PHILIPS 42PFL5432D/37 Power Supply troubles
  • BobbyLeeThomas
    • Feb 2012
    • 7
    #61
    Re: PHILIPS 42PFL5432D/37 Power Supply troubles
    I have tested the pins from the power board to the main board and the pins going to both master and slave inverter boards. I don't see any capacitors that are bloated. Unfortunately, after two days of the tv running almost non stop, and always being plugged in, it has never malfunctioned. I am going to put it back together and wait for it to malfunction again. Thanks for all the help and I am sure I will be back.
    • tbuch
      • Jan 2012
      • 31
      #62
      BobbyLeeThomas,
      It sounds like you are having the same issue as PoteauPets
      • deng
        • india
        #63
        I had similar problem with my Philips 42" LCD TV, chirping sound was comming and the power on light (blue light) was flickering. i opend and replaced 3no.s capacitior 1500,35v which was little popped up at top BUT no use... then i found 2 Diodes (Zener Diodes) which was getting hot, (D902, D904) removed (original was P6KE120A) and replaced with 1N4007, after that TV is working fine.
        cost of Diode was 0.3USD
        • daza22
          • 4
          #64
          hi i have a 42pf9631d/10
          psu number is 310432842681 pdp psu2k6 the problem im having is it wont power up 6 short red blinks and 3 quick reds ive taken the back off there are no swollen caps or blown caps and i cant even track a replacement power board the model has ambilight on the sides ive unplugged everything apart from power so ive ruled them out any help from u guys would be great im new to this so please forgive me
          yours darren hill
          • daza22
            • 4
            #65
            • vinceroger69
              • Mar 2012
              • 6714
              #66
              dazza22 might be worth you starting a new thread as the other sets in this thread are lcd your looks like its a plasma? so might get more response by opening your own thread hope tom66 will see it hes good on plasmas
              well worth a read even if your caps look good can still be bad with high esr etc
              http://www.avsforum.com/t/716082/phi...hd-plasma/1470
              • daza22
                • 4
                #67
                yer thanks man ill do that just getting used to the forum cheers
                • C-los_530
                  • Jul 2013
                  • US
                  #68
                  I have the same problem. Tv turned off on me. No power or standby light. Any help? Same tv
                  • Ltank
                    • Jun 2013
                    • 776
                    5vdc stby is needed for the remote to turn on set and for the main board to tell the SMPS to turn on. After various check it will turn on the inverters for backlighting. if there are any problems then the main board will tell the power supply to turn off.
                    If you have 5 volts have meter ready to test the 12 or 15 vdc and 24vdc on supply. They may not be marked! Then you will need a schematic. There are feed back pins on SMPS that is used for control thus bypassing that board fr testing purposes only!!!!
                    Remove the plug rom the main board. Jumper a 200 ohm resistor from 5vdc to the on pin on the SMPS this replaces the comand from the main board. Does the supply stay on?
                    Do the same for tosurn on inverter 24vdc. Is there a short across the wired to the inverters? Sometimes if you disconnect a plug you remove a shored board plugged into the supply that causes it to shut down.
                    Hope this helps.
                    Ltank
                    • to-the-max
                      to-the-max
                      • Jan 2014
                      • U.S.A.
                      #70
                      I have a Phillips 42PFL5432D/37 and need a capacitor C955 it is a 2200mf 16v CapXon. The list of capacitors posted earlier no longer has a replacement available. Can anyone suggest a replacement? Online would be great, if not I live in Batesville, Indiana
                      • philliesfan30m
                        • Aug 2013
                        • 542
                        you can use a 25v 2200uf but here is a good replacement just check the height and size so that it will fit into the spot needed and not stick up too high or be too big of a diameter. shipping is usually cheaper at digikey if you use usps option. as to where if you order from mouser it is 4.99 and you don't have any options because that is the lowest.so if you need anything else i advise on getting what you need all in 1 order.
                        http://www.digikey.com/product-detai...402-ND/2433536
                        http://www.mouser.com/ProductDetail/...%2feQFgdLN4%3d
                        • dansifjim
                          • Mar 2014
                          • 3
                          • mexico
                          #72
                          perdonen me podrian decir cual es el valor de R942 que se encuentra en la fuente de tv
                          lcd philips modelo 42pfl5432D/37
                          esque la tv se ve normal pero se oye on chllido al encenderla
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4926
                            • New Zealand
                            #73
                            Look in the service manual, link was posted on a previous page in this thread. Also, please post in English....
                            -David VanHorn
                            • dansifjim
                              • Mar 2014
                              • 3
                              • mexico
                              #74
                              me perdonen Cual Decir podrian es el valor de R942 Que se ENCUENTRA en la fuente de tv
                              lcd philips Modelo 42pfl5432D/37
                              esque la televisión en sí ve normal, Pero sí oye en chllido al encenderla y mejor la apago
                              o algen me puede decir en donde puedo bajar el diagrama
                                @dansifjim:
                                http://elektrotanya.com/?q=showresul...oria=&kat2=all
                                • dsm482
                                  • Dec 2019
                                  • 39
                                  I got the same problem
                                  Repaired the board few years ago.
                                  TV ran fine.
                                  now lost all sound
                                  tested speakers
                                  put new main board same result.
                                  something makes me think its the power board.. there is nothing else left.
                                  but i will start my own thread
                                  sorry forum rules
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
                                    Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic
                                    Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic...
                                    11-06-2024, 03:47 AM
                                    by sam_sam_sam
                                    07-01-2024, 06:34 AM
                                  • Ifixstuff9
                                    Philips 42PFL5432D/37 power supply issue no 12v
                                    by Ifixstuff9
                                    I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                    After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                    05-02-2021, 09:29 PM
