Phillips 50" Plasma - 50PF7321D/37
  • PlainBill
    • Feb 2009
    • 7034
    Re: Phillips 50" Plasma - 50PF7321D/37
    Originally posted by WinRyder
    Hey Plainbill, i've tried, a new ssb, and a new power supply... still nothing where should i go from here? I've tried old psu with new ssb, new psu with old ssb, new/new. Also to add these parts i purchase were brand new not used or anything. I hope you have some advice for me cause this is getting expensive lol
    WinRyder
    There is very little information on Error 4. The manuals point out that by shorting a pair of pins on the SSB, the TV will ignore that error and boot, and "You might even get a picture". I just spent half an hour of my life (such as it is) digging through the block diagrams, and the I2C4 bus seems to go to the logic main board, part number LJ41-03703A. There are several of them available on eBay, starting at $25.00. But please understand that I am well outside my comfort zone on this.
    PlainBill
    • WinRyder
      • Feb 2011
      • 21
      #42
      I just found that there was a update for this plasma that is suppose to fix the 4-flashing red light, so I gave it a try just now, well it doesn't flash anymore and the front led is green... but still nothing so far.
      WinRyder
      • WinRyder
        • Feb 2011
        • 21
        #43
        • PlainBill
          • Feb 2009
          • 7034
          I'm not sure that it will actually take the update without completing the startup process. I'd check the thumb drive and see if the file is still there; as I recall, it deletes the file as part of the upgrade.
          PlainBill
          • WinRyder
            • Feb 2011
            • 21
            #45
            its still there, are you sure it deletes the file once its done? Because the led is still solid green but just no picture and that's without the usb in. I'm going to try connecting something to the AV1 ports and see if it brings it up, i will post back shortly.
            WinRyder
            • PlainBill
              • Feb 2009
              • 7034
              WinRyder
              Well, let's say that the last time I did a firmware upgrade, it deleted the file. To me that was a sensible precaution, but who knows if they decided to change it.
              PlainBill
              • WinRyder
                • Feb 2011
                • 21
                #47
                on the logic board, there is a button SW2000, what is that? I've been trying to find information on it but sadly no luck, I was wondering if there was a way to reset the logic board or something cause it seems now when i turn it on, the two led's on the ssb stay one, the led on the psu still starts to flash after it goes through the steps of starting the unit (still the two leds on the ssb are lit now) and the front led is solid green and doesn't flash, then the led on the logic, goes off and then a click sound(most likely protection mode).
                • PlainBill
                  • Feb 2009
                  • 7034
                  That button is used to step through various test patterns when the main logic board is put into test mode by installing a push-on jumper. What is the model number of the plasma panel. It'll appear on a white label on the panel itself. Then Google the model number followed by ' service manual'.
                  PlainBill
                  • WinRyder
                    • Feb 2011
                    • 21
                    #49
                    Hi everyone my name is Jason, and I'm in need of help with this plasma tv i bought the other day. I've read though one forum on here that was created by PlainBill cause he had the same PSU but not the rest of the unit was. But sadly my repair training is limited (College got rid of the program...) Well I opened it up, took out the PS and looked at it and found 4 blown caps under a heat-sink (agrees with Bill on the crappy design) rated at 470uf 35v, easy i thought i have those on hand, removed the old ones, and replaced with new ones that we recently purchased from radio shack. put it all back in and turned it on and still nothing. Relay clicks twice (green light) and blinks red several times. I thought testing each other one on the board, but wanted to know if anyone has any info or idea what else could be the problem. I may not have pictures right now but I can find a picture online and circle on it where the bad ones were if need be.
                    Chassis # EP1.1U AA
                    MODEL# 50PF7321D/37
                    PSU # LJ44-00125A
                    heres my first post
                    • PlainBill
                      • Feb 2009
                      • 7034
                      heres my first post
                      Not helpful. I'm looking for the part number of the plasma panel. An example would be S50HW-YD01.
                      PlainBill
                      • PhillyPilot
                        • Sep 2012
                        • 4
                        Hi Guys, I hope you don't mind but I wanted to ask a quick question about my TV. It is this exact model. I bought it new back in 2007. Almost a year later I started having this problem:
                        While watching TV at very random times the picture goes black. It seems to still have back lighting and sound. Not sure if this will help but when it happens all I have to do is smack the back of the TV and the picture comes back. Also sometime I get the rainbow of vertical colored lines just before it blacks out. I have not had a chance to check for any bad caps yet but will do so soon. Just wanted to see if you had any ideas.
                        Thank you for any help!
                        • ZnsaneRyder
                          • Oct 2015
                          • 88
                          • Merica
                          #52
                          Hello folks.
                          I have replaced faulty capacitors and got the set to come on - ONLY TWICE, not it is clicking the relays and going from green to red repeatedly. I also noticed green blue sparkling pixels in one line when the set was working. Do you think it needs more capacitors replaced, or did the buffer just die on me after fixing the set?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #53
                            Originally posted by ZnsaneRyder
                            Hello folks.
                            Pictures please.
                            • ZnsaneRyder
                              • Oct 2015
                              • 88
                              • Merica
                              #54
                              I don't have a camera at the shop, but the board looks like the other ones I search for online. I can't get a pic of the sparklies, it won't come on anymore.
                              • ZnsaneRyder
                                • Oct 2015
                                • 88
                                • Merica
                                #55
                                50pf7321d/37 solved
                                THE TV IS UP AND RUNNING!!!!!
                                This thing was a capacitor nightmare. I literally replaced a heaping handful of capacitors. MOST WERE NOT SWELLED!!! The only ones I did not replace were 470uf 315V SAMXON, 680uf 100V SAMXON, and 270uf 450V SAMWHA
                                The Power Supply has the infamous SAMXON GREEN GF caps and SAMXON BLACK KM junk.
                                The GREEN GF caps were the WORST. Almost ALL of them bad, mostly HIGH ESR (over 15ohms) but some also failed capacitance. I replaced as LOW as 1uf, 22, 33, 47 and 100uf!!! I upgraded anything 1000uf and more to 2200uf 25V Nichicon, even the 10V caps. I also replaced a 100uf, 160V cap that read only (77uf) to a 220uf, 220V RUBYCON, which drastically shortened the startup time for the plasma to come on.
                                I usually don't pay much mind to the smaller caps, but now I will.
                                I have always known the SAMXON GF caps were junk, but I didn't know they were THAT BAD. From now on I will replace ALL GF caps!
                                On the X, and Y and Lower buffer boards, all use SAMWHA caps, and they are ok, it's JUST the POWER SUPPLY that uses SAMXON!
                                I still have the blue/green sparkles, but not near as noticeable after the repair. All the buffer chips cool to the touch.
                                • Uranium-235
                                  Phillips 50PF7321D/37 Plasma slow reboot
                                  by Uranium-235
                                  Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
                                  12-27-2021, 09:14 PM
                                • ArMaaN376
                                  Samsung PS51E550 Plasma TV
                                  by ArMaaN376
                                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                  Opened TV cover & observed foll
                                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                  How to confirm Y -Buffer board...
                                  06-19-2024, 04:05 AM
                                • jm1234
                                  Panasonic plasma TX-P42ST50 - 6 blinks
                                  by jm1234
                                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                  I checked that board for any obvious faults...
                                  05-22-2024, 06:59 AM
                                • KYBOSH
                                  Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                  by KYBOSH
                                  Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                  No picture but you hear the TV static (white noise) playing loud and clear.
                                  The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                  But it seems they didn't get too far and just left it.
                                  When I first took a look I was amazed at how pristine the inside looked.
                                  Its as if the TV had been in a time capsule.
                                  Caps looked like they were just pulled off the self.
                                  Copper coils had no sign of corrosion on...
                                  02-01-2023, 11:10 PM
                                • alltvrepairs
                                  Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                  by alltvrepairs
                                  I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                  I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                  Any one met this problem in the past?...
                                  10-08-2025, 07:34 AM
