Sansui SV-2615 LCD
  • burntfingers
    • Jan 2011
    • 148
    Sansui SV-2615 LCD
    This set cuts off the screen, sound remains OK on that station but doesn't change to other stations.
    Needs to switch off and on again to bring picture [perfect picture].
    Takes longer to shut screen when it's cold, and less and less as it warms up.
    I checked the power board for d/js and used a computer fan to extract heat, to no avail.
  • burntfingers
    • Jan 2011
    • 148
    Re: Sansui SV-2615 LCD
    Could it be the inverter circuit?
    Do I need to replace the whole PS board?
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      I have seen this board in multiple sets now. This power board can be found in Polaroid, Memorex, Element. It may help to investigate more by searching Polaroid threads here on this site. Here are just a couple:
      https://www.badcaps.net/forum/showthread.php?t=12886
      https://www.badcaps.net/forum/showthread.php?t=10017
      • burntfingers
        • Jan 2011
        • 148
        Thank you.
        The set is right now holding its picture, since I connected a computer fan, as you see in the picture.
        There is a small cap nearby, but maybe the culprit is the chip - assuming the fan has located the problem area.
        • dumpystig
          • Jul 2011
          • 485
          I had a lot of probs on a recent project with dry joints, particularly around the Microprocessor on the Mainboard - the M/p ran quite hot and I found several SMD components below/adjacent to it needed to be re-flowed. I also installed a 50mm PC case fan on the TV back cover directly above the M/p which keeps the temp much lower and the set runs fine now.
          System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
          • burntfingers
            • Jan 2011
            • 148
            While blowing air on the IC, it's holding picture!
            • burntfingers
              • Jan 2011
              • 148
              This inverter IC could be the culprit, after all.
              I haven't got one at the moment.
              Just sent an email to Mastercare Sparescare, here in Johannesburg to see if they stock it.
              I have told the customer that the set is holding nicely while the fan is going - a low noise one, by the way.
              • dumpystig
                • Jul 2011
                • 485
                Looks like it's in a DIL socket too, should be a simple replacement
                • lti
                  • May 2011
                  • 2557
                  That appears to be a microcontroller. It may have a custom program stored in internal ROM, so a new chip might not work. It is strange that the chip is socketed.
                  This is the first time I have seen a Sansui TV that wasn't a CRT.
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    Did you physically feel this chip heating up?? Chips like these usually dont. The chip to the right of it is the PWM. I'm about to change one out in a board that I have. Does that Red LED on the left bottom corner of the power board ever turn on?
                    • burntfingers
                      • Jan 2011
                      • 148
                      Yes, when the screen turns black, the LED goes on/off at slow time.
                      The IC wasn't hot at all, nor could I detect an increase in temperature prior to the fault showing up.
                      • Dgtech
                        E. Technician
                        • Apr 2009
                        • 1462
                        • Steeler
                        This sounds similar to a problem I am having with one set.
                        Here is the thread with my set's failure:
                        https://www.badcaps.net/forum/showthread.php?t=13573
                        I got to find out what that LED is telling me. It's some type of diagnostic.
                        • burntfingers
                          • Jan 2011
                          • 148
                          I will be interested to know.
                          To me, the flickering LED meant no power going through the inverters.
                          By the way, I'm trying to get the faulty IC, but it's looking hard.
                          The boards are "Made in China" - stamped on them - and this particular set will not last very long, I'm sure!
                          I had to scrap two other set recently, because of no spares available!
                          • Dgtech
                            E. Technician
                            • Apr 2009
                            • 1462
                            • Steeler
                            Sometimes you can get more money for the parts than the whole set.
                            • Sir farts alot
                              • Jul 2011
                              • 3
                              Hi There did you Check on dry joints on the IC ? Sometimes loose dry joints could be the cause of similar problems
                              • burntfingers
                                • Jan 2011
                                • 148
                                Yes, I did.
                                That's basic, standard procedure.
                                I remove the IC from socket twice.
                                It has definitely to do with internal situation.
                                Anyway, the customer accepted a fan and took the set.
                                I had it working fine for 9 hours, so I imagine it will hold for a few months.
                                Besides, picture quality wasn't top anymore.
                                These sets do not help you to become popular...
                                • Hornnumb2
                                  Sansui sled4019 dim picture
                                  by Hornnumb2
                                  I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
                                  08-31-2025, 10:37 PM
                                • Hornnumb2
                                  by Hornnumb2
                                • Chrissygizmo
                                  Polaroid p49fn0038k backlights flashing split second
                                  by Chrissygizmo
                                  Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
                                  When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
                                  Any help would be greatly appreciated
                                  Thanks in advance
                                  11-10-2022, 10:30 AM
                                • crazycavan
                                  polaroid TQLHD24PR004 no power
                                  by crazycavan
                                  hi, my tv no longer starts like dead, no standby led
                                  motherboard : MS36639-ZC01-01
                                  panel : V236BJ1-P01
                                  flash spi: GD25Q64
                                  need usb firmware or to reprogram​
                                  05-05-2024, 08:40 AM
                                • snimmits
                                  Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                                  by snimmits
                                  Good afternoon,
                                  I have a Polaroid P43D300.
                                  It shipped with WiFi and Bluetooth.
                                  Two weeks ago, I ran through the first time installation.
                                  This did a full reset and went through the first time setup.
                                  Once complete, I went to settings > sound.
                                  selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                                  search completes and doesn't find any devices.
                                  I have tried everything I can think of.
                                  Can someone provide...
                                  03-01-2024, 09:26 AM
