Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
  • gbbradshaw
    • Feb 2023
    • 55
    • United Kingdom
    #41
    Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
    Update: The lvds is perfectly fine, I have tested it with the beep test (continuity) every pin.
    What I have found out is that on both of the ribbon stripes CSF01, the pin highlighted in the picture did not pass the beep test, on both of them there is no continuity. Could this be it? Please see the photo.
    • Diah
      • Feb 2013
      • 6379
      i wrote on my first post #26
      but if you remove the U ribbon... the tv should wrok normal only 3/4 Screnn
      • gbbradshaw
        • Feb 2023
        • 55
        • United Kingdom
        #43
        Originally posted by gbbradshaw
        Is this the right way to do it? Please check the picture
        I know that if the caps beeps when I use the multimeter, in most occasions its a bad capacitor.
        I also know that if I set the multimeter to 20k to check the ohms and the value is not going from 0 to higher, that's also a bad cap.
        Correct / guide me if I am wrong please. Thanks
        It should, but at least one of the u ribbon should be good, while both of mine have that highlighted pin not connected to each other. We can see from the picture that the highlighted area shows a thicker connection between the pins, which I think it's meant to lead power between them. What i think is that The lvds delivers the power to the lower board and from there, the u ribbons are supposed to take it to the display. Does that make any sense? I can't find a better explanation.
        • lotas
          • Jan 2016
          • 4621
          • Russia
          #44
          But the photo shows that this pin is a dummy, there is no conductor.
          • Diah
            • Feb 2013
            • 6379
            this is wrong theory... never being 2 U ribbon defect at same area.... your eyes are tired.. i wrote don't trust your glasses.. only magnifier or telescope can see if there are wrong with pins.
            or you bought this TV as it is now !!!..
            from the photos you posted before we can see the U ribbon cable both side look like larger than original they didn't sitting normally flat.. but there curve and this should never happened with U ribbon. .. they should Flat connected between the tow parts if panel side buffer boards.
            • gbbradshaw
              • Feb 2023
              • 55
              • United Kingdom
              #46
              Is it really? I am no professional so I might be wrong. Can you confirm looking at this picture please? Thanks
              • gbbradshaw
                • Feb 2023
                • 55
                • United Kingdom
                #47
                I have no idea how these ribbon cable should be inside the tv, you definitely have more experience than I do. If I bought the tv as it is, that's for sure, I haven't touched it before developing this issue. Then I believe it might have been fixed before as when I bought it , it wasn't brand new. I will look for a magnifier and go over them again.
                • lotas
                  • Jan 2016
                  • 4621
                  • Russia
                  #48
                  This photo also shows that this pin is a dummy, there is no conductor. (copper conductor inside yellow)
                  • gbbradshaw
                    • Feb 2023
                    • 55
                    • United Kingdom
                    #49
                    I thunk you are right. Since none of the cables (lvds, u ribbon) seems to be damaged, I have taken the risk and bought the pcb board off ebay. I will update this post as soon as I get it changed and hopefully fixed. Thanks to all for involving and helping.
                    • gbbradshaw
                      • Feb 2023
                      • 55
                      • United Kingdom
                      #50
                      Will replacing the pcb board but (theoretically) having bad u ribbon or lvds cable , damage it again?
                      • Diah
                        • Feb 2013
                        • 6379
                        replace PCB.... !!! why and where you got so fast PWB replacment LOL....
                        what had blue screen to do with PWB !!!!
                        • gbbradshaw
                          • Feb 2023
                          • 55
                          • United Kingdom
                          #52
                          I am not sure where did you read that I bought the PWB ? I said I bought the PCB board , hopefully will put my hands on it tomorrow. Why? Because there was nothing else to try. Where? Ebay. Lucky, I know, only one piece on the whole ebay.
                            • 12206
                            • U.S.
                            #53
                            Terminology, pcb=printed circuit board, includes powerboard and mainboard, just call them what they are mainboard has the video/audio inputs, powerboard supplies the power.
                            • Diah
                              • Feb 2013
                              • 6379
                              PCB = PWB= Power circuit Board
                              you mean MB Main Board
                              • gbbradshaw
                                • Feb 2023
                                • 55
                                • United Kingdom
                                #55
                                My bad then, when I say PCB I refer to a board with the whole circuitry/components, whereas when I use PWB, I simply mean the power board. So yeah, I bought the main board.
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  I’m pretty sure it’s the panel that’s bad. I don’t think mainboard is going to fix it. As I mentioned a lot of he TU series have bad panel
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4347
                                    • Italy - Milan
                                    #57
                                    .. so you bought a main board at random? well, shipping companies will smile..
                                    Which code you have searched?
                                    Anyway PCB= printed circuit board; PSB= power supply board; PB= Power board.... aaaah! These acronyms!
                                    • gbbradshaw
                                      • Feb 2023
                                      • 55
                                      • United Kingdom
                                      #58
                                      Bought from one of the biggest suppliers for spare tv parts, with warranty and return in case this is not going to fix my issue. Happy days
                                      • gbbradshaw
                                        • Feb 2023
                                        • 55
                                        • United Kingdom
                                        #59
                                        It might aswell be, but I can only know if I'll try. With all the cables connected, while changing the channels I can see thr screen changing its lights from normal blue to darker, whilst with the lvds off, the screen stands blue. With all of this being considered and with some luck, I would like to think that it is a mainboard problem more than a display problem.
                                        As i said, i am no professional but is more likely the mainboard as it is what controls the signal output to the screen via the LVDS.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4347
                                          • Italy - Milan
                                          #60
                                          but which code, BN41- or BN94- ?
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
