Samsung UN60EH6000 wont come on after lightning strike.
This topic has been answered.
    • 12276
    • U.S.
    #41
    Did you make sure the replacement mainboard was a match, usually done by matching numbers on a sticker on the boards and did you try a firmware update on the new board, also not always but in some cases a lightning strike can mess up the firmware and an update can fix it.
      • 12276
      • U.S.
      #42
      Originally posted by karthur
      Which ones are you referring too? If you are talking about the D407 and D409 that I found burned, these seem to be diodes and upon more checking are not good. One is totally open in either direction.
      These diodes are close to the RCA input jacks on the board. The only port that was connected during the strike was HDMI1.
      Can you test these 2 diodes correctly, meter in diode mode, tv unplugged from power, look at this video it's very simple to test them, he's checking a double diode around 7:40 mark: https://www.youtube.com/watch?v=0VfSvU1AHfc
      • karthur
        • Nov 2015
        • 150
        I checked the "new" board the best I could (it doesn't have the stickers on it). From the ad where I bought it, it should be the same as my OEM board. I have not done a firmware update. Not even sure how to do that without being able to get to the MENU screen. Any information on how to accomplish that would be welcomed.
        I tested both the original OEM board and the replacement board. These chips were damaged on my original board as you can see from these pictures.
        The original OEM (damaged) board.
        New Replacement Board
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4458
          • Italy - Milan
          #44
          Take the original main board, remove D407, D409 and test the tv, power board is almost surely ok, but you have not tested the power on-off pin.. further ic905 you have posted only one voltage, pins are 3!!
            • 12276
            • U.S.
            #45
            Again you're showing ohm readings, PUT meter in DIODE mode and check per the video.
              • 12276
              • U.S.
              #46
              Going to give it my best guess, tho I don't like guessing. Some possibilities, may have bought a bad mainboard or damaged in transit or mis-handled, mainboard may not be a match, can you show good focused picture of both boards, WHOLE board not just the damaged part.
                • 12276
                • U.S.
                #47
                • karthur
                  • Nov 2015
                  • 150
                  My apology for checking those wrong. Here is the readings I am getting with the meter in DIODE mode.
                  • karthur
                    • Nov 2015
                    • 150
                    Here is a picture of the "New" board.
                    • karthur
                      • Nov 2015
                      • 150
                      This is a picture of my original board. I have removed the IC901. I was trying to get a dump from it. I could read it, but was not certain I had a good file..
                      • karthur
                        • Nov 2015
                        • 150
                        I checked the power on-off and got 5.0 Volts. See post #9 on first page. For the IC905, here is the readings I get on my replacement board. If I checked this wrong, just let me know how I should be checking it.
                          • 12276
                          • U.S.
                          #52
                          If it was me, I would try another mainboard, sometimes you get a bad one, you should be able to get a refund.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4458
                            • Italy - Milan
                            #53
                            both things wrong.. in the early posts you tested only odd pins, pins are in 2 rows, you wrote the signals marking as them are one only thing but are 2 signals in a row, power on-off is one thing, A5v is another and you are measuring A5v only..
                            second thing, i want you to bear with original board for now, checking ic905 i mean the pins voltages respect to GND, i guess this is a voltage reg. but not sure, tell eventually its code..
                            • karthur
                              • Nov 2015
                              • 150
                              I have asked for a refund and I am ordering another replacement. What do you think about the readings I got on D407 and D409 (post #48 above)? It appears to me that D407 on the new board is no good because it should be ZERO with "+" on the cathode.
                              • karthur
                                • Nov 2015
                                • 150
                                Davi,
                                Here are the readings for all 14 pins from the power board. These readings are between ground and the pin with power on the board. For reference, I also show the pin map print on the board. The pins that I see are out of range are Pins 2 and 14. I am not sure what Vamp is, so 5 and 6 might also be out of range.
Name:	14Pin Power connector.jpg
Name:	Power Board Pin Map_Rotated.jpg
                                For the IC905, I have remove the IC901 but here are the IC901 volt readings.
Name:	IC905 Volt Readings.jpg
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4458
                                  • Italy - Milan
                                  #56
                                  Now is 100% clear, so the power board is ok, all readings are within specs, Vamp is Audio amplifier voltage and is ok at 13v, the ic905 is wrong if is a voltage reg. , tell me the marking code, it has input 5 - O volt but output must be 3,3v i guess..
                                    • 12276
                                    • U.S.
                                    #57
                                    To me it looks like both diodes on old board are bad, 409 gives nothing, 407 only shows one diode, 407 on the new board seems strange since it gives a reading in both directions, which it should NOT.
                                    • karthur
                                      • Nov 2015
                                      • 150
                                      The best I can tell the markings on the IC905 says "WCAP".
Name:	IC905 Marking Code.jpg
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4458
                                        • Italy - Milan
                                        #59
                                        i have already seen, the best site for smd codes is down now..
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4458
                                          • Italy - Milan
                                          #60
                                          No i can't find it, i remember i have seen it..
                                          • Bardou Kari
                                            HP EliteBook 840 G6 – no power after lightning strike
                                            by Bardou Kari
                                            I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                            – Charger is OK and 19V is present at the motherboard.
                                            – No charging LED, no fan, no reaction.
                                            – I don’t see any 3.3V or 5V near the coils.
                                            – Battery is unplugged.
                                            – I’m new to board repair but can use a multimeter.
                                            I added a clear photo of the board.
                                            Any idea where to start or what to check next?
                                            Thanks a lot for your help!...
                                            07-01-2025, 10:45 AM
                                          • SluggerB
                                            Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                            by SluggerB
                                            Yes it's a 17 year old Panasonic plasma!
                                            I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                            06-04-2025, 07:02 PM
                                          • MrCreosote
                                            Lightning Strike: 55" TV dead: is display panel OK?
                                            by MrCreosote
                                            THE LIGHTNING:
                                            This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                            Very close and probably a very strong EMP.
                                            THE TV:
                                            No standby LED. Some voltage from PSB (not totally dead).
                                            But found a kit of ALL 4 circuit boards for $55.
                                            At first thought, this will fix my TV.
                                            But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                            08-16-2021, 10:27 PM
                                          • pbig
                                            advices for repairing Sony Bravia 32EX600 after lightning strike
                                            by pbig
                                            hi everyone,
                                            my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                            On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                            - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                            - from connector CN6150 (15 poles)
                                            STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                            06-28-2023, 02:43 AM
                                          • pfl
                                            ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                                            by pfl
                                            Hello Everyone.
                                            This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                                            It consists in :
                                            • a power board were the full H bridge class D amplifier and main power rails are located
                                            • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                                            Power rails are ok.
                                            human interface is working fine
                                            Input levels are...
                                            01-23-2024, 10:21 AM
