Blinking power light fix for DVP642 DVD Player
  • NorthIL
    • Nov 2005
    I've just completed repairing the 642 from the dreaded 'blinking
    power light', which is caused of course by a bad 1000u cap on the PS. This was my first cap replacement, and was successful.
    I took some photos while I was replacing the dead
    cap, with some simple instructions in the photos. The photos
    are located in the folder 'Philips DVP642 Repair' in my blog at:
    http://360.yahoo.com/mikescottfrank
    Unfortunately, yahoo automatically resizes them to about 300x400, so the
    text on the pictures is barely legible.
    Of course, you will want to get as many instructions as possible
    from the board. I fixed mine for $1.50 + about 1.5 hours of time.
    For those who have this otherwise nice DVD player, lots of info about
    it at http://groups.yahoo.com/group/philips_dvp642/
    MODERATOR: If you want the full size photos (1024x768) for your board, email me. There are about 12 pics. Too many large ones to post here.
  • dokbob
    • Nov 2005
    • 7
    Re: Blinking power light fix for DVP642 DVD Player
    i'd appreciate even one picture of the bad part c316, in the philips dvd player model dvp642. i need to replace someone's failing part, and i have not been able to see the type and physical size of the required replacement part yet. i know that the replacement has to be 1000 microfarads, at minimum 16vdc. what brand-name/manufacturer for the replacement? probably rubycon? how tall and what diameter is the replacement? could someone post one little picture and the location of capacitor 316 in the chassis? thanks.
    • NorthIL
      • Nov 2005
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        that radioshack cap is not low esr.
        it may work for a while but expect a repeat failure.replace all the caps on the secondary side with low esr types for a lasting repair.
        • Newbie2
          • Sep 2005
          • 885
          RadioShack (The Source CC here in Canada) sells generic capacitors. In Canada they sell "REC" capacitors. What brand of capacitor do they sell in the U.S.A. NorthIL? My uncle has a DVP642 DVD player and he does not like the blinking power light. In Canada they do not sell 272-1032 capacitors but they sell 1000uF 50V capacitors. Here is the link. You can see if these are also good.
          http://www.thesourcecc.com/estore/Pr...roduct=2729014
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            NorthIL, your blog notes the following on the repair list :
            -solder pen ( not gun ). Preferably one of those new cordless 'cool touch' type.
            are you talking about cool heat soldering iron? not recommended, as per KC8's advice it sparks and can make 6v across the tip. not good for electronics.
            • Newbie2
              • Sep 2005
              • 885
              I think someone said on the forums that those cool heat soldering irons killed their motherboard!
              My gaming PC:
              • NorthIL
                • Nov 2005
                Wow, kc8adu Im glad to told me that. I'll get one and keep it on hand in case of the future failure, and I will update my photos with correct type. What
                exact replacement part # from RS? Same spec. as the source one?
                ALUMINUM ELECTROLYTIC, 50V CAPACITORS
                Catalog Number: 2729014
                I'll also remove the note about the cold heat solder pen. That's odd. Does the
                manufacturer of cold heat specifically say in their manual NOT to use it on sensitive electronics?
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  rs does not have the proper low esr caps.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    digikey catalogue
                    panasonic FC radial - pages 963-965
                    panasonic FM radial - page 966
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      Is there a post somewhere about hte Cold Heat soldering iron? There's a recent discussion on another message board I go to about these, and someone asked why they're bad. I'd like to link them to some information...
                      HEre's the latest iteration of Cold Heat- http://www.moditory.com/content/view/238/34/1/0/
                      Ludicrous gibs!
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        just google for coldheat sparks i am sure you can find something.
                        • capnewbie
                          • Mar 2006
                          NorthIL,
                          I am a complete newbie to diagnosing & replacing bad caps.
                          THANK YOU for your concise help and advice - I fixed my DVP642 flashing standbylisght problem in < 20 mins.
                          A great and helpful post - Massive respect from a happy newbie!
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            you might want to contact him direct on his site, i didnt see him pass by here for a while. its always great to receive positive feedback
                            • arneson
                              • Sep 2005
                              • 1267
                              This year, under the christmas tree, a small long box, cold solder.
                              Wait, way in back a simmilar box, another cold solder.
                              Last gift, could it be? another cold solder. Everyone thought this would be the coolest present.
                              These are the most useless gimmicks since the "chill wizard", another funny gift.
                              I couldn't solder with this if I used all three of them at the same time, wouldn't that make a good spark?
                              Jim
                              • ewoudy
                                • May 2006
                                Thanks for the great photos and tips. I did the repair without problems -- all of 20 minutes with a bit of solder and solder wick. How nice to be able to actually replace a faulty part on a piece of modern hardware!
                                • bossfn
                                  • Aug 2006
                                  In NorthIL's pics it mentions he uses a 32V 1000u cap instead of the 16V that was OEM. In my DVP 642 there is a 10V cap...the only ones I could find at The Source were 1000u 50v caps.
                                  Is it safe to use a 50v one? From what I gather, 1000u and MIN 16v is the requirement, so 32/50 are fine to use.
                                  Sound ok?
                                  • milano
                                    • Sep 2006
                                    I just used the Radio Shack 272-1032 to repair my player. Works great now.
                                    • bossfn
                                      • Aug 2006
                                      I used the 1000u 50v cap. It was way bigger than the OEM one, barely fit in the spot. However, it is 100% working again.
                                      Thanks so much for this info. It saved me from having to find a new player.
                                      • mlim82480
                                        • Oct 2006
                                        The cap I pulled out of my board was 1000uF 10v. I found a site that sells it with low ESR http://www.stsi.com/Merchant2/mercha...TGY/Capacitors
                                        there are 2 different models EEU-FC1A102 and EEU-FC1A102L, does anyone know what the difference is? The only difference I see is that one is .10 cents more.
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                        • 1centchips
                                          Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
                                          by 1centchips
                                          I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
                                          The laptop is just out of warranty.
                                          The laptop continues to freeze randomly with the blinking amber charging light.
                                          What could be possibly wrong with it?
                                          I have also disable armoury crate in bios.
                                          12-17-2024, 05:18 PM
