i will have the answer later . i normally pick at that white crap after a 30 minute soak but cant be bothered so left it to soak overnight .
is it ok to soak a populated pcb in petrol overnight ?
Tags: None
Re: is it ok to soak a populated pcb in petrol overnight ?
well it softened it enough to find 3 through hole resistors loose and somehow the ntc has lost its bead .maybe i knocked it off but i was careful scraping .Comment
Good job, another way to remove the potting mixture is to BOIL it in a saucepan for at least 20 min. I've done this a number of times, best to put in some marbles...to keep the board off the bottom of the pan. It may take a few times, but be assured it works. The problem with solvents can be losing part types.
GraemeComment
by foshlandHi, I have this card with the fuses, resistors or whatever they should be not populated from factory, maybe the seller scammed me or im comming crazy, but as I can see, there never where something there, have a look, what do you think?
More fun comes when I saw a Dicky96 video with same card and he meassured the 6pin fuses (the ones im talking about) and he finds that they are open (but as far as I can see there is nothing there, just pads)
Does anyone has same card??? schematics says they should be there.
Link to LER video (very thanks for all your videos... -
by beetle1303I have a 7-year old Panasonic inverter refrigerator model NR-BY602XS that went from working normally to completely not cold air overnight (both freezer and refrigerator compartments...
The service manual instruction on Self Diagnostic Test seems to indicated Compressor faulty or locked. But the compressor seems to be working with humming sound and vibrating at variable speed and noise level..
Everything else seems to be working normally - power cycled a few times has no effect. All the interior lights, and fan are working. I dismantled the interior panel to expose... -
by rutgervDear all,
For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
The issue with the Acer laptop is the following:
It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power... -
by NovgorodHi!
I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
What are the steps for DIMM (DDR4) socket troubleshooting? Since the... -
by Jesse JamesHey guys need help with this one. I have a cq62-225NR that runs and works well on windows 7 or 10. The problem i am having is it kills good known battery overnight dead. It charges well and runs off battery fine and is shutting down when powered off. I don't have the board # as i have not opened unit yet. This is the AMD model
Any help would be great - Loading...
