Hisense H6750G stumped on this
  • EazyBone
    • Jun 2023
    • 1354
    • United states
    #41
    Re: Hisense H6750G stumped on this
    So the tcon fuse is good, showing continuity with a probe on each end, but you have no 12 volt on either side? then no voltage getting to tcon.
    I got no nothing now, the MB shows no voltages anymore lol. Checked that resistor voltage, TV finally turned on backlight and poof, MB done for some reason. But yes I didn't get 12v to tcon before then either
    • Diah
      • Feb 2013
      • 6441
      yours TV system Android. as any box or android TV the PSU produce 12V -10V always this will go to Step down on MB to generate 3.3 / 1.8 etc to let the Nand / CPU start the firmware start script (boot loader) , at this stage the PSU will go High and turn on all other rails include the BL
      to trouble shooting Android MB.. we look after the low voltage i mentioned before.. if they are exist , then we have issue at eMMC / CPU / and the last issue at Firmware ( boot loader )
      working around as any Mobile.... can play to knop power volume down and then plug in wall... or contact Hisense to have complete Firmware on USB..
      the sign make me write this... because when u touched part the script start and BL come on.. so its sound for me boot loader issue or dead eMMC
      • EazyBone
        • Jun 2023
        • 1354
        • United states
        #43
        Also main board was found and TV works fine now
        Originally posted by Diah
        as you said no change... keep the LVDS disconnected from MB side.... make wire jumper from 12V PSU socket direct to T-CON fuse... then turn on... see if the screen under tourch light generate color pattern... to be sure we have t_CON and panel are fine.... .... you can use too yours led testers to light on one group only of BL to see if screen work with out issue.
        Can you tell me what brand of tvs this works on in general? This was very helpful
        • Diah
          • Feb 2013
          • 6441
          at any brand with Panel T-CON had firmware section saved on SPI / NOR
          • RossMoodley1967
            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
            by RossMoodley1967
            Hello
            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
            03-01-2024, 06:07 AM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • BadCapex
            Hisense main board surrogate evaluation
            by BadCapex
            I am yet another unfortunate owner of a 65H6570F with a main board that failed due to an inherent flaw with the eMMC.
            Reference: https://www.badcaps.net/forum/showthread.php?t=117406
            The exact replacement board for a 65H6570 model TV is RSAG7.820.8831/ROH (aka 265223, aka 244991). It is very rare or expensive ($150+) to purchase currently and arguably not worth it if they're all just ticking time bombs.
            A very similar board was identified in the above referenced thread, RSAG7.820.10315/ROH. It is more reliable, cheap, plentiful, and...
            10-22-2023, 04:36 PM
          • LemoneyF
            Hisense 50r6- no standby, no power, bad main board?
            by LemoneyF
            Hi all
            I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
            I have tested the power supply and found the following:
            363V and 373V across the input caps
            bri- 0V
            ana- 0V
            vamp-17.03V
            vamp-17.03V
            stb- 0V
            12V- 9.3V
            12V- 9.3V
            To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
            10-12-2022, 07:44 AM
