Vizio D43f-J04 is panel dead?
  • NSkyLab
    • Dec 2022
    • 6
    TV Model: Vizio D43f-J04
    Main Board: TPD.MT5583.PB751 (60103-00876)
    T-Con: BOE_CC430LV2D_43001 V1.0
    Panel: BOEI430WU1
    The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
    This is a dumpster find, don't know if it was hit, there are no visible cracks...
    I though there may be something wrong with the panel voltages.
    Those I managed to find on the T-Con board. Does it seem normal?
    12V: 12.27v
    VCC33: 3.28v
    1.2V: 1.25v
    VGL: -5.87v
    AVDD: 16v
    HAVDD: 7.47v
    VCOM: 7.0v
    The weirdes thing: when I disconnect all ribbon cable from the t-con the panel seem to partially remember and display the last image before turning off...
    Is this panel dead or there are changes it might be a t-con/driver boards issue?
    • 12206
    • U.S.
    Re: Vizio D43f-J04 is panel dead?
    look it over very closely, seems like a cracked/broken screen, sometimes the crack is hiding under the bezel.
    • diif
      • Feb 2014
      • 6978
      • England
      Disconnect one cable from the tcon to the panel and turn on, what does the picture look like ? Put it back and remove the other,
      • NSkyLab
        • Dec 2022
        • 6
        Re: Vizio D43f-J04 is this panel dead?
        Right side ribbon cable disconnected:
        Left side disconnected:
        Can't see any changes...
          • 12206
          • U.S.
          ok after seeing that, I don't think it is cracked, wonder if it could be pressure damage from it having something leaning or sitting on the screen.
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • netgearnetgear
            TCL 43S423 TCON OR PANEL FAULTY???
            by netgearnetgear
            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
            08-20-2025, 06:04 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • KYBOSH
            Samsung UN50TU8000 - Dead Panel Forensic Questions
            by KYBOSH
            I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
            When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
            When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
            Later I checked for shorts on the panel PCB boards but could not find anything.
            When I took a look with the FLIR i noticed the 2 resistors...
            08-10-2024, 08:39 AM
