Vizio VW42LFHDTV10...Brother Mikes TV...
  • Spetznazer
    replied
    Re: Vizio VW42LFHDTV10...Brother Mikes TV...
    Thank you Bill for the effort to help. I decide to heat up the board with heat gun to see if it will lead me somewhere but with no luck. Set acts the same way. i downloaded service manual that says it is for the same model. Not much of info there for me but I found troubleshoot diagram for DC-DC converter so I went through checking Volts again. In a manual it says that the voltage on a pin2 of U5 must be about +1.8V (which is 1.94) also it says that pin2 of U8 also must be about +1.8v where it is about 3.3V. Either manual is wrong or board was revised and changed after manual was written. I went trough the diagram and checked all pins it was mentioned and got right data except that pin1(PWON) of J7 connector from board to PS was 4.6V and not up to 3V as in manual but that can be O'k right?.
  • PlainBill
    replied
    Originally posted by Spetznazer
    Thank you Bill for a quick reply. Sorry I was wrong with which ADO is adjustable and which is not. All ADOs I assumed are adjustable have pin1 ON A BOARD marked as "adj" that's where my misinterpretation came from. Thanks for correcting me. So I took two independent tests again with two different testers. And yes I failed to check voltage on a pin1 of U5. Results are:
    ADO____PIN1______PIN2______PIN3
    U4.........0.............3.26..........5.04.......17-33L
    U5.........0.69.........1.93..........3.26.......AMC1117
    U6.........0.............3.28..........5.04.......17-33L
    U7.........0.............1.81..........3.26.......17-18L
    U8.........0.............3.26..........5.01.......17-33L
    U9.........0.............1.80..........3.26.......17-18L
    U10.......0.............1.80..........3.26.......17-18L
    U16.......0.............2.48..........5.01.......17-25L
    DU2.......0.............3.27..........4.99.......17-33L
    DU3.......0.............2.48..........4.99........17-25L
    DU4.......0.............1.23..........3.29.......AMC1117
    As I understand U5 and DU4 are O'k since the drop between pin1 and pin2 is about 1.25V on both. Well it makes it more difficult. All caps on mainboard look good without any sign of failure, but I am afraid that it is not a proof of that they are good. Also there is a lot of other chips on board that may fail. Any ideas on a data I already have?
    P.S. Hey Bill is that Diamond Head on a background of your avatar?
    P.S.S. I forgot to mention the TV set is VIZIO GV42L.
    If the voltage regulators are good, here is very little that can be done to repair these board without schematics and the proper test setup. At this point I would say your only option is to replace the main board.
    Yes. And of course, the beach is Waikiki Beach.
    PlainBill
  • Spetznazer
    replied
  • PlainBill
    replied
    Hi all, my first post here. I found Badcaps.net pretty informative and helpful with my other repair of VIZIO crap.
    So I've got another fixer-uper. Symptoms are similar: when I press ON button set turns on (with click), LED changes color to white, blue screen appears with NO SIGNAL sign(obviously inverters are good), 2 sec after screen turns black and LED to ambient and after 4-5 sec set turns off (I hear click). I am able to turn it in by pressing ON button again. I took some measurements when set was able to be on(turned it on several hundreds times). It seems like PS is Ok, all caps looks good no bulging or burned spots on board. Huge cap's readings are 160V when not turned on and around 400V when on. PS feeds 5.2V, 11.8V and 24.4V to main board and inverters respectively. Readings of ADOs are as follow:
    (I used this method of measuring - black goes to GROUND at screw hole, red goes to the pin in 3-2-1 order)
    ADO# Pin 3 Pin 2 Pin 1 Type Model
    U4 5.05 3.27 0 adj 17-33L 6E1L
    U5 3.27 1.94 0 adj AMC1117 F0615J
    U6 5.07 3.29 0 ADJ 17-33L 6E1L
    U7 3.28 1.82 0 FIX 17-18L 6E5L
    U8 5.01 3.28 0 ADJ 17-33L 6E1L
    U9 3.27 1.81 0 FIX 17-18L 6E5L
    U10 3.28 1.81 0 FIX 17-18L 6E5L
    U16 5.02 2.25 0 ADJ 17-25L 6D1L
    DU2 5.01 3.29 0 ADJ 17-33L 6E1L
    DU3 5.01 2.49 0 ADJ 17-25L 6D1L
    DU4 3.31 1.24 0 ADJ AMC1117 F0615J
    I am not too deep with electronics but learning fast. Did I have to measure voltage between pin 2 and 3 also?
    No, but there are a number of problems with your chart. First, for milleniums humand have counted 1-2-3 etc. Some of us have the habit ingrained. When checking the voltage of an LDO regulator the first pin is the Gnd / Adj pin, the second the output, the third the input. The second problem is you have misidentified a number of the regulators. Some of the numbers do not make sense; I'm not sure if you took a short cut, or there is a problem with your meter.
    Rather than change the chart to a more conventional layout, here are some problems.
    U4 5.05 3.27 0 Fix 17-33L 6E1L (1)
    U5 3.27 1.94 0 adj AMC1117 F0615J (2)
    U6 5.07 3.29 0 Fix 17-33L 6E1L (1)
    U8 5.01 3.28 0 Fix 17-33L 6E1L (1)
    U16 5.02 2.25 0 Fix 17-25L 6D1L
    DU2 5.01 3.29 0 Fix 17-33L 6E1L (1)
    DU3 5.01 2.49 0 Fix 17-25L 6D1L
    You have misidentified a number of fixed regulators as adjustable.
    Those with a 1 in parenthesis (1) indicates either a problem with the ground point you selected, your meter, or a regulator out of tolerance. These regulators have an accuracy of 1%. All are low by more than that. This is within the power input tolerances of most ICs, but is curious.
    U5 (marked with a (2)) has another problem. Either you did not measure the voltage on pin 1, or it is defective. You are correct, it is an adjustable regulator. The output (pin 2) of an adjustable LDO regulator will ALWAYS be 1.25 volts above the reference (pin 1). 1.25 is a standard voltage used in (I believe) memory ICs. 1.92 is not a standard voltage.
    PlainBill
  • Spetznazer
    replied
  • ecundiffaz1
    replied
    is there anyone i can send this board to for repair and do the mod?
  • PlainBill
    replied
    Originally posted by ecundiffaz1
    hi newbie here,
    not sure if this will post right. i have the common problem with my inverter chip that is shown in your picture. what causes that to go bad?
    Poor design of the inverter causing the FETs to short, most likely. There is a mod to prevent it.
    PlainBill
  • ecundiffaz1
    replied
    Originally posted by Dgtech
    I thought the same thing, but it did. Get that fixed first, then see what you got after. Did you also check the driver chips on the inverter? See pic for usual failure.
    hi newbie here,
  • Dgtech
    replied
    Thats interesting that you had the bad caps on the inverter board first and now this. I wonder if it's not logical that one problem created the other? Maybe there were simply two separate problems. Either case, Visio seems to be the worse sets out there for failure rate, even worse than Samsungs.
  • taydu
    replied
    to update, I replace the cap and when power up i can see the back lite come on but nothing appear, still unable to turn off the TV.
  • Dgtech
    replied
    Originally posted by taydu
    two caps on both inverter are bulge, will get it replace but it shouldn't effect the main board ( cannot turn off after it turned on?)
  • taydu
    replied
    any other suggestion Bill ?
  • PlainBill
    replied
    It's K1117S15
    Thank you
    OK, that output voltage is correct.
    PlainBill
  • taydu
    replied
    It's K1117S15
    Thank you
  • PlainBill
    replied
    I was able to:
    - Turn on the TV
    - Vizio Logo turn from orange to White
    - Screen is Black (not even backlite or a flash, completely black from off to on)
    - Not able to turn OFF TV unless unplug
    From what I've read from this thread and other thread it, the problem is from the main board mostly U33. I used my multimeter to check and got the following number
    Chip Location / Vin / Vout / Adj,Gnd
    U2 / 5.19 / 3.30 / 2.0
    U4 / 5.19 / 3.30 / 2.0
    U7 / 3.30 / 1.28 / 0.0
    U8 / 5.19 / 3.30 / 2.0
    U9 / 3.30 / 1.52 / 0.0
    U33 / 5.19 / 3.30 / 2.0
    What is the part number on U9?
    PlainBill
  • taydu
    replied
  • Dgtech
    replied
    Check the inverter boards as well. (Master and Slave)
  • taydu
    replied
    I was able to:
    - Turn on the TV
  • Dgtech
    replied
    A description of the failure or pictures of the failure is always a great start.
  • taydu
    replied
    Few days ago the tv gave up on me, i found this thread, read it couple times and check all
    U2, U4, U7, U8, U9, U33 and the voltage are fine. Now im kind of frustrate, could someone shed some light for me.
    Any suggestion would greatly appriciate
  • Steph.hen
    Bridge rectifier identification part number KPB305G
    by Steph.hen
    Hi all, a newby question about a bridge rectifier I'm trying to identify.
    I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
    08-29-2024, 09:52 AM
  • mpn78
    Fujitsu Q556, What capacitor for bridge rectifier?
    by mpn78
    Hello
    My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
    There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
    Thanks....
    04-05-2022, 12:31 PM
  • EasyGoing1
    Reading input and output of bridge rectifier on the same scope?
    by EasyGoing1
    I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
    When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
    06-26-2022, 12:52 AM
  • Ross Kohler
    Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
    by Ross Kohler
    I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
    - There's no sign of any attempt to power on when pushing the power button.
    - No PSON signal is reaching the 24-pin ATX connector.
    - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
    - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
    - If I pull the Super IO S_SLPS#_R pin...
    04-16-2024, 09:36 AM
