TCL 65S421 No Backlight
+ More Options
Posts
  • m4a2t0t
    • Mar 2013
    • 279
    I can see an image on the screen with a flashlight. Is P_ON at 2.6v acceptable or does it need to be 3.3?
    Main Connector
    1- 3.3 - BL_ON
    2- 3.3 - P-DIM
    3- 2.6 - P_ON
    4- 0 - GND
    5- 2.6 - A_DIM
    6- 0 - NC
    7- 0 - GND
    8- 0 - GND
    9- 12 - 12v
    10- 12 - 12v
    11- 12 - 12v
    12- 12 - 12v
    13- 0 - 3D_EN
    14- 12 - 12v
    I see no voltage on either side of TS2 or TS3. Is something else causing U601 to not drive TS3?
    U601(OZ9976GN)
    1- -.038 DRV1
    2- -.036 GNDA
    3- 12.1 VCC
    4- 3.28 ENA
    5- 6.01 VREF
    6- 3.285 PWM
    7- 2.159 ADM
    8- -.036 STATUS
    9- 2.36 RT
    10- .036 ISEN
    11- 1.02 OVP1
    12- 1.02 OVP2
    13- -.035 SFON
    14- -.035 SSTCMP
    15- -.036 GNDP
    16- -.036 DRV2
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    Re: TCL 65S421 No Backlight
    Just use a LED tester. Ive had a few of these and it was always the backlight so far, not the psu
    • Storyteller12
      • Jun 2020
      • 625
      Originally posted by eazybone
      just use a led tester. Ive had a few of these and it was always the backlight so far, not the psu
      +1
      • vinceroger69
        • Mar 2012
        • 6714
        8 out of 10 tvs i get for free/repair are backlight issues, i always do a quick visual check on the boards then test the backlights saves so much time trouble shooting
        • EazyBone
          • Jun 2023
          • 1353
          • United states
          Agreed. These psus on the Roku TVs do weird things also when then lights have a short. Plus it's pretty much always the BLs lol
          • vinceroger69
            • Mar 2012
            • 6714
            I have actually just fixed a 43 inch roku tv i got for free and yes was backlights at fault, first tapped in screen repair i have done it went ok i just took my time when removing the screen and cleaning it up used 3m foam tape for re assembly.
            • m4a2t0t
              • Mar 2013
              • 279
              It looks like LED2 is bad. The tester stays at 330v when I probe the pins. Thanks
              • EazyBone
                • Jun 2023
                • 1353
                • United states
                Yup that's your answer. Next time on these Roku TVs with same problem, just skip right to testing LEDs, then if they are good then look at PSU
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
                • Comp_Pro
                  No Backlight Macbook A1990 820-01041
                  by Comp_Pro
                  Hello all,
                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                  Tests performed:
                  There is no backlight even with a good screen.
                  Backlight IC is receiving the correct support voltages.
                  Fuse F8400 ok
                  Current sense resistor R8400 ok
                  Backlight IC is receiving 3.3V on enable pin.
                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                  Backlight IC receiving 5V from PP5V_G3S
                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                  05-06-2024, 10:23 PM
                • cheebster
                  iPad Pro 12.9 5th Gen Backlight Issue
                  by cheebster
                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                  Anyone...
                  05-20-2025, 09:17 AM
                • canadaboy25
                  LG Flatron 24EN33TA No Backlight When Cold
                  by canadaboy25
                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                  03-07-2023, 12:23 AM
