Emerson LF501EM6F has 21v and 13v but no vled+27v
  • triplefour
    • May 2014
    • 1747
    Re: Emerson LF501EM6F has 21v and 13v but no vled+27v
    Originally posted by R_J
    D656 charges C656 and before D657 starts to conduct, there is 0 volts on Q654 base, so the collector is being pulled high by R653 which is connected to AL3.3v so Q650 will be turned ON, and the reset pin will be LOW, as soon as D657 conducts and supplies voltage to Q654 base, Q654 conducts turning Q650 OFF and the reset pin is then HIGH.
    The RESET is used to RESET the microprocessor
    So is the tv working now?
    thank you for that explanation. i will read and re-read, and look at the circuit until i understand it.
    yes the TV is working. i have it running playing a DVD for maybe half hour now.
    maybe the gekko damage had nothing to do with anything. maybe it was always just a loose connection that plugging and unplugging the boards and connectors has resolved. who knows? but at least i know how to trick these power supplies on, so if the TV goes down again it will be easy to tell which part it is.
    and i can be fairly confident in testing these PSU's all by themselves because i can at least see the VLED+27 line come up for some time before fading away
    Don't fear the repair...
    • nomoresonys
      • 12307
      • U.S.
      #42
      those backs cover pretty well, hellofa mystery how a gecko could get in there.
      • triplefour
        • May 2014
        • 1747
        yes the back does cover up well enough to stop such a big gecko from getting in there. but when you take the stand off to wall mount the tv, it leaves a hole where the stand went that is quite big! i have something new to warn people about!
        • nomoresonys
          • 12307
          • U.S.
          #44
          ah, ok, I should have been able to figure that out,
            by momaka
            03-15-2023, 10:17 PM
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
          • MMH3
            Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
            by MMH3
            i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
            Never ever i experienced problems with that.
            Now i have one 5050sff machine, where this jumper isnt working at all.
            I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
            The history of the machine is that i used it in my office...
            03-23-2025, 09:28 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Byte_76
            Requesting assistance with 486 motherboard repair
            by Byte_76
            I have a seemingly rare 486 motherboard which shows no signs of life.
            The Motherboard is marked with the labels B887 / 8 / 9 AI, which seems to be a Mecer branded board.
            With an AT power supply hooked up, the power supply turns on but the board does not post, there is no beep and there is nothing displayed on the post analyser card, whether it's plugged into a PCI slot or an ISA slot.
            I found a thread on Vogons of someone else who had the same board in working condition.
            What I've tried so far: (In each case, the symptoms remain unchanged as...
            04-12-2025, 06:43 AM
