Sony XBR-65X900H vertical lines
  • dustman1747
    • Feb 2015
    • 33
    I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
    Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen to go grayish with less pronounced lines.
    Any other ideas? Bad panel?
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Re: Sony XBR-65X900H vertical lines
    I mean sounds like bad panel. I'm learning here also, but tcon replaced and lines still. Lines are most likely panel.
    • Storyteller12
      • Jun 2020
      • 625
      Might have gotten a bad tcon board but you may want to check the buffer boards for shorted caps or diodes also. Have seen this on a few Samsung TVs where diodes go bad.
      If neither of those most likely mainboard emmc or the main processor is shorted. Real common on Sonys
      I believe Nicks TVs YouTube channel shows which caps to measure for the emmc and processor for this model.
        • 12328
        • U.S.
        Make sure the replacement mainboard is not a mismatch, have seen many bad tcons display like this.
        • dustman1747
          • Feb 2015
          • 33
          Boards appear to match based on what is available on ShopJimmy. I've attached pictures. The top boards are the original and the bottom ones are the replacements which are currently installed.
          Am I correct in assuming the EMMC is good on the replacement considering I have an optical light and setup/menu noises after a factory reset?
          I can try another TCON but was just debating how likely that is actually the culprit.
            • 12328
            • U.S.
            No expert but I don't think you would get that image if bad eMMC, maybe test the tcon, they sold a lot of these xbr's, many good tcon testing videos on youtube.
            • zomi
              • Nov 2011
              • 511
              Bad emmc you woudl have boot problems
              freezing or totally dead set
              not this
              • Diah
                • Feb 2013
                • 6553
                show us please the sticker on the tv chassis belong to the panel
                • dustman1747
                  • Feb 2015
                  • 33
                  Is this the sticker you're looking for?
                  • Diah
                    • Feb 2013
                    • 6553
                    VA panel... you have issue on panel buffer boards... it may being cleaning liquid effect on it
                    take out the speaker and the metal cover of both side , show us please yours Panel buffer boards
                    its sound this TV some one work on it before it landed under yours hand
                    • dustman1747
                      • Feb 2015
                      • 33
                      Here's some pictures not sure what type of detail you were looking for. I can get better close ups if needed.
                      What makes you think it was worked on before and how does a VA panel make you think it's a buffer problem?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4535
                        • Italy - Milan
                        Hi dustman.. my guess is that you have good Panel/tcon and only fault was main board, Sony tv needs a pairing procedure after mb or tcon replacement, now i'm on work, i hope at home i manage to find something in my notes on how to.. if you are in a hurry check my last discussions on a Sony this year.. I've talked about it with Lotas.. bye..
                        • Diah
                          • Feb 2013
                          • 6553
                          you have U ribbon cable on each side at the panel buffer boards.... disconnect one a time and turn on... show us the result photo
                          BTW this test should all yours perviouse masking / type remove it... let the set as original only the U ribbon disconnected
                          • dustman1747
                            • Feb 2015
                            • 33
                            The only change I could get was with entire left side unplugged and the right side U cable also unplugged. A picture is attached, boards are disconnected at the arrows. It results in a black pattern.
                            I've done a lot of digging on this pairing process and haven't found anything about these models. The other models appeared to have a specific error code via the front lights for mismatched boards. I've done software updates on it twice now and neither time did it change the results.
                            • Diah
                              • Feb 2013
                              • 6553
                              wrong,,, the ribbon cable between t-con and panel should be always in place... only you test the U ribbon at buffer boards disconnected each time one side of left side and right side... you have 2 U riboon alone
                              also your masking type you did before should take out... and feed it to signal.. not just blank screen
                              • dustman1747
                                • Feb 2015
                                • 33
                                All of the tape is removed. I have a chromecast connected. The TV seems to be in the initial setup menus based on the audio, so I cannot be sure of the image but there should at least me a menu.
                                I did as you advised:
                                Right U ribbon disconnected, all others connected - Black screen with no changes
                                Left U ribbon disconnected, all others connected - Black screen with no changes
                                • Diah
                                  • Feb 2013
                                  • 6553
                                  first take the screen Bezel out and inspect all round 4 corners of screen glass if there broken / damage
                                  • dustman1747
                                    • Feb 2015
                                    • 33
                                    Panel shows no signs of damage
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4535
                                      • Italy - Milan
                                      i have found this on my notes file:
                                      Sony smart tv (not Android) forced update mode (with board pairing, not well tested):
                                      1- Put an update file on a flash drive with state led
                                      2- rename it as upgrade_loader.pkg
                                      3- put flash drive in tv, plug the power in when keep pressing power button on local keys, it brings to a different state with blue led steady in standby
                                      position, releasing the button and pressing it again brings to a pulsating white led, wait flashdrive led to stop after few pulses, remove power, reinsert
                                      it, white led does 3 - pause - 7 pulses, then turn on with local key, tv turns on with backlight an maybe an image
                                      also watch this
                                      https://youtu.be/3kYPjIHt8Lc?si=ApuSHLDWjiu7L0qx
                                        • 12328
                                        • U.S.
                                        When trying to update, try not to use anything bigger than a 4 gig drive, sonys can be very fussy.
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • iampivot
                                          Three vertical lines without t-con board connected: Sony 55X8000F
                                          by iampivot
                                          I have a Sony 55x8000f that has three vertical lines (three different colors), with the lines still showing when the cable from t-con board to the panel is disconnected. Am wondering what might be causing this? Unfixable panel problem?
                                          04-18-2022, 06:41 PM
