Blinking power light fix for DVP642 DVD Player
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Blinking power light fix for DVP642 DVD Player
    The case size is the difference, especially the diameter. As long as space dosn?t mather, use the one with the biggest diameter.
    • mlim82480
      • Oct 2006
      Thanks for the info, gonzo. I found few 1000uF 10v caps in a nonworking computer power supply, my player works fine again.
      • NorthIL
        • Nov 2005
        Well, thanks for all your comments in the thread. I did see about the crappy cordless solder pens and won't ever use them on electronics.
        Its been over 1 year since the repair on my player, and its still going strong. Whether or not the cap i put in will hold up for years to come..only time will tell, but I still love the DVP642.
        • jaykayd
          • Aug 2007
          I have a feeling that whether you like the DVP642 depends on whether you were successful at fixing this problem. I was successful, so I still like the player. But c'mon, Philips.
          Anyway, here's a little info to help others. I went to Fry's electronics here in L.A. (Woodland Hills to be exact) and purchased an ECG 25 watt soldering iron for $5.99, an NTE "High Temperature" Electrolytic Capacitor (1000MFD, 16V) for $1.90, and some Kester Electronic Silver Solder for $1.99. Total cost was $10.70 with tax. I've never soldered before (or even held an iron before purchasing this one) and it was pretty simple if you follow the pics and instructions on Mike F's blog above.
          If for some reason his blog isn't working here's a simplified version:
          1. Take the cover off your player.
          2. Find the C316 capacitor... it's on the same PCB that the main power cord comes in on. Mine was bulging slightly upward, but didn't have a leak or anything.
          3. Unscrew the PCB, turn it over and locate the bottom pins of C316.
          4. Apply the soldering iron to the solder surrounding pins until the solder is melted. I held the capacitor at the same time as Mike's instructions said, but it got really hot. So instead I worked on getting the solder melted and occasionally tugged at the capacitor. After about 5 minutes, it came free pretty easy.
          5. Put in the new capacitor... the shorter pin (-) goes into the shaded hole side of the PCB. Once in, I used a toenail clipper to shorten the ends of the capacitor pins to about a half a centimeter. If you don't have toenail clippers, get a pedicure immediately because you are neglecting your toes . I was able to seat the capacitor all the way down to the board. Then I heated the surrounding solder, and added some from the solder I purchased. That was the easiest and most fun part... it just ran down the soldering pen right to where I wanted it. Heed the warning not to let the separate solder trails on the PCB touch... from my experience you'd have to intentionally goof up to have that happen, but who knows.
          6. Lastly, reconnect everything and watch DVDs with the smug feeling that you are some sort of electronics expert thanks to Philips trying to save a couple bucks.
          • davmax
            • Dec 2005
            • 899
            I have just taken a look at my DVP642 and C316 can be replaced bya fairly common 1000uF 6.3Volt Low ESR capacitor as used on computer motherboards. The operating voltage on the cap is 5 volts. I have placed a 6.3V cap in my DVP.
            160Gb WD SATAII Server grade
            Nvidia 8500GT 256Mb
            Samsung 18x DVD writer
            33 way card reader
            Windows XP Pro SP3
            17" Benq FP737s LCD monitor
            • starfury1
              • May 2006
              • 1256
              #26
              Doh! read bottom of first page, thought it was last...so disregard already been answered
              The cap I pulled out of my board was 1000uF 10v. I found a site that sells it with low ESR http://www.stsi.com/Merchant2/merch...CTGY/Capacitors
              there are 2 different models EEU-FC1A102 and EEU-FC1A102L, does anyone know what the difference is? The only difference I see is that one is .10 cents more.
              humm think you got panasonic FC series the "L" is a smaller Diameter can, I think
              Panasonic FC series PDF
              Think the specs change a bit because of this but sometimes you have no choice but to use a smaller diameter can
              HTH cheers
              • gastorgrab
                • May 2007
                • 320
                #27
                What exactly is the 'blinking light failure'?
                I have two of these units (DVP-642), one about 3-4 years old and one under a year old, but both seem to work fine.
                I do have an older DVD player that didn't last too long at all. Brand/Model is Blaupunkt DVD-ME1 (same as Shinco DVD-168). This player will play the first disc you put in on power up but will not play the second unless unplugged for 24 hours.
                Could this be a similar problem?
                (i'll see if i can find the caps on the bad-cap list)
                • gastorgrab
                  • May 2007
                  • 320
                  #28
                  There are only 6 caps on the power board that have vents.
                  3 brands i have never heard of and can't find on the 'Bad' list are;
                  chang
                  FOAI
                  NL
                  None appear to be bulged in any way but the power problem is similar to a bad PSU i had once. The PC would run fine until shutdown but wouldn't restart unless i unplugged it for a while.
                  I have most of what i need already (the caps with vents) but i'm guessing that all will need to be replaced.
                  Maybe i'll take a pre-cap pic.
                  • gastorgrab
                    • May 2007
                    • 320
                    #29
                    Simple little board:
                    The parts list for the vented caps is:
                    1 x 220uf, 16v 8mm
                    1 x 470uf, 10v 8mm - (i dont' have one of these, and can't replace it)
                    2 x 1000uf, 6.3v, 8mm
                    2 x 1000uf, 10v, 8mm (there are oversized, 10mm caps on the board for some reason)
                    Let's see what happens.
                    • gastorgrab
                      • May 2007
                      • 320
                      #30
                      After the update:
                      470uf, 10v replaced with Rubycon MBZ 470uf, 16v
                      1000uf, 6.3v replaced with UCC KY 1000uf, 6.3v
                      1000uf, 10v replaced with Rubyconn MCZ 1000uf, 10v
                      This is all i had to work with.
                      Fingers are crossed.
                      • gastorgrab
                        • May 2007
                        • 320
                        #31
                        No change.
                        Popping in a disc leads to a near endless wait only to be disappointed by the message "No Disc".
                        I guess the problem was something else.
                        • stavr0
                          • Nov 2007
                          • 21
                          #32
                          Hit it on the nail right there. According to repairfaqs.org, it more important to have higher temperature tolerance than higher voltage rating. Too high a voltage and the ESR specs start to be too different that what the board expects.
                          The original badcap on there is 1000uF 10V 105°C, a suitable replacement must be at least 105 degrees as well and not too much above 25V or so. 50V is probably overkill, plus will be difficult to fit, as C135 is stuck between other caps. I got a 25V/105°C radial which is 10mmD x 14mmH and had no trouble fitting it in at all.
                          • stavr0
                            • Nov 2007
                            • 21
                            #33
                            Originally posted by gastorgrab
                            No change.
                            Sorry the cap replacement didn't work ...
                            You should mention that those pics aren't of a DVP642 power supply board, I was confused for a while until I reread your original posts about the Blaupunkt. This may mislead others into thinking you were repairing the Philips.
                            • wdfta
                              • Jan 2008
                              #34
                              I just opened my DVP642 DVD player and sure enough C316 (Su'scon 220uF 16v) was leaking yellow-ish brown goo. I also notice the big black capacitor (?) C304 had similar yellow-ish brown goo around it. The markings on this unit is:
                              TBOR
                              105 degrees celius
                              250v/68uF
                              I'm not an electrician or that knowledgeable about electronics but have solder before. Is it safe to replace both of these capacitors?? If I can't find these parts, any suggestions on equivalent replacement parts?
                              Thanks.
                              • davmax
                                • Dec 2005
                                • 899
                                #35
                                Yes if these caps have bulged or leaked replace them. Usually there is a 1000uF capacitor, replace that also.
                                Replace with the same value and temperature rating . The 220 and 1000 must be low ESR types.
                                There are plenty of good brands of capacitors recommended in this forum.
                                Places to get them are here: https://www.badcaps.net/forum/showthread.php?t=613
                                Nvidia 8500GT 256Mb
                                33 way card reader
                                Windows XP Pro SP3
                                • jephthah
                                  • Mar 2008
                                  #36
                                  hello, people:
                                  ESR is not the issue. anyone who says it is, doesnt know what they're talking about, and is just parroting the same misinformation. we're talking about a power supply circuit, not a high speed microcontroller.
                                  the problem is, Phillips put 10V Capacitors on a 12V Power Supply. so of course its going to eventually fail, due it to being overvoltaged. the longer you leave the device on at a time, the sooner it will fail.
                                  all you have to do is put a similar capacitance of at least 16V in its place. I put a 35V cap. if you replaced it with another 10V cap, it will eventually fail again, in about the same amount of time that it took it to fail the first time.
                                  the question is, why is Phillips installing 10V caps in a power supply that calls for 16V? incompetence? negligence? what?
                                  • davmax
                                    • Dec 2005
                                    • 899
                                    #37
                                    Originally posted by jephthah
                                    hello, people:
                                    My DV642 must be very different to yours. The only 10V cap in mine was on a 5V supply I replaced it with a 6.3V cap. All other caps are either 16V or 35V. My operates without any problems. Are you sure you have got it right?
                                    Overvolting usually causes rapid failure.
                                    I guess all you had was a 35V. A little over the top but OK.
                                    Nvidia 8500GT 256Mb
                                    33 way card reader
                                    Windows XP Pro SP3
                                    • davmax
                                      • Dec 2005
                                      • 899
                                      #38
                                      The DVP642 has a switch mode power supply (up to 100Khz) run by a KA5M02659 that has a high voltage (650V) MOSFET internal to the package. This being the case the output caps should be low ESR.
                                      Nvidia 8500GT 256Mb
                                      33 way card reader
                                      Windows XP Pro SP3
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #39
                                        if you found a 10v cap on a 12v line its likely due to an error loading the insertion machine.
                                        i have seen this before.
                                        as stated by dav the secondary caps MUST be high quality low esr types to last any time at all.
                                        thank the beancounters for this failure.
                                        • i4004
                                          • Oct 2006
                                          • 2029
                                          #40
                                          not true at all.
                                          are you aware of the number of smps' in different devices that have normal grade of lytics(non low esr) that lasted in excess of 10 or 20 years?
                                          infact it wouldn't be an exaggeration to state that the only place where low esr caps are a must are pc mobos and simillar devices that operate on rather low voltages so everything counts.
                                          you can put low esr caps there, but you'll still be dumping it to garbage much sooner than good gp lytics can last, because it's cheap mechanics will fail. like gastor's case proves(caps are not the only and exclusive malfunction cause on electronic devices, you know).
                                          so i fully support what jephthah has said.
                                          it's a problem of poor component quality or inadequate ratings of the component.
                                          i've swapped the general purpose lytic in my vcr(leaking and making all sorts of trouble for vcr's operation) with general purpose cap and everything is working as it should. and this was some time ago.
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • Fergal22
                                            Samsung UE40F5300AK blinking red light
                                            by Fergal22
                                            I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                            When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                            I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                            Any help would be appreciated...
                                            02-02-2023, 09:19 AM
                                          • matty24
                                            Samsung UE50MU6172 - red light blinking
                                            by matty24
                                            Hello. I have problem with Samsung UE50MU6172.
                                            TV won't turn on, red standby light is blinking.
                                            Power supply BN44-00807A is fine. I replaced it with the new one.​
                                            Main board BN41-02568B (BN94-12530E)
                                            I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                            03-02-2025, 08:57 AM
                                          • norbiszoke
                                            Samsung 50AU7172, only blinking red light
                                            by norbiszoke
                                            We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                            Regards, Norbert!...
                                            04-17-2024, 06:54 AM
                                          • 1centchips
                                            Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
                                            by 1centchips
                                            I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
                                            The laptop is just out of warranty.
                                            The laptop continues to freeze randomly with the blinking amber charging light.
                                            What could be possibly wrong with it?
                                            I have also disable armoury crate in bios.
                                            12-17-2024, 05:18 PM
