MacBook Air A1932 Keyboard backlight not working
This topic has been answered.
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    After updating the system to Sonoma, the keyboard backlight does not turn on! Preinstallation through recovery did not change the situation. Resetting smc and pram did not help! restore via dfu is also zero! I put the board in another Mac and it turns on the light! I put a board from another Mac into this one and the backlight works too! Only the original board does not turn on the backlight! Can anyone please advise, I beg you!
  • Answer selected by PITERPENY at 03-23-2024, 04:50 PM.
    mon2
    • 14657
    https://repair.wiki/w/MacBook_Air_A1...0to%20firmware.
    • mon2
      • 14657
      • astroboypaul
        MacBook Air A1932 Keyboard Schematic 820-01294-A
        by astroboypaul
        Can anyone help with a schematic and board layout for the keyboard 820-01294-A in Macbook Air A1932 please? (for reference, mainboard is 820-01521-A)
        Alternatively, I'd settle for confirming value of a resistor on the keyboard (red arrow in picture below)
        Water damage keyboard, with corrosion visible on the noted resistor (picture was taken after cleaning). One pad under the resistor was corroded and resistor fell off while clearing the potting resin (or whatever it is Apple has coated the components in).
        By chance I discovered that mainboard 820-02443 has...
        03-22-2024, 11:57 PM
      • defdjamel
        macbook a1932 no screen , no backlight
        by defdjamel
        hi there , in this A1932 - Air 13 Retina 2018 820-01521, there no screen , no backlight.
        no liquid damage.
        i have change the lcd flex ,
        tested with a working lcd screen but no display , no backlight.
        hdmi over usbc is ok .laptop is working .
        the same.
        here measurement
        • PP3V3_LCD = 3,3 V
        • PP5V_LCD = 5 V
        • I2C_SDA_TCON / I2C_SCL_TCON = 3,3 V (no oscilation)
        • LCD_PWR_EN = 5 V
        • LCDBKLT_EN_L = 12 V
        • EDP_BKLT_EN = 0 V
        • IPD_LID_OPEN = 1.8 V
        i am stuck, if you have an idea....
        09-16-2025, 06:52 AM
      • ktmmotocross
        Asus G513QE keyboard and backlight not working
        by ktmmotocross
        Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
        i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
        but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
        08-08-2025, 06:29 AM
      • playit
        ps/2 port keyboard dead ? p5ql pro / ethernet cable light
        by playit
        my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
        my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
        few years back ps2 mouse stopped working, but ps2...
        12-23-2024, 06:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
