Quick question about the ribbon
  • Rubenlily
    • Aug 2023
    • 37
    • Sweden
    Hey,
    So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
    When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines so what does this tell me?
    What is the problem here? Is It the ribbon itself?
  • ikmpch
    • Jul 2020
    • 22
    Re: Quick question about the ribbon
    You can clean and re seat ribbon cables to see if anything changes.
    I would also suggest to check the important voltages on the T-con board. The voltage regulators usually ICs go bad. Good luck with your repairs.
      • 12307
      • U.S.
      Report the full model number on the back cover.
        • 12307
        • U.S.
        Have a read, start with simple things first because sometimes it is simple, do the resets suggested, no joy, move on to factory reset, firmware update etc: https://www.technewstoday.com/horizo...-on-tv-screen/
          • 12307
          • U.S.
          Here's a simple video of the "cut-off" method, it might not work but it can work even tho there is no half picture with one side unhooked, many more examples on youtube: https://www.youtube.com/shorts/-MftCkVto5A
          • Rubenlily
            • Aug 2023
            • 37
            • Sweden
            I've done the cleaning and reseating with no luck.
            I don't have a multimeter, haven't bought one yet so I will check the voltages once I get one. How do I know if it's something like that or the panel?
            • Rubenlily
              • Aug 2023
              • 37
              • Sweden
              The TV model is Samsung QE50Q67TAU
              Model code: QE50Q67TAUXXC
              • Rubenlily
                • Aug 2023
                • 37
                • Sweden
                Thank you. I've done all the joyless parts. Power cycle, soft reset, hard reset, picture test, update, change of socket, change of power cable etc. I have made a thread about the problem with the model name Samsung QE50Q67TAU but I just want to know what it means when I get no half split when disconnecting the ribbon one at a time. I've not seen anything about it after scouring the internet and Youtube for hours and hours.
                • Rubenlily
                  • Aug 2023
                  • 37
                  • Sweden
                  Thanks for the link. I've tried this on both the ribbons with no luck. I've even tried it on the panel ribbon from the main board to the t-con thinking I might get lucky.
                    • 12307
                    • U.S.
                    Someone here can probably help you check the diode packs and or resistors on the panel driver boards, there's been lots of posts about them, you can also check the little mlc capacitors on those panel driver boards for visible damage, shorts or very low ohms.
                      • 12307
                      • U.S.
                      You can use just a basic multimeter for checking tvs, don't need anything fancy.
                        • 12307
                        • U.S.
                        Post a picture of the lines, different type lines can mean different faults.
                        • Rubenlily
                          • Aug 2023
                          • 37
                          • Sweden
                          I've just purchased a multimeter and will start searching. Will look in the forum and on YT for tips. I've no idea right now what to do. Thanks for the tips.
                          • Rubenlily
                            • Aug 2023
                            • 37
                            • Sweden
                            Here are a picture of the lines. The lines are not solid, at least not all. Some change color and some disappear. Changes happens like every other second.
                            I've already made a thread about the TV and just made this thread to get answer to a question I couldn't find an answer to. More info in the thread below.
                            Thread:
                            https://www.badcaps.net/forum/showthread.php?t=122423
                            • Rubenlily
                              • Aug 2023
                              • 37
                              • Sweden
                              This is what I have to work with. I have the power board, the mainboard and the other long board going from end to end.
                              Only Voltage Regulator I've found is on the mainboard circled in red but that can't be true? Where should I put my focus? On the mainboard or the long board?
                              • Scincidae
                                UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
                                by Scincidae
                                I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
                                I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
                                04-24-2022, 06:00 PM
                              • zesko
                                xps 9520 ribbon cable
                                by zesko
                                I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                                There is 2 models, idk which one is needed on my laptop.
                                0xkvng
                                00vpr2
                                Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                                Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                                thanks...
                                10-23-2025, 05:03 PM
                              • kca
                                by kca
                                Hello all ~
                                08-31-2025, 06:38 AM
                              • netgearnetgear
                                TCL 43S423 TCON OR PANEL FAULTY???
                                by netgearnetgear
                                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                08-20-2025, 06:04 PM
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
