How many times does the standby LED blink between pauses?
Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
It blinks non-stop, without pause, there is no error code. Measuring the voltage on the main PCB connector, the power supply oscillates between 11.5v and 9v. I did the test without the 25q40 and the voltage stabilizes at 9.5v. When I disconnect the power supply cable, the panel LEDs light up normally and the source voltage stabilizes at 12.65v.
I did the test with a bench source too, I injected 12v into the main PCB and there is very low consumption and it goes back to zero, this keeps loopingComment
What is written on the paper is BN94-12811S. Model: BN41-02568 - Code: BN41-02568B is printed on the motherboard. If you want I can take a photo of everythingAttached Filesif you find these attachements useful please consider making a small donation to the site
I can yes! Just to let you know that since I read them the defect is the same. These are the same ones I already sent you, but if you want I can read them again and send them, but as I already told you the problem has been the same since then.Attached Filesif you find these attachements useful please consider making a small donation to the site
You don’t understand me, I don’t need dumps, but what status register is registered on 25Q40, which is what the programmer log shows when reading these statuses.Comment
hmmm now I understand Lotas! About this error log issue, I don't know how to check. The TV's standby LED blinks continuously and does not report any code. To extract the file I use the TL866 II and I don't know how to see this error log with this equipment. 😅☹Comment
Yes, this is not an error log, but a protection (status register), read the 25Q40 chip again and after reading, click on “status register” and a new window will pop up, this window show me where the checkboxes are...Attached Filesif you find these attachements useful please consider making a small donation to the site
Pronto!Attached Filesif you find these attachements useful please consider making a small donation to the site
Right! Can you verify 24512? I understand very little about programming and I'm even curious to understand it better, but as I said, if you can see it for me, I can read it and put it here. Regarding shorts, I didn't find any and the dc/dc ldo regulators I can't check the outputs because the board goes into protection and also doesn't have their reference so I can inject voltage and do the tests. Anyway, I'm still grateful.Comment
24C512 I can't check, since they are all different for each TV (it contains the model, settings, serial numbers, MAC Address, ....), I can upload a working dump for checking, just be sure to save your own one.
Have you checked the wi-fi module or turned it off?
Try.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi Lotas! I've already turned off the Wi-Fi module too, but it stays the same, unless this card only works with the module connected, but I don't think so. I have the board here on the bench, I connected 13v and checked that even the 5v voltage is stable, below it everything fluctuates. I looked for the 25C512 but I didn't find it, I only found a 25512FD but I'm sure it's another component because on the board it has terminals 1 to 4 on the same track, so it can't be 25C512. Finally my head is starting to smoke and I'm already wanting to set everything on fire hahaha I think I'll try to look at another board because I don't have an oscilloscope to be able to see the circuit in another way, I also don't want to take up as much of your time as I already did . Thank you once again for all your support and patience.Comment
Maybe it's still 24512FD, if so, then it's 24C512 and on the board 1-4 pins are connected together and sit on the ground.
You write that your 5v is stable, but below is not stable, while 3.3v is doing well, they should also be stable, since this voltage powers the standby and the spi flash 25Q40 (8pin) should be stable at 3.3v.Last edited by lotas; 10-11-2024, 01:56 PM.Comment
Hi Lotas! Me here again. Analyzing the 3.3v voltage it is also oscillating and then I realized that when removing the inductor from the 3.3v dc/dc regulator (this regulator receives 13v from the source board), after removing the inductor, the 13v from the source board stabilizes, however, As I said, I didn't find any type of short or apparent leak. I also checked if the 3.3v regulator heats up beyond normal, but it doesn't heat up at all. Don't you have the schematic for that board? Now I tried to read the 24512FD (it has pins 1-4 connected to gnd) but it gave an error and I couldn't read it.Maybe it's still 24512FD, if so, then it's 24C512 and on the board 1-4 pins are connected together and sit on the ground.
You write that your 5v is stable, but below is not stable, while 3.3v is doing well, they should also be stable, since this voltage powers the standby and the spi flash 25Q40 (8pin) should be stable at 3.3v.Comment
by YanlebHi all,
My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
Disconnecting the main board from the power supply makes the backlight come ON.
I did disconnect the panel cables and the WIFI modules, the board is still dead.
I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
Thanks. -
by ogabugaHello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D
01-28-2025, 04:48 AM -
by daniel0799Hi everyone,
I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
I can provide photos of my board and the flash...-
Channel: Troubleshooting & Designing Networks
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by totofCould you help me...
I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
Then motherboard connected, standby led is on and current consuption is 18W.
Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
The model of my TV is :
Power supply BN44-00807A
Main Board BN41-02568B / BN94-12765W
Panel CY-GM055HGLV3H... - Loading...
