Toshiba 37" inverter board failure
  • whatusername
    • Dec 2013
    • 456
    Re: Toshiba 37" inverter board failure
    ok so does that mean i still have to remove those 2 teeny tiny smd caps that i can barely see?
    • whatusername
      • Dec 2013
      • 456
      Originally posted by tom66
      DE90 is part of buck converter, the IC will be damaged if it operates without that diode (the substrate of the IC will become the diode which will be bad for it.)
      oh damn ok so what do u guys want me to do?
        If the short is gone with that diode out ... did you check the diode was actually shorted?
        If the diode is shorted that is the point when you find or order a replacement diode and replace it, then test the TV.
        Don't try it without the diode.
        • whatusername
          • Dec 2013
          • 456
          well i dont think its bad i get a reading of 175 in 1 direction and dmm says 1 on other direction
            That sounds OK, so do you still have a short on the board?
            • whatusername
              • Dec 2013
              • 456
              no short when de90 and de91 is removed reinstall de91 and short comes back de90 still removed
              • whatusername
                • Dec 2013
                • 456
                guess i will remove the 2 caps now
                  So is DE91 shorted out of circuit?
                  • whatusername
                    • Dec 2013
                    • 456
                    no in circuit i didnt test it out of circuit but will do now
                    • whatusername
                      • Dec 2013
                      • 456
                      yes it is shorted out of circuit too
                      but that dont explain how come i still had a short when it was removed
                      • whatusername
                        • Dec 2013
                        • 456
                        reinstalled de90 and installed it shorts both ways so theres still a short and de91 is still not installed when this happens so which cap should i remove first?
                        • whatusername
                          • Dec 2013
                          • 456
                          removed ce92 still shorted going to remove ce901 now de90 still installed
                            "no short when de90 and de91 is removed reinstall de91 and short comes back " and "but that dont explain how come i still had a short when it was removed" I am totally confused now.
                            • whatusername
                              • Dec 2013
                              • 456
                              ok if i remove de 91 alone i still have a short if i also remove de90 then the board does not have a short anymore . de 91 is shorted both directions out of circuit de 90 is fine out of circuit.. de90 shorts in circuit with de91 both out and in circuit. if i leave de90 out and just put de91 back in i have a short again. i now have de90 back in de91 is out ce92 and ce901 are out and i still have a short
                              • whatusername
                                • Dec 2013
                                • 456
                                so all thats left is the ic i know for sure de91 is bad but i still short with it and the 2 caps removed and de90 in so the ic has to be causing it because if i also take out de90 no more short but de90 tests good
                                • whatusername
                                  • Dec 2013
                                  • 456
                                  still confused?
                                    If the IC is shorted, then this will not make sense "if i also take out de90 no more short" If everything are removed except the IC and the shorts is gone then it can not be the IC that is shorted.
                                    We know that DE91 is shorted and you had verify it as shorted in/out of the circuit. So what resistance do you get when DE90 is in, <1 Ohm?
                                    • whatusername
                                      • Dec 2013
                                      • 456
                                      ok am going to remove de90 again and retest.. all that will be left in board is the ic
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        ooops sorry had the meter in diode mode lol ok with de90 in and ic in and nothing else there is no short
                                        • whatusername
                                          • Dec 2013
                                          • 456
                                          so i will replace ce92 ce901 and de91 just cuz they are already out problem is i dont know what to order
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • seppde
                                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                            by seppde
                                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                            02-09-2024, 05:19 AM
