Hisense H6750G stumped on this
  • EazyBone
    • Jun 2023
    • 1315
    • United states
    Picked up another free one. The original owner replaced power board to try and fix them gave up gave to me
    Problem: Red led standby light blinks once every 5 seconds repeatedly for ever.power button does nothing. Nothing turns on.
    PSU, 12v are all 12v to main, 18v are all 16.6 stby is 2.6
    Disconnect main and 12v is 10.5 and 18v become 14.4.
    This is the same for BOTH psus.
    Backlight tester turns on backlights at 105v each strand and work properly.
    I cannot get ANY voltage to backlights on either power supply. They remain zero always.
    I am stumped. I put pictures. Is there any way to jump this on or does anyone have any insight. The main is getting some voltages as it should.
    Does the main tell the PSU to turn on backlight voltages? Should I have some sort of voltages at the PSU for LEDs? Help lol
    Also thanks everyone whose been helping me! I've fixed many many tvs now and it's going great 👍👍👍💯💯💯
  • EazyBone
    • Jun 2023
    • 1315
    • United states
    Re: Hisense H6750G stumped on this
    Also is 75 inch.
    As a note w833,832,830,834,835 are all at -5v (checking in DC with chassis ground) and start and -5 and drop all down to zero, if that means anything.
      • 12128
      • U.S.
      Check XP901, voltage on the BRI pin, check it in standby then power on tv, what voltage do you get in both situations?
      • Diah
        • Feb 2013
        • 6357
        105V by LED tester sound to me not good.... how about when you start the tv did you have any up and down V, u need to put the probe in place then turn on
        BTW STB 2.6V very low
        so you need to do the first test and second leave the PSU alone with out MB connected and check V on the its socket we want to know STB
        • EazyBone
          • Jun 2023
          • 1315
          • United states
          Bri is 0.151volts, mashing power button does no change as TV won't power on at all.
          BSW is .105v, mashing power button jumpers it to .109 and right back down immediately, that's all that's happening.
          PSON never gets any volts
          • EazyBone
            • Jun 2023
            • 1315
            • United states
            TV doesn't start. Voltages never change when hitting power button for LEDs they always remain zero. StB v is the same on Both power boards. Will get back in couple min without StB MB connected
            • EazyBone
              • Jun 2023
              • 1315
              • United states
              StB is zero with MB disconnected
              • Diah
                • Feb 2013
                • 6357
                read other pins at socket psu what v u have and where
                  • 12128
                  • U.S.
                  Do test on backlights as Diah described, if that looks ok maybe test the powerboard as stand alone.
                  • EazyBone
                    • Jun 2023
                    • 1315
                    • United states
                    PSON zero
                    18v's 16.6
                    12v's 12.14
                    Bri 0.152
                    BSW 0.105
                    StB 2.6
                    Led drivers all zero
                    Disconnect from mb
                    PSON zero
                    18v's 14.6
                    12v's 10.14
                    Bri 0
                    BSW 0
                    StB 0
                    Sony the LEDs both have 105v and do turn on with tester
                    All steady voltages also
                    • EazyBone
                      • Jun 2023
                      • 1315
                      • United states
                      Also I have two psus and they both give these voltages
                      • Diah
                        • Feb 2013
                        • 6357
                        so you have step down circuit on MB.. work on it,, and check if u have spi on it if it shorted
                          • 12128
                          • U.S.
                          Like Diah said 105 seems quite low for a 75 inch tv, does this powerboard have a label for expected backlight voltages? not sure tho, maybe it's normal if it's edge lit.
                          • EazyBone
                            • Jun 2023
                            • 1315
                            • United states
                            I really don't know what this means. I tried to look up step down circuit. Don't know what spi is either.
                            Here are some pictures, one component gets 220degree fahrenheit which I circled on MB.
                            And here are some pictures of it.
                            Sony, they are not edge lit and for some reason my last Hisense was only 2.5 v per light and looked dim. So 105v for 2 sets. Also here's the expected voltages picture which says 98vAre we thinking this is a MB problem?
                            • Diah
                              • Feb 2013
                              • 6357
                              disconnect the blue LVDS cable from MB side and turn n see if backlight come on
                              • EazyBone
                                • Jun 2023
                                • 1315
                                • United states
                                No backlight, nothing changes
                                Edit, the backlight voltages come up to 0.200v and drop to zero.
                                This is with everything connected and MB lvds cable disconnected
                                Also with lvds cable connected the voltages come up and down like that now also, must of missed this earliwr
                                • R_J
                                  • 9535
                                  The led supply voltage for this power supply is 98V@510ma. You could have a bad led in the panel causing the problem, your led tester likely only provides about 10ma, when the led draw a higher current they can fail.
                                  Using W842 as ground, check the voltage on W702 as you turn on the tv, see if this voltage comes up and drops, It may be tough to check with a meter.
                                  • R_J
                                    • 9535
                                    Originally posted by EazyBone
                                    Also is 75 inch.
                                    All these jumper wires are in the primary (hot) side of the power supply, you can NOT check these points using chassis ground.
                                      • 12128
                                      • U.S.
                                      That does seem very hot for a voltage regulator, check those little caps right by it, are any shorted, also what do you get measured in ohms?
                                      • EazyBone
                                        • Jun 2023
                                        • 1315
                                        • United states
                                        I can hit about 100ma, and they still turn on. Not saying this is wrong but is what I got.
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • BadCapex
                                          Hisense main board surrogate evaluation
                                          by BadCapex
                                          I am yet another unfortunate owner of a 65H6570F with a main board that failed due to an inherent flaw with the eMMC.
                                          Reference: https://www.badcaps.net/forum/showthread.php?t=117406
                                          The exact replacement board for a 65H6570 model TV is RSAG7.820.8831/ROH (aka 265223, aka 244991). It is very rare or expensive ($150+) to purchase currently and arguably not worth it if they're all just ticking time bombs.
                                          A very similar board was identified in the above referenced thread, RSAG7.820.10315/ROH. It is more reliable, cheap, plentiful, and...
                                          10-22-2023, 04:36 PM
                                        • LemoneyF
                                          Hisense 50r6- no standby, no power, bad main board?
                                          by LemoneyF
                                          Hi all
                                          I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                                          I have tested the power supply and found the following:
                                          363V and 373V across the input caps
                                          bri- 0V
                                          ana- 0V
                                          vamp-17.03V
                                          vamp-17.03V
                                          stb- 0V
                                          12V- 9.3V
                                          12V- 9.3V
                                          To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                                          10-12-2022, 07:44 AM
