Re: Vizio VW42LFHDTV10...Brother Mikes TV...
Well... its 100% not the power supply. Now when I plug the tv in I get a steady amber light and when I turn it on a steady white. Gotta wait for the main board now.
stefnopolis...yours is a crap shoot at best...and likely will not fix your set. The forum and this thread are pretty clear on this...repairs are done with the suggested help and your thorough checking of readings and components in a stepwise process. I know its frustrating at times, but substituting parts for knowledge is not the way to go.
Here are the strongest fix suggestions thread has for you. If you are having trouble doing these, enlist the help of a local tech .
No 1... thoroughly check the p/s, and all the voltages across all the boards...
No 2... check the inverter boards and their IC's readings
No 3 ... check all the LDO's on the mainboard
Good Luck !Leave a comment:
Thanks for the quick reply guys. After reading for awhile...(not this site or post) I decided to trial and error it and start with the mainboard. The situation is.. when plugged in, black screen. Turn on and amber light comes on. No sound, no picture, black screen only. Thanks again for in stock info. Once again, I have already ordered the main board I previosly posted and will try it out. Hopefully it worksIf not I will return it and try what Kingofcoins has done and go from there.------ I did see that the board has an alternate part number as well.... man i hope the board i ordered works!! No i have not checked out the inverters. Wouldnt know what to look for to be honest. There was no swelling on any caps and I am replacing the 6.3A fuse just to be safe so.... ill stay in touch
Are you sure that the problem is in the Mainboard? Were the inverters checked? That's where my problem was at on this set -bad inverter driver chip. I'm just curious. Do you have sound and no picture?Leave a comment:
I looked on the web and found three sites right off the bat selling your board and in stock, All I did was type in 3642-0502-0150 on the dogpile.com search page.
Also the sub that I found for your board was 3642-0502-0395 with Serial number beginning with: LSPBYDJ
So there is a chance that the board you bought might not work for you.Leave a comment:
I really hope someone is still reading this out there. I have the same model TV and black screen problem but unfortunately found this forum a little too lateSo here is what is going on that I need a little help with... I opened her up and found my main board number to be 3642-0502-0150. I looked for a mainboard that matched but nobody had one in stock. So I decided to order the 3642-0472-0150. My logic was that since they are the same model Television, then they should take the same mainboards. So my question is.. would this swap work? Are they compatible? I receive the new mainboard tomorrow but would like to know if anyone has done something similar. ... Oh by the way, called Vizio to ask this question and wasted like 2 1/2 hours of my life.
This is a good thread! Very informative and you guys are very helpful. I have a I have a Visio E42VO and i'm excited about getting it fixed myself, just based of what i'm learning here.Leave a comment:
Thanks for the reply King. I will be moving to Penn Hills (Pittsburgh 15235) next weekend. So now I'm in your hood!
It's nice to be back in da Burgh!!
GO PENS!!!Leave a comment:
Re: Vizio VW42LFHDTV10...less get 'er dun !
DGtech and Dossman...
My set has been running well for sometime now, so I hope this will help get you two get it done as well. If you have a Vizio VW42LFHD model this thread has all the gyrations done for a fix. You may have some missing 'as built' components on mainboard as mine did, but it should be pretty close to that I show in the Post #1 pics.
...> Post # 95 gives the this thread fix summary to follow (yes this is here at this thread...see reply #95)..
More on your specific questions....
...>Post # 70 gives the most applicable meter readings on board for the LDO's. Although I tried reading these in several other ways, including external test circuits, this way gave the most discernable good/bad results.
...>Post #75 discusses the best Digikey replacement I used for any of the AMC1117 LDOs' like U2, U7, U8, U33.....it is digikey's 497-1229-1-ND
...>Post # 77 shows closeup of my U7 and U33 LDO's before replacement. These components are 3 leg+ tab SOT-223 packages not 8 legged IC's. And yes use chip-quik, just be sure the pads are cleaned to level, flux and make very sure the component is perfectly aligned on the pads before you touch that 1st leg with solder. If you have touched two or more legs and chip is too far off-center its too late, and the re-do is a real b..ch to do.
Re: Vizio VW42LFHDTV10...Brother Mikes TV...mainboard woes
Did you ever fix this TV, Dossman. I just bought one of the same exact model as yours. I will not be working on it until after I move into my new house and set up my shop. I have a feeling these boards will be different than those of the previous set of this thread. That may be the reason why you may not have found that same chip. If you are still working on this set, post some pictures of the boards.Leave a comment:
Lecture time. To locate them on Digikey, enter the keyword Voltage Regulator and click Go (or Search Again). Under Integrated Circuits (ICs) click on PMIC - Voltage Regulators - Linear (34,840 items) Check the box next to In Stock and under Regulator Topology click on Positive Fixed, under voltage select 1.8 Volts Click on Apply filters. Scroll to the right, under Number of Regulators select 1, under Mounting Type select Surface Mount, and under Supplier Device Package select SOT223-3. Scroll back to the left and click on Apply filters. Under Current Limit select 1.1A , and Apply filters
PlainBillLeave a comment:
Can't locate that U9 chip anywhere, in the manual it's listed as a AP1117E18LA but that does nothing on Digikey.Leave a comment:
Re: Vizio VW42LFHDTV10...Brother Mikes TV...power checks
No need to disconnect...but check your p/s output and the inverter and main board inputs when led is amber, and then again when it kicks up to white to see if all is well.Leave a comment:
Al...we did clear the power supply, see my post #7, have 5v standby then 12 and 24V comes on when kicked up.
BTW...> the replacement inverters should be here by Sat. I intend to test/compare them side by side with mine before I ever try them out on the set, and report back here. If you have suggestions on what all to test on these boards out of circuit please advise.
I have this sinking feeling though that something else is bad either on the mainboard or on the T-con panel.Leave a comment:
Thanks, I was able to download the PDF from there.Leave a comment:
Re: Vizio VW42LFHDTV10...Brother Mikes TV...>SUCCESS !!!
Hey look what I didwith YOUR help
Put in the two new LDO Voltage Regulators at U7 and U33, and 5 more 220uf caps near them on mainboard...I kept thinking it won't work, it won't work, .. and viola, it DID !
Stay tuned..> I'll get a review summary posted when time permits, pic....
AWESOME!!!Leave a comment:
Re: Vizio VW42LFHDTV10...Brother Mikes TV...Final Report
I replaced 8 more of the main-board caps that had moderately high ESR's on principle that the Taicon's, series VT & VZ are not the best..that makes 18 total, mostly 200uf x 25v replaced on this board
Now a very happy Brother Mike reports that he thinks TV looks and sounds 'better than new'.
If you need help with a Vizio that's not a 42 inch LCD, please search the forum or start a new thread.
Again Thanks to All !Leave a comment:
On reviewing the manual, I especially liked the 'BOLLOCK DIAGRAM' - anyone with a grasp of British English will understand why this is so important when attempting to debug a TV that's balls to the wall!
Chris...Leave a comment:
that site doesn't seem to like any proper browser..
doesn't show a download link at all in Opera (plus totally messed up layout).. works fine in IE.. go figure
same file reuploaded to my webspace:
I'm working on a visio VX42LHDTV10A but I can't seem to download the service manual from this link.Leave a comment:
by Steph.henHi all, a newby question about a bridge rectifier I'm trying to identify.
I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?... -
by mpn78Hello
My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
Thanks.... -
by EasyGoing1I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier... -
Assuming...7 Photos -
by Ross KohlerHi,
I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
- There's no sign of any attempt to power on when pushing the power button.
- No PSON signal is reaching the 24-pin ATX connector.
- The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
- The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
- If I pull the Super IO S_SLPS#_R pin... - Loading...
