Mitsubishi HS-E82 VCR Bad Picture
  • hugocarmo
    • Feb 2021
    • 39
    • Portugal
    Good morning everyone.
    This time I have a Mitsubishi HS-E82.
    It was a bargain that I found with original remote included.
    The problem reported by the owner is that it was working but no output video.
    I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
    I replaced them, cleaned all the liquid remains and the video output got working again.
    I saw too that were three surface mounted capacitors, two near the 470uf and one in a vertical board. I replaced them too, they were leaking too.
    I replaced one surface mounted capacitor in the drum motor pcb, it was leaking too.
    Now, resuming.
    I have video output, vcr menu and tv channels with good picture, if I attach RCA cables to audio input AUX, and a bluetooth receiver I have good Stereo Sound, but no stereo in tv channels nor tape playback. I have the problem you can see in the video that I´ve attached.
    I cleaned the upper drum heads, with printer paper and IPA, like I do to my other VCR´s, no luck.
    Is this bad worn heads symptoms? Or I need to investigate deeper in the pcb´s for more bad caps?
    Thank You!
    Hugo.
    Video link
    https://vimeo.com/886789022
  • R_J
    • 9623
    Re: Mitsubishi HS-E82 VCR Bad Picture
    Make sure the tape guides are loading fully to there stops, if they are I suspect the guide posts have become loose or are out of adjustment.
    when you play a tape do you get linier audio?
    A bad or plugged head would give a poor picture over the whole screen
    • hugocarmo
      • Feb 2021
      • 39
      • Portugal
      Thank You for your answer.
      I looked at the timing marks before I look for bad belt, I have the service manual and all were in sync. The tape loads tight to the head drum...
      I thougt that too before...
      Thank You.
      • R_J
        • 9623
        Thank You.
        If the guides are loading into there V stops, then I suspect the guide posts are loose, It's been years since I worked on these models but I remember some mechanisms where the lower part of the guide would become loose from the slide plate, on others the lock screw would come loose and the guide would turn, Check if the guides are tight or not.
        You are getting linier audio and the speed is ok so the tape is tracking the ace head properly so the tape exit guide is likely ok. I suspect the tape input guide is out of adjustment or loose
        Also check that the back tension band is ok and that the back tension arm is not too tight or too loose against the tape.
        • hugocarmo
          • Feb 2021
          • 39
          • Portugal
          Thank You again R_J.
          I have a JVC where that happened, the lower parts of the guide simply came off, in this case, I checked right now and the guides are all tight.
          I have linear audio, but the image looks a bit out of sync with the sound.
          Thank You.
          • R_J
            • 9623
            About the only thing that can cause this picture is a tape path problem.
            • hugocarmo
              • Feb 2021
              • 39
              • Portugal
              And can´t it be worn heads?
              Thank You.
              • R_J
                • 9623
                one head scans the tape and produces one field of the picture from the top of the screen to the bottom, worn heads would not produce the picture in your video.
                • hugocarmo
                  • Feb 2021
                  • 39
                  • Portugal
                  I managed to find the problem.
                  It was the tape left tape guide, the screw is very loose and it turned with the tape, managed to tune it and fixed it with thread-lock fluid!
                  It was more simple than I thougt!
                  Thank You!​
                  • PNI E.
                    Samsung eu75nu8000 no picture after tape method
                    by PNI E.
                    Hi guys, I write here for help me. I have a Samsung eu75nu8000. The Tv start to turn off and on, and I understand it was a panel problem, because if I take out a ribbon the Tv stay on. I tried the tape method but I have no picture but the Tv now stay on. My question is I have to give up because it s the panel? I notice that the chip vpm2sm it s really really hot, I can’t stay with my finger on it. Do u think all the problem of my panel is due to this chip, or u think it s a death panel and I can’t do nothing?sorry for my English
                    11-10-2024, 03:46 PM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • RetroComputingGrotto
                    IBM LTO 7 Tape Drive - Dust Sensors??
                    by RetroComputingGrotto
                    I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                    I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                    09-19-2024, 01:54 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
