Phillips 50" Plasma - 50PF7321D/37
  • WinRyder
    • Feb 2011
    • 21
    Hi everyone my name is Jason, and I'm in need of help with this plasma tv i bought the other day. I've read though one forum on here that was created by PlainBill cause he had the same PSU but not the rest of the unit was. But sadly my repair training is limited (College got rid of the program...) Well I opened it up, took out the PS and looked at it and found 4 blown caps under a heat-sink (agrees with Bill on the crappy design) rated at 470uf 35v, easy i thought i have those on hand, removed the old ones, and replaced with new ones that we recently purchased from radio shack. put it all back in and turned it on and still nothing. Relay clicks twice (green light) and blinks red several times. I thought testing each other one on the board, but wanted to know if anyone has any info or idea what else could be the problem. I may not have pictures right now but I can find a picture online and circle on it where the bad ones were if need be.
    Chassis # EP1.1U AA
    MODEL# 50PF7321D/37
    PSU # LJ44-00125A
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Phillips 50" Plasma - 50PF7321D/37
    Radio Shack does not sell low ESR caps which are required in SMPS application. They sell general purpose caps.
    A list of high quality low ESR can be found at
    https://www.badcaps.net/forum/showthread.php?t=2280
    --- begin sig file ---
    --- end sig file ---
    • WinRyder
      • Feb 2011
      • 21
      So if i replace the caps with these will it work? Is that what your saying?
      • thelmores
        • Feb 2011
        • 17
        I have access to the service manual if it helps any......., will have time later this evening to post parts if you need.......
        If you need something, try to be as specific as possible.
        • WinRyder
          • Feb 2011
          • 21
          Well i'm central time, its 1:54pm right now what time do you think you would be back on? Also i'm looking on the site(s) he listed for parts, alot to choose from...
          but sure we can talk, i really want to get this working.
          • thelmores
            • Feb 2011
            • 17
            While you certainly want low ESR caps, I doubt that using general purpose caps would keep the TV from coming on.....
            Short term, they would probably work, long term you would want to put some good caps in.......
            • WinRyder
              • Feb 2011
              • 21
              ok understandable, but in the long run it still didn't work lol
              - the caps i put in it first -
              • PlainBill
                • Feb 2009
                • 7034
                Chassis # EP1.1U AA
                MODEL# 50PF7321D/37
                PSU # LJ44-00125A
                How many blinks? The service manual is on Scribd. Page 25 lists the blink codes for when it goes into protection.
                The first step is to replace the caps with good quality low ESR caps, then (if necessary), continue from there.
                PlainBill
                • WinRyder
                  • Feb 2011
                  • 21
                  Ok out of the list of different companies, which should i get that are rated at 470uf 35v, i've only found (https://www.badcaps.net/store/produc...roducts_id=114)
                  • thelmores
                    • Feb 2011
                    • 17
                    here is another option......
                    http://www.mouser.com/ProductDetail/...DM6OpFSYm78%3d
                    • WinRyder
                      • Feb 2011
                      • 21
                      would it be a good idea to replace all of the caps with Low ESR?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        It's not a bad idea, but there probably are a lot of caps. What I would suggest is examining the supply carefully for any other bulging caps. Then replace the caps that failed with good quality low ESR caps (I prefer Panasonic FR, FM, or FC) and see if the power supply works. If it does, then make a decision on replacing the rest of them.
                        PlainBill
                        • WinRyder
                          • Feb 2011
                          • 21
                          Ok, changed out the caps with the ones recommended, still nothing... I also tested the the other caps and all are fine. I've read from page 25 and down on the service manual and I don't understand 100% the procedure that needs to happen to let me know what the code is. Am I suppose to look at the front of the tv in the bottom left hand corner, or on the back where the psu is located?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Error codes can be read three ways. One way is with an interface called Compair? that plugs into the service connector on the back. A second way is via the blink codes - the flashing red LED. The third is on the screen itself. Somewhere in the manual it describes shorting a pair of solder pads on the SSB to force the set into displaying blink codes.
                            PlainBill
                            • WinRyder
                              • Feb 2011
                              • 21
                              PlainBill
                              Way one - not able to do
                              Way two - the flashing red led on the front of the tv basically goes through this procedure. When plugged in you hear two clicks from the psu (guessing its the relay at the same time the led is green. After about a few seconds you will notice the screen attempt to come on (looks like a slight fuzzy flash, best way to describe it) then you hear one more click of the psu, and the green led turns off and then the led switches to red and flashes 4 times *pauses* flashes 4 time *pauses* flashes 4 times and repeats and repeats. At this time i'm unable to turn off the tv via power button or remote
                              Way three - nothing appears on the screen
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Exactly - protect mode, Error 4. There is a lot of technical discussion on pages 25 and 26, but there are two approaches to take AFTER performing some preliminary tests.
                                The first preliminary test is the 12V supply - does it rise to a full 12 volts? If it does, you can either try checking the Small Signal Board (SSB), or just replace it. And THAT decision depends on your troubleshooting skills. I do note that the SSB is available on eBay for as little as $70, including one from a seller with 99.8% positive feedback.
                                Things to check on the SSB are the SMD fuses, the 3.3 and 2.5 volt supplies, and I2C bus 4. I'll be honest, if I had the TV on my bench I would at least determine where I2C bus 4 runs. There IS a distinct possibility that it runs to an IC that is unobtainable, or contains firmware.
                                PlainBill
                                • WinRyder
                                  • Feb 2011
                                  • 21
                                  on the psu there is a spot that says 12V ssb and underneath that is a 5Vstb, after looking more at the board there are others ones, like D3V3, D5V, Va, 5Vsw, GND_SSP, 8V6
                                  which of these should i test?
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    12V ssb. SSB = ssb = small signal board. Well, checking all of them would be a good idea.
                                    The DC-DC converter in the upper left corner of the SSB takes the 12V ssb from the power supply and converts it to 3.3, 2.5, and possibly other voltages used on the SSB. Without those voltages the I2C bus (and most of the other circuitry on the SSB) would not work.
                                    The objective is to have a high level of confidence that if you buy an SSB it will fix the problem.
                                    PlainBill
                                    • WinRyder
                                      • Feb 2011
                                      • 21
                                      ok on the psu the, 12V ssb it get 0.03V and the 5Vstb gets 5.34V, please note this is from the psu so is it still the psu? at the way things are looking, the psu is still shot... or at least the 12V ssb on the psu and i did trace the wires for the 12V ssb to the ssb and still 0.03... any ideas now or should i just buy a new psu from ebay?
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Not yet. First of all, did you do the test while the TV was trying to turn on?
                                        Test sequence:
                                        Unplug the TV until the red light stops flashing.
                                        Plug the TV in.
                                        Connect the DMM to measure the 12V SSB output of the power supply - it should be 0 volts. Have someone turn the TV on. Note the voltage.
                                        If it rises to 12V the 12V ssb section of the power supply is good.
                                        If it rises to anywhere between 4 to 10 volts there is a problem with the SSB.
                                        If it doesn't rise at all, the power supply is PROBABLY bad.
                                        Buried somewhere in the service manual is a section discussing the DC-DC converter section of the SSB. The short story is it uses several mosfet switches instead of diodes to handle the DC-DC converter. This is a known problem, and repairing the SSB requires replacing three ICs; total cost under $10, the parts are available from Digikey. Check the parts list in the service manual, do not order the parts listed in the schematic. The parts list lists upgraded parts.
                                        PlainBill
                                        • Uranium-235
                                          Phillips 50PF7321D/37 Plasma slow reboot
                                          by Uranium-235
                                          Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
                                          12-27-2021, 09:14 PM
                                        • ArMaaN376
                                          Samsung PS51E550 Plasma TV
                                          by ArMaaN376
                                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                          Opened TV cover & observed foll
                                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                          How to confirm Y -Buffer board...
                                          06-19-2024, 04:05 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • alltvrepairs
                                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                          by alltvrepairs
                                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                          Any one met this problem in the past?...
                                          10-08-2025, 07:34 AM
