Vizio d650i-c3 freezing
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    This Vizio doesn't freeze at startup. Not that problem
    This Vizio will go into an app like YouTube and work and a very bad picture rate and freeze on videos pretty quickly. But will freeze up in all the apps. Plug a Roku stick into it and it works flawless without video buffers etc. Is there a solution to this freezing issue with Vizio's? It's at latest firmware. I figured they just suck, but factory reset and firmware didn't fix.
  • nomoresonys
    • 12330
    • U.S.
    Re: Vizio d650i-c3 freezing
    Vizio probably abandoned the apps after a certain amount of time, like so many others do, did you try updating the apps.
    • nomoresonys
      • 12330
      • U.S.
      Also wonder if the latest firmware has anything to do with it not working correctly, have seen plenty of times where the latest firmware took away some features, which is a bs thing for tv makers to do imo.
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Ya the app is updated. It updated when I loaded it. I've seen a few problems on Reddit etc but oh well. Currently works excellent with a Roku stick and picture is great. Well if anyone knows feel free to share
        • jason123
          Vizio D50-F1 - Can't update Software / Firmware
          by jason123
          Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
          I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
          I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
          08-15-2021, 06:48 AM
        • Lee M.
          Vizio E55-DO firmware corrupted?
          by Lee M.
          I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find...
          04-02-2023, 03:12 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
