SO i learned some things about these emerson power supplies from this thread: https://www.badcaps.net/forum/showthread.php?t=65611
where i was able to successfully get the power supply to power up and turn on the backlights, proving that i only had a main board issue. the customer was happy with the result, so he referred me to his neighbor who happens to have a very similar TV but the bigger model.
his issue is different though. when i opened up the set i noticed right away that there was a rather large gecko who had found his way in there and died on the PSU.
looks like he touched PFC VIN and probably the GND jumper as well.
the PFC VIN jumpers are bad looking (rusty) but still have continuity.
so i tried to "trick" the power supply on via the method i learned in the other post. i connected P-ON_H2 to P-ON+21V and i applied 5v to BL_SW and ADJ jumpers.
i get the AMP+13v but i do not get any voltage at VLED1, 2 or 3
and it seems there is a rail that feeds all three of them: VLED+27V
that is also 0V
it seems it should get this voltage from the cathodes of Diodes D710, D711, D712 via the secondary of the bigger transformer but those are all 0 as well.
i see 158v at the Primary Filter Cap and the other big caps around that area, and at the primary of the bigger transformer, but it seems like it should be boosted higher than this. since there is a PFC according to the markings on the board.
poking around some more i noticed a jumper wire marked VCC+15V that is at 0v.
this goes to one of the pins of IC1601 which i assume is the switching control IC.
VCC is probably pretty important for this IC to do its job, so i went looking for where this 15v should come from and from what i can tell, it should come from the smaller of the 2 transformers, thru some diodes. i see 18v coming from the cathode of diode D620A. i trace it via J1617 and thru R1656 to a 3 pin diode D1604 where 18v appears on one side but not the other. on that other side is where the VCC+15V jumper wire would take that voltage via a few other jumpers to the IC1601.
i think i may have found the bad component, but i cant find a datasheet for it.
maybe someone can help?
it is marked as far as i can tell BKD and it also has a 2H on the side.
the voltage enters on the side with only one pin, but doesnt appear on either of the pins on the other side. testing in diode mode with red probe on this pin i see open circuit from this pin to either of the others.
please have a look at the pictures and let me know if my reasoning is correct
but more importantly. How to find the replacement component?
THANK YOU!
that is also 0V
THANK YOU!
