HP PSC2355 with likely bad caps
  • smeezekitty
    • Aug 2009
    • 32
    So I have this HP PSC2355 printer which I suspect
    has bad capacitors. Symptoms are frequent
    blue error screen (on the printer screen). Failure to start up usually either
    a restart loop, a hang or a blue screen. It seems more likely to successfully
    start when it is warm.
    Also the screen slightly dims in accordance to the activation of the motors.
    I suspect caps but the problem is I cannot figure out how to get
    access to the main circuit board. Any ideas?
    • 31247
    Re: HP PSC2355 with likely bad caps
    there are service manuals online for most HP stuff, you just need to search.
    • smeezekitty
      • Aug 2009
      • 32
      I'm not having any luck on this particular model
      • todenkopf
        • Oct 2014
        • 49
        • UA
        There are no manuals for HP inkjets, except A3+ models and few old officejets.
        Have you checked PSU unit?
        • smeezekitty
          • Aug 2009
          • 32
          Thanks for the reply. I had forgotten about this thread.
          I can confirm that the same problem occurs with a different power supply
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            I'd rather suspect the processor on the printer mainboard in this case. A reflow should (temporarily) fix it.
            A working TV? How boring!
            • smeezekitty
              • Aug 2009
              • 32
              Well wouldn't the backlight dimming in rhythm with the motors point
              to a fried bypass cap?
              Regardless the problem is I cannot get to the board
