Hisense 65R6107 remote sensor
  • Jackching
    • May 2017
    • 127
    Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
  • Diah
    • Feb 2013
    • 6582
    Re: Hisense 65R6107 remote sensor
    when it work in close distances.. then check yours room environments and yours RC
    take mobile with IR sender such galaxy S5 , and use Galaxy Universal Remote apk... you will know yours TV received the signal from far distances
    • cheeky2
      • Dec 2012
      • 339
      • uk
      If you have tried to different remote controls then looks like the receiver part of your TV for receiving the infra red signals is faulty. Make sure it it orientated and pointing outwards and not down or to one side. I have seen water get in these before with kids mucking about ( I guess).
      • edugimeno
        HiSense 55A7500F won't obbey to remote after power on
        by edugimeno
        Hi! I have this TV set that does the following:
        1) I press the red power button on the remote
        2) The TV turns on normally
        3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
        4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
        Then after it's off, it would again accept the TURN ON from the remote and same again
        BUT:
        -The remote does show the correct IR beam while observed thru a phone camera
        -The TV works fine while using the MiRemote...
        03-14-2023, 11:22 AM
      • CapLeaker
        AcuRite 5 in 1 temperature sensor replacement repair
        by CapLeaker
        Got a new victim:
        AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
        A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
        B: stuck at some temperature and maybe updating once in 12 hrs or so.
        Easy solution is to go to AcuRite website and purchase the sensor. Right?...
        04-15-2025, 01:32 PM
      • groomit
        Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
        by groomit
        I just replaced the battery on a Google Pixel 5.
        After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
        Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
        The rubber seal is on again (as mentioned in various suggestions in other forums).
        This smells like a cold or broken solder joint. So I'd like to reflow...
        06-11-2025, 02:21 AM
      • cstout
        DeLonghi AC Remote only accepts 3V
        by cstout
        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
        I can't find any schematics...
        06-03-2024, 03:53 PM
      • Gcnewbie
        Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
        by Gcnewbie
        Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
        I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
        My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
        I opened the...
        03-29-2024, 06:55 AM
