zenith plasma 50"
  • jwmd02
    • Sep 2010
    • 6
    zenith plasma 50"
    What board controls the brightness of the screen on a plasma display. The picture is ok in a poorly lit room but in a room with lights on I can barely see the picture. This is a 2005 model. I already changed the zsus board.
  • cadiman
    • Mar 2010
    • 397
    Re: zenith plasma 50"
    You need to check your voltages from the power supply against the sticker on the panel.
    There will be a white sticker in the upper right hand corner or left hand corner on the pdp itself. looks something like this va/60 vs/175
    You will be able to find va and vs on the power supply board.
    Was the picture better after you changed the z board? It will need the v set on it as well.
    • jwmd02
      • Sep 2010
      • 6
      not better after I changed the board the same. from reading on here I think i need to change the other board. The one I changed had a burn trail on it so i know it was bad.
      • jwmd02
        • Sep 2010
        • 6
        i am teaching myself to work on tvs. I already repaired 2. both of those were lcd. This plasma is older and more to it, so it seems. I repaied two ps3s also.
        • cadiman
          • Mar 2010
          • 397
          A 2005 plasma should have the minimum amount of boards in it. The z will give a very dim goofy picture. Bad y can sometimes give a dim picture, but mostly no picture.
          You need to check v
          If these are hybrid ic y and z you will hear them running or fireing and they will be warm and/or hot.
          I need a model number so I know what boards you have.
          • jwmd02
            • Sep 2010
            • 6
            i ordered the y board and the color improved but pic stayed dim so i ordered the other one and will put it on tomorrow.
            it is a z50px2d
            • jwmd02
              • Sep 2010
              • 6
              the new board fixed the problem
              • PowerAmpFreak
                • 982
                • Sweden
                Sorry for being slow, which board did you refer to as "other board" and "new board fixed the problem"?
                • jwmd02
                  • Sep 2010
                  • 6
                  the y board fixed the problem. I changed the z board first, it had a burn path on it.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • stecos
                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                    by stecos
                    Hi everyone!
                    I happened several times, in the search for help from the web, to consult this very interesting forum.
                    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                    Having said that I come to the gist of my post on the forum as the title suggests.
                    For my passion for technology I'm now collecting several...
                    11-28-2022, 11:39 AM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
