Sony KDL-46EX700
  • haybales
    • Aug 2025
    Can someone clarify which board was the issue?
    • digitalshooter
      • Jul 2023
      • 24
      This is my old board that was replaced.
      • haybales
        • Aug 2025
        Thank you for posting that image… super helpful!
        • YasaCh
          Sony kdl 40p5500 red light keeps blinking 3 times
          by YasaCh
          Hello...
          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
          i opened the back cover no sign of damage on the powery suply or motherboard
          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
          07-07-2025, 11:53 AM
        • shahnld
          Sony kdl 65xg9505 green amber blinking
          by shahnld
          Good Day.
          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
          01-03-2024, 03:05 PM
        • James007$
          Sony KDL-70R550A red led blinking 5 times, troubleshooting
          by James007$
          Hey mates! my tv keeps blinking 5 time and when I turn on it doesn't show anything on screen and it turns off after a few seconds.
          I am having the same issue as this guy: https://www.badcaps.net/forum/showthread.php?t=65126 and following his method,
          I have removed the right bottom ribbon cable and the tv starts but the picture showing but not very clear and good, I attached a pic.
          Can anyone point me to the next step I should take? thanks!...
          07-09-2022, 05:03 PM
        • YasaCh
          sony kd-49xf9005 4 red blinking problem
          by YasaCh
          Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
          05-05-2025, 08:40 AM
        • NolesFan
          Sony kd-85x85j LED blinking red 6 times
          by NolesFan
          I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
          03-16-2025, 11:50 AM
