Philips 50PF9731D/37 relays clicks
by SharpaHello,
I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
The symptoms when bought: Philips logo appears then tv turns off
Things tried so far:
1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen... -
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by jason123Hi folks,
I'm suspecting the actual CCFL or EFL being bad, just not sure how to test, but would like to confirm.
TV clicks upon plugging in AC. When I press the PWR ON button, clicks again.
LED on the Main board comes on green (Assuming some diagnostics), Blue LED on the TCON comes on also when I turn the TV on, but turns off about 30 seconds later.
3V3 ST is on (3.26 V)
Standy 3.3 V (off) when I press power button goes to 0.16 V
12Vssb is 11.75 V (on), 0.18 V (0ff)
+12Voud is 13.8V (on) ~ 0V off
-12Voud is -12.4 V (On) ~0V... -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... - Loading...
