Finlux LED backlight not working
  • stoian_93
    • Oct 2022
    • 13
    • Bulgaria
    Hello guys!
    My Finlux TV backlight stopped working. I disassembled the TV, saw I don't have the tools to replace the backlight and assembled it again without replacing anything. So then the backlight started working again.
    A day after it is also not working.
    I decided now to remove the back cover and get the output voltage to the backlight. I placed the TV facedown and connected to the mains, so - nothing. I disconected, removed the cover and connected again to the mains and then the backlight lighted again. So strange.
    Output voltage when light is 66V.
    Board: VESTEL 17IPS62
    What could the problem be?
  • yokoono
    • Apr 2010
    • 481
    Re: Finlux LED backlight not working
    Change the LEDs and stop wasting time. 2x 11 leds x 3v = 66V. The voltage is correct.
    • stoian_93
      • Oct 2022
      • 13
      • Bulgaria
      They were already changed 2 times untill now.
      • zwarder
        • Oct 2013
        • 45
        • United Kingdom
        Buy new led strips from aliexpress with the sreen number usually VES******
        • stoian_93
          • Oct 2022
          • 13
          • Bulgaria
          Guys, the LED stops lighting, and after some time starts again.
          Last time I opened the TV again, pluged into the mains, the LED did NOT lighted and I measured 24V, going to it.
          I can not find out which element on the board is the problem.
            • 12112
            • U.S.
            Wonder if it's a bad led driver ic on the powerboard or something, make sure it's not just a bad solder joint, see if you can get a clue from that page: https://www.google.com/search?client...ps62+schematic
            • stoian_93
              • Oct 2022
              • 13
              • Bulgaria
              I'm sure it's not a bad joint. I saw some of them and made them again, so it's not. I ordered new driver and when replace it will see if it is. But there's nothing else, that seems to be defective. Thank you 'till now!
                • 20643
                Put make and model number in thread title ! ! ! https://www.badcaps.net/forum/showthread.php?t=24661
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • knoxrebel
                  TCL 65s425 sound/video working, no backlight
                  by knoxrebel
                  Tv shows no issues other than no backlight. Picture was visible with flashlight and menu navigation possible with audible responses.
                  Polyester film Capacitor c620 27nf (on power supply board had visible brown discoloration, but is not shorted. Replaced with suitable spare and now working properly. (Apparently this is a known issue with this series.)
                  Backlights tested independently with tester and registered ~140vs on each.
                  40-L171w4-pwa1g
                  Mmkp82 1kv 273 J...
                  01-12-2025, 03:33 PM
                • PITERPENY
                  MacBook Air A1932 Keyboard backlight not working
                  by PITERPENY
                  After updating the system to Sonoma, the keyboard backlight does not turn on! Preinstallation through recovery did not change the situation. Resetting smc and pram did not help! restore via dfu is also zero! I put the board in another Mac and it turns on the light! I put a board from another Mac into this one and the backlight works too! Only the original board does not turn on the backlight! Can anyone please advise, I beg you!
                  03-13-2024, 07:01 PM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
