Hi, I have a Samsung TV model UN43MU6100GCZB (mainboard BN41-02568B BN41-02568). It first had random HDMI issues, then progressed to turning on with backlight but shutting off after a few seconds. All main power rails are present. Could you please check this dump? I suspect its the main problem. Thanks a lot!
Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
Originally posted by pepebmx View PostHi, I have a Samsung TV model UN43MU6100GCZB (mainboard BN41-02568B BN41-02568). It first had random HDMI issues, then progressed to turning on with backlight but shutting off after a few seconds. All main power rails are present. Could you please check this dump? I suspect its the main problem. Thanks a lot!
Originally posted by zmeutul View PostHello. I also have a samsung ue65mu6172 with the bn41-02568b motherboard that doesn't turn on and doesn't have the standby LED. From what I saw in the hex of the W25Q40CL chip, it seems to be corrupted at first. Can you help me with its repair? Thank you very much!
Originally posted by catran View Posthello, can you help me with UE50mu6102k mainboard bn41-02568b, stdby led on, flash on power on but still on after 1sec below is 25q40, panel is CY-GK050HHNVMH, tested without mainboard, leds ok, power ok on plugin
Read the dump again with the programmer and see what the programmer shows about the status register, what it is set to (should be 0x88, 0x42).Last edited by lotas; 05-13-2025, 04:30 PM.
Originally posted by lotas View Post
If this dump is native, original, then it works.
Originally posted by tuanvo_86 View PostHello
I have one u43mu6100 with no boot problems. I have the Ic1604. It is possible to fix it?
Thank youAttached Files
Originally posted by Salvatore Cancellieri View PostI have this TV with standby LED off, I downloaded the dump, it doesn't seem original to me, is it possible to try to repair it?
TV UE55MU6220 board BN41-02568A
I compressed the dump in winrar, is there any way to repair it?
Is there any way to get this TV to work?
It won't be possible to restore it, since it's not a dump, either you counted it incorrectly, or someone wrote something incomprehensible there. What happened to the TV, what's its history?
