Philips 55PUS6754/12 Backlight settings override TMP19.6E LA
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    I would like to reduce the backlights for this set. There is no direct settings like in Samsung or LG etc. Probably in Option Codes in SDM.
    If not available I would like to ask if anyone managed to alter the circuit to reduce slightly the LED current. Uses PF7904S U8601
    Tks
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    Re: Philips 55PUS6754/12 Backlight settings override TMP19.6E LA
    No one here ever tried to reduce backlight in modern Philips sets?
      • 12323
      • U.S.
      here's tomtech doing a few, usually done with a resistor mod: https://www.youtube.com/results?sear...r+modification
      • lotas
        • Jan 2016
        • 4905
        • Russia
        These resistors are a current sensor, when one, two, ... are removed, the resistance in this circuit will increase, therefore, the current to the LEDs will decrease.
        • alltvrepairs
          • Jan 2014
          • 256
          • Malta
          Tks. Interesting guy for sure. Nice watching him removing Large screens bare handed without suckers!
          • alltvrepairs
            • Jan 2014
            • 256
            • Malta
            Tks, I was after those lines as well but preferred a confirmation first. Have tried with the 100R series resistor range 75R to120R made no difference. However I am sure removing a resistor from the voltage divider you marked should be a quicker option.
            Tks again!
            • kiko1
              • Apr 2016
              • 48
              • croatia
              I want to wake up this topic a bit.....
              I tried removing resistors from FET-s source, but current did not changed...
              tried also double the source resistance from Q8601....still the same current...go figure....
              I really need PF7904S datasheet...anyone have it??
              • RetroComputingGrotto
                New Toy UNI-T UTi260B - What Settings?
                by RetroComputingGrotto
                I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                09-02-2025, 08:36 AM
              • alltvrepairs
                Philips 55pus6754/12 FZ3A Set Option value dilemma
                by alltvrepairs
                I need to change the main board for this set. I have a new identical board but for a smaller model 43PUS6704/12 FZ3A
                The picture is not good and remote seems not to work either.
                The Set Option on the rear of the TV says 042 as shown in pic.
                The Service manual lists this model but with another screen with a mentioned Option Code of 109. I assume that I need to use the one on the back of the TV.
                The problem I don't know how to tackle yet is the remote issue as not responding. Remote works on another Philips TV.
                03-16-2023, 06:06 AM
              • marekk
                Philips 55PUS6754 with lines after few seconds
                by marekk
                I have tried to replace TCON but it didn't help.
                The strange is that it shows Philips logo before the lines. Tried to cover some of the lines with tape on the ribbons to the screen but had no success.
                screen: tpt550u2-eqya3.g
                tcon: 6870C-0769A
                I will appreciate any help
                Many thanks
                Marek...
                11-03-2022, 03:00 PM
              • istvanszasz99
                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                by istvanszasz99
                Product Name: Razer Blade 15 (2022)
                Product ID: RZ09-0421
                Motherboard: CH580
                BIOS Versions I work with: 2.02 & 2.06
                Bios File Size: 32,768 KB
                Dear Forum Readers!
                I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                !!! MY RAZER BLADE...
                11-24-2025, 05:52 PM
              • Sharpa
                Repair attempt Philips 55OLED804/12
                by Sharpa
                I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                The symptoms when bought: Philips logo appears then tv turns off
                Things tried so far:
                1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                11-22-2025, 08:30 AM
