HiSense 65H6510G no boot
  • howardc64
    • Jun 2017
    • 653
    TV standby light flash once after plug-in AC power. Then silent. No backlight, no LCD image on flash light test, no SPDIF light.
    All PSU voltages to main looks good (12v, 20v (label says 18v but is 20), standby voltage) Probing main board shows what appears to be a DCDC converter (MSH6103A can't find datasheet) providing 5v, 3.3v and 1v. 5v present to the standby light power switch board.
    These HiSense TVs appears to have lots of firmware corruptions that takes out the main board either through smartTV use or firmware update. Used main board prices are quite high probably due to so many main boards failing from poor firmware. Since I only get 1 blink on the standby light, probably even basic boot firmware has corrupted (>1 blinks will indicate some failure status)
    Main SOC is a MStar msd6886NQHT (MStar bought out by MediaTek in 2019 according to Phillips lawsuit docs in US ITC court filing link p48 )
    Found this 2018 service guide for MSD5886 showing UART access to the TV to flash various boot/firmware bits
    https://www.manualslib.com/manual/16...roduct-MSD6886
    p28 shows a serial port connection to the earphone port. My TV has both an earphone and service port (also earphone plug shape) right next to it. Service port plug solder points appears to show its just a TRS 3.5mm plug port
    https://www.headphonesty.com/2019/04...uctor_plug_TRS
    Looks pretty easy to make the DB9 to TRS 3.5mm cable (pin 2/3/5) and can buy these off the shelf programming cables
    https://www.youtube.com/watch?v=4riU...elliteTrackers
    Then its onto finding software and this TV's boot/firmware bits.
    Flashing in boot/firmware via serial ports is pretty standard Android flashing process. Recently did this on my Chinese Android HeadUnit for the car. Just need the cable, Flashing firmware (usually from main SOC maker) and trigger SOC to reset.
    Anyone has experience with this? Also probably unlikely to get boot/firmware bits from HiSense so probably need a flash in a raw dump?
    I'll try heating the main SOC slightly to see if any help but given the % of firmware failures on this TV, corruption boot/firmware seems the most likely candidate.
  • Diah
    • Feb 2013
    • 6560
    Re: HiSense 65H6510G no boot
    you are diving at wrong ocean...
    lets go back to original issue while all in original connecting.. give read of the socket which goes to main-boards and LED socket high and low at first start
    • howardc64
      • Jun 2017
      • 653
      Don't know if BSW is turning backlight on but < 1v after plugging in AC and no change pressing power switch on TV. Anyway, none of the main connector voltages change pressing power button on the TV (not remote)
      Shopjimmy shows 10 strips of 6 LEDs so LED tester shows 10v below 90v assuming 3v LEDs.
      https://www.shopjimmy.com/hisense-lb...ght-strips-10/
      googling HiSense standby light blinking codes shows 2 blinks = bad LED. Anyway, I have no standby light at all (briefly flash after plugging in AC) So most signs seems to point to dead main
      • Diah
        • Feb 2013
        • 6560
        you are still diving at wrong ocean
        if you work on what SJ write and advertised then no need to post over here.... they sell parts not to diagnose issue..
        yours photo remark voltage i cant understand from it any point.. as its out of my poor English knowledge.. sorry
        • howardc64
          • Jun 2017
          • 653
          yours photo remark voltage[/URL] i cant understand from it any point.. as its out of my poor English knowledge.. sorry
          4 pins on PSU LED connector. Presumably 2 serial circuits.
          blue
          white
          red
          black
          volt meter ground probe on chassis
          blue = 195v
          white = 124v
          red = 195v
          black = 124v
          meter + on blue, meter - on white = 0v
          meter + on red, meter - on black = 0v
          These voltage reading starts when plugging in AC cord and never change with pressing TV power button.
          LED tester + on blue and - on white light up LED and reads 79.2v
          LED tester + on red and - on black light up LED and reads 79.2v
          I only use shopjimmy reference to see # of LEDs. Of course it may not be exact to whats in the TV. To see whats in the TV require a lot more disassembly.
          • Diah
            • Feb 2013
            • 6560
            disconnect the MB from socket XP810 and tested the voltage you have on it and on the LED BL socket with references to TV chassis
            • howardc64
              • Jun 2017
              • 653
              XP810 disconnected from main
              BSW BRI 0v
              18/12v = 20v
              all 12v = 9.4v
              BL Connector (volt meter - on chassis)
              Connected to backlight
              blue and red = 190v when plug in AC and continuously dropping
              white and black = 120v when plug in AC and continuously dropping
              Disconnected from backlight
              white and black = < 10v and continuously dropping
              • Diah
                • Feb 2013
                • 6560
                if you are sure MB disconnected and this is the value u have,,, then you have one Optokoppler between primary and secondary PWB defect
                • nomoresonys
                  • 12328
                  • U.S.
                  Maybe try the powerboard as stand alone and see if you get steady voltages and backlights on.
                  • howardc64
                    • Jun 2017
                    • 653
                    I only see 1 optocoupler on bottom of PSU (right of center). The diode side measures good (1325 in forward bias, 0 in reverse ) Don't know how to check emitter collector side in circuit.
                    PSU doesn't light up backlight with main disconnected. Anyway, there is clear evidence main is dead. Here is latest summary
                    I believe the boot sequence is as follows
                    - PSU generate 12v to main and 20v (not sure what this is for, maybe tcon or audio amp? I have seen LG tcon's PMIC generate 20v+ VGH from 12v)
                    - If main boots properly, it will turn on standby light and power on IR. If TV is requested to power on, main will tell PSU to turn on backlight along with supplying analog or PWM dimming signals. PSU on this board shows ANA signal at a minimum (I've seen ANA and PWM dimming on a 55 Samsung but not sure HiSense have both)
                    - BSW (Backlight Switch?) between PSU and main is likely the signal main uses to tell PSU to turn on backlight. Goes to about 0.8v when AC is plugged in. I jumped this line with 3.3v standby (generated by main's DCDC power tree) and saw backlight flash on briefly. I'm guessing probably need to supply proper ANA signal (maybe jump 3.3v also) to keep it staying on.
                    - Main's DCDC power rails use PSU's 12v to converts to all the necessary voltages to drive its components starting with the computing system (CPU=1v, DDR3=1.5v, eMMC=3.3v and 1.8v) just to be able to boot the computer. Other voltages like 5v exist for USB, IR, wifi, etc
                    -All of the main's computing system voltages are present checking around SOC/DDR3/eMMC. One of the 2 USB port has no 5V. Circuit trace (service manual has the circuit diagram) shows its enabled by the CPU so CPU didn't get that far.
                    - FLIR image of main shows one region of SOC and one side of eMMC warms up on plugging in AC. This likely shows everything is configured to start reading boot/system code from eMMC. The correct boot sequence on AC plug in would be to enable IR and turn on standby light at a minimum. But lacking standby light, 2nd USB port power, no SPDIF light etc... means SOC didn't get very far.
                    So main is dead and I suspect it is likely firmware. Main boards for this TV (3 years old) is out of stock everywhere @ $100. Many complaints of slow smarttv software and bricking from updating the TV. Anyhow, Hisense doesn't even provide USB recovery firmware without request. Not sure can get PC flashed tools and firmware.
                    So to summarize, main has the 12v source from PSU and DCDC generates all voltages for the SOC, DDR3, eMMC but no evidence its booting very far. Don't think I want to invest $100+ on a replacement main so will see if can gather enough SOC tools to see if can at least get a terminal prompt over the service port (3.5mm jack for serial UART signal)
                    • dan8139
                      • Jul 2004
                      • 57
                      I hate situations like this. It's the way of the world sadly.
                      Can you scope something on the ARM chip to at least see if it's alive (clock etc)?
                      Wish you luck.
                      Did you say earlier the 12v rail was at 9.4v?
                      Why is the 12v at 9.4v?
                      • howardc64
                        • Jun 2017
                        • 653
                        Wish you luck.
                        Unfortunately no scope or logic analyzer. That would be helpful of course. But I suppose seeing heat signature in one spot in the SOC and one side of eMMC indicate there is clock (or a short of course but my probe found none)
                        And been fixing lots of easy fixes (change LED backlight, blown PSU caps, shorted panel edge driver caps and flex etc) Finally hit a couple of hard ones like this haha.
                        Yes, PSU has a couple of mysteries and I know nothing about power electronics
                        Just doubled checked and it will read 12.5v (solid and steady) when main is connected. When main is not connected, Connecting AC and multimeter will read 9.5-12+v (depending on how long leave AC disconnected, seems to get higher voltage if disconnected longer) and quickly drop to settle in at 9.4v. Traced it back to the 2 rectifier that generates 20v and 12v. Will read 12v at rectifier output when main disconnected (can no load cause this?) Here is pic and data sheet for the 6 cold side rectifiers
                        https://datasheetspdf.com/pdf/108335.../2CZ20100A9S/1
                        https://datasheetspdf.com/pdf/100455...tor/10F40HF3/1
                        Also many TV PSU will light up LEDs when main is disconnected. I guess must be default behavior without main. Don't have a reference on this HiSense. Great if someone can chime in if HiSense (ideally this model) does the same.
                        • howardc64
                          • Jun 2017
                          • 653
                          UPDATE
                          The PSU does make a faint noise differently with main connected and disconnected. Furthermore, one periodic noise correlates with voltage drops.
                          Main Connected
                          - Every ~30s will hear a faint 1/2s squeal sound near the big transformer (haven't isolate it exactly where from) when this sound occurs, all DC voltages will drop momentarily. 195v will drop about 10v on digital volt meter. Even main side's 1v CPU supply voltage will drop a tiny amount (few 100th of a volt on the meter)
                          Main disconnected
                          - No periodic squeal but a faint clicking sound that speeds up after plugging in AC which seem to gradually become steady clicking frequency.
                          So I guess PSU could still be suspect as without a scope, can't see how clean the DC voltages are going to main.
                          • Diah
                            • Feb 2013
                            • 6560
                            i need to correct my post #8
                            i just learned yours TV Android. so the PWB will be in high always for warm start 12 / 20 V.
                            so the boot loop caused by MB either emmc or CPU / RAM BGA or could be Firmware too since its android... try to contact Hisense and ask them for Firmware if you couldnt find in net
                            • nomoresonys
                              • 12328
                              • U.S.
                              Check all solder joints with microscope, and give m the wiggle test which works good to find one that looks good but isn't.
                              • howardc64
                                • Jun 2017
                                • 653
                                Yes its Android TV. Can you explain what "PWB will be in high mean"? Does it mean backlight voltage will not be final?
                                FYI, I also learned 20V = VCC_A for the audio amp from the service manual schematic.
                                I guess you are thinking the periodic ~30s PWB squeal / brief voltage drop is main board boot loop. Checked all signal from main->PWB and all are steady when this occurs
                                STB = 3.43v
                                BSW = 0.084v (I think this is backlight switch)
                                BRI = 0.084v (probably PWM dimming according to service manual schematic)
                                ANA = 0v (PWM2 in service manual schematic)
                                From PWB
                                VCC_A = 20v will drop momentarily when this occurs
                                12V = 12.5 steady when this occurs
                                Possible ~30s PWB squeal / voltage drop is caused by PWB? This does not occur with main disconnected but all the voltages aren't stable or don't look correct when main is disconnected anyways.
                                Contacted HiSense. My understanding from service manual is to first get mboot working to enable USB flash upgrade.
                                MSTV_Tool.exe and ID password to complete "deciphering" which seems to be "unlock ability to flashing eMMC"
                                ISP_Tool to flash mboot to eMMC
                                Correct TV bin file for USB upgrading
                                Seems like many firmware corruptions just require USB upgrade so mboot remains intact and main gets far enough to light up the screen with logo. If this one is firmware failure, then it would have also corrupted mboot.
                                Will do, hard to untangle which is bad (PWB or main) so will proceed both for now.
                                • Diah
                                  • Feb 2013
                                  • 6560
                                  since its Android. there are no Mboot... will be bootloader... and if the bootloader not in tact then no more reboot or try to reboot.
                                  suggested in your case remove any load from MB... BT or WIFI.... speaker ... BGA at the parts i mentioned before cause this too.... at the end all repair level just replace boards. if there are no Oscilloscope in hand.
                                  • lotas
                                    • Jan 2016
                                    • 4854
                                    • Russia
                                    Try to find the TX and RX points on the board, connect the UART to USB adapter to them, run the terminal program and look at the terminal boot log, and you will see where the problem is. (The main thing is that UART is not disabled in the firmware itself).
                                    • howardc64
                                      • Jun 2017
                                      • 653
                                      Thanks, will look for bootloader.
                                      Tried removing all connectors (panel, wifi, speaker, with and without IR+power button) and unfortunately no sign of booting (no SPDIF, CPU enabled USB port power)
                                      And yes, without scope, hard to make much progress other than board swap. Given the availability and cost of the boards > $100, most owners encountering are just trashing the TVs
                                      Yes, TV has 3.5mm audio jack for service port that is UART. Searching for my USB UART dongle or order one or find old DB9 computer and build a cable. Then I'll have more insight on CPU activity/any logs.
                                      Since there are so many firmware failures on these HiSense Android TVs, am motivated to see if can succeed firmware reinstall to publish procedure and help save more of these hisense TVs
                                      • howardc64
                                        • Jun 2017
                                        • 653
                                        Anyone knows necessary spec for the HW UART connection to this TV?
                                        Service Manual for 2018 HiSense (link in post #1, this TV is 2020 but use same main SOC) shows a HiSense serial board RSAG7.820.2335T with USB to PC and DB9->3.5mm jack to service port.
                                        Same 2018 service manual shows UART circuit diagram which connects directly to main SOC (probably 3.3v GPIO?). I'm guessing the proper signaling probably requires 3.3v RX/TX. I measured the service port directly and see 3.3v
                                        Finally, has anyone used a cheap USB<->Serial TTL dongle based on FT232RL or CH340G to connect to UART on these HiSense TV's service ports? Both of these have changeable RX/TX voltage from 5 to 3.3v.
                                        Just want to make sure I gather the correct USB to UART HW.
                                        • Dragunov
                                          Need firmware for HISENSE 40A5NQ
                                          by Dragunov
                                          i need firmware for HISENSE 40A5NQ so i can flash it via USB...
                                          Tried via USA website but it doesnt accept my serial number TV was bought in croatia.
                                          Remote works only to power on tv and after that i cant select firmware update or anything else...
                                          07-07-2025, 01:33 PM
                                        • joby91
                                          SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                          by joby91
                                          I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                          I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                          I found one chat about firmware on ************** forum but i cannot read the comments.
                                          https://**************/forum/108-114100-1#880537
                                          09-04-2024, 01:34 PM
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • DoubleBogey817
                                          HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                          by DoubleBogey817
                                          HISENSE 65H6510G (13 AUGUST 2020)
                                          When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                          02-16-2024, 10:58 PM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
