LCD-TV repair
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    Digikey lists a JKL BF24438-33B, which ignites at 1400 volts and operates at 835 Volts, 5 mA. The 2500 volts you saw should be enough to get the CCFLs to ignite.
    PlainBill
    This will be simple enough to build, and be very handy when checking backlight panels in the future.
  • PlainBill
    replied
    Re: LCD-TV repair
    Originally posted by PowerAmpFreak
    Ok, I get it
    I think about building a small HV generator for CCFL testing purposes, what is the recommended operating voltage of a CCFL? And how much juice do I need to actually see something light up?
    PlainBill
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    Think of it this way - capacitance is directly proportional to the overlapped area of the plates and inversely proportional to the distance between the plates. In my misspent youth I remember unwrapping paper caps - the layers were many feet long. In most capacitors the spacing is measured in thousandths of an inch. How much capacitance is there between 2 pinheads more than a foot apart?
    PlainBill
    Ok, I get it
  • PlainBill
    replied
    Re: LCD-TV repair
    The panel has two HV wires, each on either side of the panel. I believe there are several CCFL or EEFL's connected in parallell, so why shouldn't a few light if one or more were bad? Or their wires were loose.
    It looks like one of the inputs has been disconnected so none of the lamps has contact with the HV supply.
    By the way, is it possible to make a capacitance measurement across the lamps?
    After the easter holiday I'll try to take some close pictures of the panel assembly and see if any of you might have a good idea how to get into the lamp compartment.
    PlainBill
  • alexanna
    replied
    Re: LCD-TV repair
    Email ccflwarehouse and find out exactly what's inside your panel, then try to find similar CCFLs to substitute .They may be trying to light but you are unable to see them through the dark LCD panel
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
  • Th3_uN1Qu3
    replied
    Re: LCD-TV repair
    Inside the panel, the connections to the lamps themselves.
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    No... but the wires going to the lamps can break, a few members here have found loose connections to otherwise good CCFLs.
    Ok, you mean inside the panel or the wires from inverter to panel?
  • Th3_uN1Qu3
    replied
    Re: LCD-TV repair
    Is there any protection inside the panel, fuse or something that my go open if there's a CCFL failure?
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    2.5kV is strike voltage, if that doesn't drop off at all before the inverter shuts down, then it's definitely failed CCFLs.
    I did the voltage measurements quick, since my oscilloscope probe is rated for 1500V peak but I was so curious so I give it a shot anyway.
    I see no additional load on mains when inverter goes on, I would expect the power consumption to raise a bit if the CCFL were properly loading the inverter, but I cannot see this. Which also tells something is bad in the panel.
    It feels the HV goes into an open circuit.
  • Th3_uN1Qu3
    replied
    Re: LCD-TV repair
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    Originally posted by cadiman
    I had failed ccfls on au-optronics panel (L/G) panel would light up for 2 seconds then shut down.
    I first found a bad mosfet on slave inverter. and repaired that and it was working( the inverter).
    The best thing I did is take another inverter board (one piece) powered off of 24vdc.
    I knew it was good and the backlights did the same thing (2 seconds to black).
    I then pulled the panel apart and found 3 bad ccfls.
    Took them from another panel and soldered them in (some solder in and some push in).
    Then I replaced them all (used) for color match.
    Yes, I had the TV all in pieces trying to get into the panel itself and look for bad CCFL's, but I was forced to stop when I found that Samsung used steel rivets to put the panel assembly together and that the panel could be bought as a complete module $$$$, so appearently this will be very hard to repair. I've confirmed that both HV outputs generate voltages about 2.5kV, so I can only see the panel as the problem right now.
  • cadiman
    replied
    Re: LCD-TV repair
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    Originally posted by Johnny P
    Pain in the ass.
    Hehe ... OK!
    Yes - you're right, this has taken far too much time already
  • Johnny P
    replied
    Re: LCD-TV repair
    Pain in the ass.
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    Right, as long as the values are the same. What a PITA!
    PITA? Hmm...
  • Johnny P
    replied
    Re: LCD-TV repair
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    There is no way to simulate the load of the lamps? Then the inverter board should remain on. Just an assumption mind you.
    It's a good idea, but the load of the lamps seems to be purely capacitive and I don't know if this actually could be substituted by a resistive load. But one thing I might try is to power up another backlight (on another tv) with this inverter and see what happens. Then I could swap it all around and power the problematic panel with a known good inverter.
  • Johnny P
    replied
    Re: LCD-TV repair
  • PowerAmpFreak
    replied
    Re: LCD-TV repair
    Thanks guys, but of course I have the datasheet for the '9882 but no schematics of the inverter.
  • Mirenia
    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
    by Mirenia
    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
    03-30-2025, 06:47 AM
  • orcic
    MASTER TL240 and new mainboard LW36BKC01
    by orcic
    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
    Now I have some doubts about how to connect the new mainboard to the old power supply.
    First of...
    05-12-2023, 08:10 AM
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
  • Devonavar
    Vizio M43-C1 - How closely do I need to match the mainboard number?
    by Devonavar
    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
    So, I've ruled out the PSU for now.
    The reboot loop...
    08-14-2022, 08:46 PM
  • Malva
    Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
    by Malva
    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
    Mainboard model: EAX65684604
    PCB marking: EBT62954607
    SPI chip: Winbond W25X20CLNIG Problem description:
    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
    • I bought another
    06-25-2025, 02:07 PM
