Panasonic TX-P50U30B power issue
+ More Options
Posts
  • ag63kry
    • May 2023
    • 9
    • United Kingdom
    Hi
    Got my Panasonic plasma tv that stopped working suddenly.
    Took out the cover all the leads from the powr baord in the middle apart of the main 220AC. and measured Vsus and 15V DC on P2 and P11 connector. Found nothing. Concluded it is the board
    Replaced with a second hand one but still the same issue.
    Cannot see the 5V or the 15V on the board with or without all the other leads attached.
    Here is an example of what I have measured on P6 connector (see the image).
    3V DC on pin 6 (STBby 5V and
    0,3V DC on pin 7 (F_stdby_on)
    No lights on LED, no ticking sound or buzzing.
    Please help
    Could it be the main A board? I was expecting to see the 5V and the 15V DC on the power board even if the A board is defective or disconnected, am I right?
    Any ideas anyone?
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Panasonic TX-P50U30B power issue
    The inclusion algorithm…
    • ag63kry
      • May 2023
      • 9
      • United Kingdom
      Hi. Thanks for that.
      Issue now solved , changed the A board, all ok.
      The only thing is that I have au automatic menu activated when I start the TV- see picture. Even if I press exit, the red info (setvice mode info I guess) remains on the screen which is absolutely annoying
      Anyone have any idea?
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        Try
        • ag63kry
          • May 2023
          • 9
          • United Kingdom
          Originally posted by kasfamily
          Try
          Hi. Thanks for that. It does not work. It all starts when I turn on the TV . It says <Start adjust menu> and then the attached picture is displayed. If I press exit, it is gone, but stiil the red service info remains at the left side of the screen. The remote control does not also have a Menu button , otherwise I would have tried to factory reset it.
          So stuck here, no idea what else to try
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            Press and hold the “V-“ on tv and press the «menu» button on the remote control. After that , turn off the TV with the power switch .
            • ag63kry
              • May 2023
              • 9
              • United Kingdom
              I don't have a Menu button on the remote I bought the TV with. I will order a new one if that is a working solution. You sure you are this will work?
              • kasfamily
                • Aug 2014
                • 774
                • Russia
                Turning off the TV with the power switch does not help to exit the service mode ?
                • ag63kry
                  • May 2023
                  • 9
                  • United Kingdom
                  Hi. No. It always goes to the same menu. I have also tried to leave with no power for 60 minutes, no difference
                  • kasfamily
                    • Aug 2014
                    • 774
                    • Russia
                    • ag63kry
                      • May 2023
                      • 9
                      • United Kingdom
                      thanks for that. New remote ordered, will keep you updated
                      Thanks for your help Kasfamily
                      • kasfamily
                        • Aug 2014
                        • 774
                        • Russia
                        Someone managed to exit the service mode like this: press and hold "V-" on the TV and press "OK" 3 times quickly on the remote control, and then pull the power cord out of the socket.
                        • ag63kry
                          • May 2023
                          • 9
                          • United Kingdom
                          No it does not work. <Start adjustment menu > still on the scrren first thing when I power up
                          • kasfamily
                            • Aug 2014
                            • 774
                            • Russia
                            Ok
                            For example, such a remote control…
                            • ag63kry
                              • May 2023
                              • 9
                              • United Kingdom
                              Ok
                              Hi. Remote control arrived now. Reset it to factory defaults and the TV image is now clear with no service info on the screen
                              Many thanks <kasfamily>
                              • kasfamily
                                • Aug 2014
                                • 774
                                • Russia
                                Ok.
                                • Soulzink
                                  Samsug washing machine. Power supply DC41-00189a board issue
                                  by Soulzink
                                  I am trying to fix a samsung washinmachine power supply main board.
                                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                  The power supply board reference is the following: DC41-00189a
                                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                  04-19-2025, 06:26 AM
                                  by sam_sam_sam
                                  After all of...
                                  07-13-2024, 08:14 PM
                                • canadaboy25
                                  Panasonic TC-P54VT25 No image. A or D board?
                                  by canadaboy25
                                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                  The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                  01-17-2021, 01:06 AM
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
                                • Stephen
                                  A2991 Logic Board issue, 20volts 0 amps help!
                                  by Stephen
                                  Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                  09-10-2025, 03:16 PM
