Sony XBR-65X900H vertical lines
  • dustman1747
    • Feb 2015
    • 33
    Re: Sony XBR-65X900H vertical lines
    I did watch the video, mine is an H series though and appears different. My TV only has a white and red light that I have seen. I used a 2gb drive and the white light pulsed for a few minutes then the light turned off. I presume it took the update because there was audio again but no picture after the pulsing stopped. I tried renaming the files to force another update but no luck. The firmware for this version comes in a ZIP not a PKG but I tried it anyways.
    I did run across a technical bulletin for t-con and/or main board replacement procedure. It requires a WB/MURA/CUC data transfer between the t-con and main but this requires the screen to at least turn on so the service menu can be used.
    As a last ditch I did order another t-con and new lvds cable to rule them out.
    Not sure where to go from here.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4363
      • Italy - Milan
      Zip files are not suitable for tv updates, them must be uncompressed in the usb key root
      • dustman1747
        • Feb 2015
        • 33
        According to Sony's support page for this model it looks like it call for using the zip
        Download the Updater:
        Before you install the update, you'll need to download the update files from the Internet and save them to a USB flash drive.
        Click the Download button at the top of this page, then read and accept the terms and conditions.
        Once you have accepted the terms and conditions, click the Download button at the bottom of the page to download the update files to your computer.
        Verify the downloaded file names and size (see the File Info section).
        Extract the downloaded files to a location on your computer you can easily find.
        Make sure that a sony_tvotafull_202x_zzzzzzzzzz_yyy_auth folder is created and that it contains the following files:
        sony_dtvxxxxxxxxxxxx_xxxxxxxx_zzzzzzzzzzzzzz.zip
        sony_dtvxxxxxxxxxxxx_xxxxxxxx_zzzzzzzzzzzzzz_xxxx.dep
        Connect the USB flash drive to your computer.
        Go to the location where the extracted files are saved and copy (or drag and drop) the two files from the sony_tvotafull_202x_zzzzzzzzzz_yyy_auth folder into the root directory of the USB flash drive.
        Note: The root directory is the first or top-most directory of the device, which contains all the other folders.
        Remove the USB flash drive from your computer and continue to the next section
        • Diah
          • Feb 2013
          • 6395
          you are wrong... this TV android... update always with zip....
          plug the TV out from wall socket wait view minuts.... press the joystic and pull it down.. keep it in this position... and plug it in wall.... the fron LED indicatore will change to green color at this relase the press
          • zomi
            • Nov 2011
            • 505
            I always extract the file and put the .pkg on the root of the usb stick.
            • Diah
              • Feb 2013
              • 6395
              yes you are correct,, if the .zip after extracting there .pkg then should use .pkg
              • dustman1747
                • Feb 2015
                • 33
                Tested a second t-con and a new set of lvds cables, still can't get an image. Probably going to call this a one a loss.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4363
                  • Italy - Milan
                  #28
                  have you read the second page posts? how about software attempts?
                  • zomi
                    • Nov 2011
                    • 505
                    #29
                    power the tv with the tcon disconnected
                    should give the error with the green/ amber light
                    then you will have to update/ pair it
                    then add usb with update file and see what happens
                    worth a shot
                    • dustman1747
                      • Feb 2015
                      • 33
                      I have yet to be able to get any sort of amber/green error lights. It's an H series which I believe is different than the other series and may display errors differently. The TV only has a white and red lights that I have seen. I got a white light pulsing for a few minutes with the jump drive plugged in, then the light turned off. I presume it took the update because there was audio again but no picture after the pulsing stopped. I have tried additional updates but it does not seem to force the TV to reflash. The manual specifically says it will ignore the same version firmware and I have not found anything referencing a way around this.
                      The service and the diagnostic manuals all seem to indicate that there should be a test pattern or service menu displayed during the repair process in order to perform the "sync" yet I get nothing. This is what makes me lean towards a bad panel or larger problem.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4363
                        • Italy - Milan
                        #31
                        If the tv is an Android like diah says, then try many combinations as you can with the flash stick inside and with extracted or not files, with portable devices it is usually Vol- / power, try it with the tv body power key or remote power key.. try power key kept pushed for different time, example 5sec, 10sec, 15sec..
                        don't give up.. i know what i say..
                          • 12206
                          • U.S.
                          #32
                          Did a lot of research with my xbr 900 series, and these symptoms that you have a WHOLE lot of people had, I only saw it solved in one of 3 ways, an update, new eMMC or new mainboard.
                            • 12206
                            • U.S.
                            #33
                            But they did not have vertical lines so still a puzzle.
                            • dustman1747
                              • Feb 2015
                              • 33
                              The vertical lines were only when I was trying the tape trick. The normal untouched screen is just black with backlights.
                              I replaced the whole main board which fixed the original no power condition and flickering red light. Now I have power, start and menu sounds just no image. I would assume the eMMC is working since it's booting but I'm no expert.
                                • 12206
                                • U.S.
                                #35
                                Those damn eMMC's can be tricky, they can present symptoms in at least a few different ways and still be bad.
                                  • 12206
                                  • U.S.
                                  #36
                                  Check Nick's tv on youtube, my memory is bad but I think I recall him saying check the little mlc capacitors near the chip for shorts which is usually a sure sign of a bad chip, if it's not just the cap that is bad, which is easy enough to check if cap is removed. But always check results many times because some of those caps are supposed to have low ohms, it is tricky.
                                  • Storyteller12
                                    • Jun 2020
                                    • 624
                                    +1. I mentioned this in post 3. Nick has a lot of experience with sony TVs.
                                      • 12206
                                      • U.S.
                                      #38
                                      Well indeed you did, I wondered where I got that good idea from.
                                      • gpo23
                                        Sony KDL-40V3000 - Vertical lines
                                        by gpo23
                                        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                        With the new t-con the color are good but there are vertical lines on all the screen :
                                        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                        Is there a way to fix the vertical lines on the new t-con ?
                                        Thank you for your help
                                        gpo23...
                                        10-04-2023, 09:11 AM
                                      • Stanley1843
                                        by Stanley1843
                                        06-29-2024, 11:54 AM
                                      • noisykid
                                        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                        by noisykid
                                        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                        12-30-2024, 07:15 PM
                                      • iampivot
                                        Three vertical lines without t-con board connected: Sony 55X8000F
                                        by iampivot
                                        I have a Sony 55x8000f that has three vertical lines (three different colors), with the lines still showing when the cable from t-con board to the panel is disconnected. Am wondering what might be causing this? Unfixable panel problem?
                                        04-18-2022, 06:41 PM
                                      • Falki
                                        Colorful LCD Vertical Lines on Samsung ue55es8090
                                        by Falki
                                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                                        A similar issue has been posted as well but also with no actual response ...
                                        08-12-2025, 04:19 AM
